header gaskets , which work best?
Old Jan 23, 2004 | 07:18 PM
vettemaster1's Avatar
vettemaster1
Default header gaskets , which work best?
in the process of installing headers, i like the steel factory gasket, but the headers came with fiber gasket. any one have any input as to which is less likely to leak? thanks!! :smash: :confused: :seeya :auto:
Old Jan 23, 2004 | 07:21 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
Default Re: header gaskets , which work best? (vettemaster1)
stock!!! :hat
Old Jan 23, 2004 | 07:45 PM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
I'm using the stock ones without any problems :yesnod:
Old Jan 23, 2004 | 07:54 PM
hotrodhoodlum's Avatar
hotrodhoodlum
8th Gear
Default Re: header gaskets , which work best? (Flyin'Brian)
do not use the fiber unless you like changing header gaskets, go with new stock or fel-pro,, have metal to help prevent blow out,, and almost nothin sounds worse than a heade tick ona vette, or any other nice ride
Old Jan 23, 2004 | 07:56 PM
Scubanme's Avatar
Scubanme
Stock gaskets are best, but you might need to do some matching of the ports.
nothing a little elbow grease and a round file can't take care of.
:thumbs:
Old Jan 23, 2004 | 08:02 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Default Re: header gaskets , which work best? (Scubanme)
Crap my Kooks came with fiber gaskets and that's what I used. Will I have any problems?
Old Jan 24, 2004 | 01:00 AM
alc2001's Avatar
alc2001
I used the fiber gasket that came with my FLP's and it's leak free after 8k. I believe that the fiber gaskets work better with the header flange surface than the steel gaskets which are intended for a machined, true flat surface of the stock cast headers. I think the fiber gasket is actually stock for 2000 and older which are welded tube/flange construction.
[Modified by alc2001, 10:01 PM 1/23/2004]
Old Jan 24, 2004 | 02:27 AM
lowdowndirty's Avatar
lowdowndirty
Default Re: header gaskets , which work best? (alc2001)
:withstupid: This is not true. Steels gaskets are factory parts on the ones I've seen.
Old Jan 24, 2004 | 03:11 AM
Cobra4B's Avatar
Cobra4B
ttt
Old Jan 24, 2004 | 03:43 AM
molon labe's Avatar
molon labe
i used the factory steel gaskets and have about 5k miles with no problems. :)
Old Jan 24, 2004 | 11:47 AM
Flyin'Brian
Cruise-In I Veteran
Not true :nonod:
My stock 2000 gaskets are metal
Old Jan 24, 2004 | 01:58 PM
corvettebob1's Avatar
corvettebob1
I've used both in the past with headers and found they both work in fact in the old days only the fiber gaskets worked with headers. :crazy:
Thats where MR. Gasket was born! :D
The key is to re-torque them after a few heat cycles. :cheers:
And my 98 came with sandwich steel gaskets.... :yesnod:
Old Jan 24, 2004 | 02:11 PM
vettemaster1
thanks for all the input! :thumbs: after looking at the header flange and both the steel and fibre gaskets very carefully, i installed the steel ones. i seem to remember having to change the fiber ones in days gone by, fairly often, no matter how often i tightened the bolts. i guess time will tell. once again thanks for the input! ;) :steering:
To header gaskets , which work best?
