Help... Car almost stalling
Old Oct 30, 2003 | 06:53 PM
Bat Boy99's Avatar
Bat Boy99
Default Help... Car almost stalling
As of late my has been recently showing me the check engine light but this is not the true problem.
Whether the car is in gear or out of gear the cars rpms drop from 800-900 rps to about 300 rmps as I am comming to a stop. SWometimes the car maintains that low of an idle till I "pop" the gas to bump the idle back up to the 800ish range. This does not happen at every stop or slow down, but is starting to get real annoying. This same thing happend to my old Mustang. Any help would be great.
Old Oct 30, 2003 | 07:20 PM
Steve02C5's Avatar
Steve02C5
From: Renaissance Festival TAZ the Wolfdog (R.I.P.)
Default Re: Help... Car almost stalling (Bat Boy99)
Are there any DTC's, if so, what are they?
Your symptoms could be a bad MAF or IAC, to name a few.
[Modified by Steve02C5, 6:27 PM 10/30/2003]
Old Oct 30, 2003 | 07:52 PM
NICEDRV's Avatar
NICEDRV
Default Re: Help... Car almost stalling (Steve02C5)
I had the same problem after I installed a new head/cam and program. The program had to be reinstalled and now it is ok.
Old Oct 30, 2003 | 09:59 PM
Bat Boy99's Avatar
Bat Boy99
Default Re: Help... Car almost stalling (NICEDRV)
I do not have the ability to see if any DTC's are coming up and my car is mostly stock. I did install an aftermarket Mass Air Sensor. I am obviously trying to avoid taking my car in order to have a diagnostic test done on it to see what codes are coming up. However, I may have no choice.
Old Oct 30, 2003 | 10:02 PM
Old Rotor Head's Avatar
Old Rotor Head
I find if I drive in traffic for a few days I get the same thing. I blow it out and I'm fine. :rofl:
Old Oct 30, 2003 | 10:44 PM
99C5ragtop's Avatar
99C5ragtop
Try the relearn procedure....check the tech section....definitely to do with the new MAF....Computer has to relearn the idle characteristics for the increase air from the MAF...mine still does ot from time to time but infrequently after I did the relearn.
MM
Old Oct 30, 2003 | 11:05 PM
Steve02C5's Avatar
Steve02C5
Why can't you get the DTC's off the DIC? What am I missing here??
Old Oct 30, 2003 | 11:54 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
:iagree: I'm with Steve! Retreiving the codea on yoir C% is a SNAP andd it is FREE!!! It should take you all of 2 minutes and you do not even need to leave the drivers seat! :thumbs:
Look in the TECH section fro the procedure and the codes.
Bill C
Old Oct 31, 2003 | 11:52 AM
boost2much's Avatar
boost2much
Default Re: Help... Car almost stalling (Bill Curlee)
With the key in the on position but not started, hold down options and press fuel 4 times. It will then cycle through all your codes or you can go into manual mode but I forgot which button does what. :cheers:
To Help... Car almost stalling
