Replace brake bolts?
Old Oct 20, 2004 | 05:14 PM
TVSKIP's Avatar
TVSKIP
Default Replace brake bolts?
Do I really need to replace my caliper pin bolts and caliper bracket mounting bolts per GM manual or is this just a liability issue with GM to make sure that threadlocker is used. If there is a technical reason to replace them then I don't mind, or can I can safely re-locktite and reuse the bolts. SAFELY being the key word here!!
Old Oct 20, 2004 | 05:17 PM
Patches's Avatar
Patches
To be safe, replace them but a lot of us here loctite them and reuse them.
How's that?
Old Oct 20, 2004 | 05:18 PM
VetteDrmr's Avatar
VetteDrmr
You can reuse them. They're not torque-to-yield bolts, and I've reused brake caliper and bracket bolts since the beginning of time (which is when my son thinks I was born).
I just clean them up and use red loctite.
HTH, and have a good one,
Mike
AU N EGL's Avatar
AU N EGL
No - GM just wants to make $10 a bolt from you thats all. Clean the threads off - use the red auto locktite and torque to 125. You age good to go then.
Old Oct 20, 2004 | 05:37 PM
vettenuts's Avatar
vettenuts
Mike
I replaced my first set so I could have a spare set, but generally I do just clean and re-loctite. Make sure to clean the bolts and the female threads as well.
Old Oct 20, 2004 | 06:17 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
I have reused them for 5 years and many swaps with countless pads used in track events.
Old Oct 20, 2004 | 06:29 PM
Ls1Rat's Avatar
Ls1Rat
no
Old Oct 20, 2004 | 10:42 PM
TVSKIP's Avatar
TVSKIP
Thanks to all who replied As always, this forum rocks..... I'll clean the bolts and inner theads properly and use locktite as I planned, but I wanted to get the opinion of the CORVETTE brotherhood just to make sure.... Again, Thanks to all.....SAVE THE WAVE!
Old Oct 21, 2004 | 01:18 AM
Richin Chicago's Avatar
Richin Chicago
OOPS! I think he said the caliper pin bolts which are the 15mm wrench size bolts that are only torqued to 23 ft lbs. And the bracket bolts which are the 21mm bolts and are torqued at 125 ft lbs.
Old Oct 21, 2004 | 09:21 AM
gtzy's Avatar
gtzy
Steel fasteners [bolts] that are used with aluminum componets often have a coating that prevents a chemical reaction between the 2 different metals.When the fastener is removed this coating is compromised.GM replacement requirement may be related to that issue rather than stress failure of bolt.
Old Oct 21, 2004 | 11:37 AM
TVSKIP's Avatar
TVSKIP
Good point. Thanks again.
To Replace brake bolts?
