Stock shifter question...
Old Jul 8, 2004 | 10:49 PM
nuke61's Avatar
nuke61
Default Stock shifter question...
I've lost the bent pin that attaches to the front of the stock shifter. What's that thing for, and is it O.K. to reinstall without it?
Old Jul 9, 2004 | 09:05 AM
nuke61's Avatar
nuke61
Ttt
Old Jul 10, 2004 | 12:48 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Ahh the bent pin! It is installed to allow you to align the shift linkage to nuteral. In front of the shifter housing is a place to install the pin. If your trans is in TRUE nuteral and the shifter or linkage is in TRUE nuteral the pin should slip right into the hole! You should be able to use a drill bit. If you neeed the proper diameter of the pin I can measure mine and provide it.
BC
Old Jul 14, 2004 | 09:04 PM
nuke61's Avatar
nuke61
Thanks Bill. I just used an old L shaped allen wrench that I ground a bit.
Old Jul 14, 2004 | 09:34 PM
Blkout's Avatar
Blkout
Wonder why the Hurst shifters don't use the pin......
Anyone know?
Old Jul 14, 2004 | 10:44 PM
LoneStarFRC's Avatar
LoneStarFRC
I think a 1/8" drill bit will work too if memory serves. As I recall the pin is only used to lock the shifter while performing a shift shaft adjusment procedure. HTH
Robert
Old Jul 15, 2004 | 09:31 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
That is CORRECT!! The pin does not have anything to do with the Hurst shifter. The pin slips into a small hole in front of the housing that the Hurst shifter mounts to! The shift linkage protrudes out of the front of that housing. The pin goes in to that portion of the housing.
BC
Old Jul 15, 2004 | 10:37 PM
LoneStarFRC
FWIW,
I also found that this little hole served as a convenient place to put a little additional lube to help lubricate the front part of the shifter "rail" going through the housing. I then put a small dab of silicone on the hole to prevent any dirt, etc from getting in.
Robert
Old Jul 16, 2004 | 09:53 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Man,,, I did the same thing! Great minds think alike!!
Bill C
To Stock shifter question...
