Tranny is trashed - need advise
Old Jul 15, 2004 | 01:00 PM
tcarroll's Avatar
tcarroll
Default Tranny is trashed - need advise
The six speed in my '97 has the following issues as diagnosed by a close friend who does the Vette repairs for a local Chevy dealer: the fifth & sixth shift rails and forks need to be replaced. GM Tech Center also recommends replacing the fourth gear rail, forks and synchro assembly due to an inherent weakness. The options to this point are to rebuild or secure a rebuilt. Cost range including labor is $2,700 to $4,000.
The tech friend suggested going on the internet to see if any of you have any ideas as to what can be done. Obviously, it has to be repaired, but before I drop that kind of money, I want to be sure all options have been explored.
Thanks, in advance, for any input that can be provided.
Old Jul 15, 2004 | 02:25 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Call Rodney at Transmission specialists. He has done many trans for us as well as many forum members here..
765-529-9919
__________________
Home of the Fastest Supercharged C5 8.4 @ 158mph
Home of the Fastest Supercharged IRS GTO 9.0@ 155
Home of the Fastest Supercharged C6 9.7 @ 143mph
Proud Sponsor of the ECS Corvette Challenge
http://www.corvettechallenge.info
609-752-0321
Old Jul 19, 2004 | 03:14 PM
tcarroll's Avatar
tcarroll
Thanks, Chris. Will do.
Old Jul 19, 2004 | 03:18 PM
yel01z06's Avatar
yel01z06
3rd Gear
check some of the forums i saw someone selling one for around 1400.00 complete
Old Jul 19, 2004 | 03:26 PM
Dave68's Avatar
Dave68
How many miles do you have on the tranny? Were they hard, easy, or somewhere in between miles?
Old Jul 19, 2004 | 03:49 PM
NEPTUNEBILL's Avatar
NEPTUNEBILL
listen to Chris and call Rodney--and your trans problems are over for way less money--he also uses steel forks like the ones in the Viper version of the tranny that will not break---all the better drag guys on the forum are running his tranny-I couldn't be happier with mine and I traded mine in with him when there was nothing wrong with it just to save having to do it later---its a good time to think about a good clutch as well a lot less labor while replacing the tranny---exedy single disk should suit your needs perfectly and unless you add several hundred hp its the last clutch you will ever need---
Old Jul 19, 2004 | 06:38 PM
kirbyloid's Avatar
kirbyloid
Default tranny
Rodney "crashed94" is The best and you cannot find a better person, he will do you right and loves corvettes. If you need any contact information email me.
Kirby
Old Jul 20, 2004 | 03:40 AM
leaftye's Avatar
leaftye
Or rebuild the tranny yourself: http://www.ls2.com/forums/showthread...threadid=30484
Old Jul 20, 2004 | 03:04 PM
tcarroll's Avatar
tcarroll
38,000 miles. About a thousand of those were mine. I know the previous owner. He did not abuse the car.
Old Jul 20, 2004 | 03:06 PM
tcarroll's Avatar
tcarroll
I am working on getting with him now. Do you mind giving me an idea of what you spent on the tranny? Thanks.
To Tranny is trashed - need advise
