Electrical Help...Please!
Old Mar 27, 2004 | 03:28 PM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
Default Electrical Help...Please!
Well, it looks like my stock battery is gone after 20 months. Fortunately it died at 21st Century Musclecars, and the guys stopped what they were doing until they could diagnose, then gave me a jump to get me home. One the way home I noticed that my temp gauge, both analog and on the DIC were dead. Furthermore, when I parked and tried to pop the trunk, the switch is dead.
Question: Is there a common fuse for both that we may have blown while trying to start my car (several times) on the charger and then via a jump of another vehicle? Good news is I am home...But this sucks!!! :mad
Old Mar 27, 2004 | 03:48 PM
rwj383's Avatar
rwj383
Default Re: Electrical Help...Please! (C5 StockSwap)
before you spend any time looking through all your fuses, simply disconnect your battery for a few minutes then reconnect. This should restore your problem to normal. If not, you may need to clear all historical codes through your DIC control panel buttons.
Old Mar 27, 2004 | 03:55 PM
C5 StockSwap
Cruise-In V Veteran
Default Re: Electrical Help...Please! (rwj383)
Will Do! FYI...don't know if it just because it has been on the Battery Tender Plus for a few minutes, but the trunk lid will pop now. As for the gauge problem, I'll try the disconnect and see what happens.
Old Mar 28, 2004 | 10:37 AM
C5 StockSwap
Cruise-In V Veteran
Final chapter of story...
Took my OEM battery to Auto Zone this morning for a test after a full night on the Battery Tender Plus. Battery showed a full charge, but only able to output 6 amps! Message on the testing device was "Remove From Service".
I guess these batteries really do die a sudden death. I've never experienced something quite like that with any previous battery. Put an Optima Red Top in today, and everything is back to normal after pulling and replacing the #16 and #23 fuses, then doing a 5 minute idle relearn. I should now in a few days whether it was truly just the battery, or if I have other electrical issues. :eek:
Old Mar 28, 2004 | 01:00 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
WOW! :eek: Glad that everything worked out for you!!My 98 is enjoying the Optima Red now too!! :thumbs: :thumbs:
Bill
To Electrical Help...Please!
