Headlight issue
Old Jun 26, 2025 | 09:18 AM
rgrass917's Avatar
rgrass917
5th Gear
Default Headlight issue
My 04 c5 has an issue with the headlight on the left. It comes up OK but when I turn it off it flips up and down several times then will not close completely.
Old Jun 26, 2025 | 12:11 PM
Probably the gear inside the motor has failed. A search (in either C5 Gen or C5 Tech) should yield some last discussions on this topic.
Moving this to C5 Tech.
Old Aug 14, 2025 | 04:42 PM
richard emmanuel's Avatar
richard emmanuel
mine did the same thing. was the white chicklet tabs worn out
To Headlight issue
