04 Feul Filters
Old Nov 16, 2004 | 01:12 AM
Dirty Howie's Avatar
Dirty Howie
Default 04 Feul Filters
I was looking in the Midwest catalogue and saw inline feul filters for all C5's including the 04. I was going to order one but was told by someone that the filter in the 04 filter is actually in the feul tank.....is this correct? And it will only cost $1000 to change it.
Old Nov 16, 2004 | 01:19 AM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
Thats correct. The fuel filter is located in the gas tank. I don't plan to service it for quite awhile as long as I continue to use quality gas from reputable dealers.
Old Nov 16, 2004 | 01:30 AM
Rattler71's Avatar
Rattler71
Did they move it in the 2004 models from its usual location at the frame by the left rear wheel?
Scott
Old Nov 16, 2004 | 01:33 AM
Dirty Howie
Thats unbelievable...I'm glad they didn't put the oil filter in the middle of the engine block
BTW: nice taste in vettes!
Old Nov 16, 2004 | 10:35 AM
gst20psi's Avatar
gst20psi
The 04 filter is in the same location as the 97-98 vettes, on the frame up near the drivers side wheel well as said by Rattler71. I know this because I have some 04 filters left over, so if you need one let me know. The differnce between the 97-98 and the 99-04 is that the 99-04 filters have the regulator built into the filter and that makes them more $ then the 97- 98 . Hope that helps you
Old Nov 16, 2004 | 11:11 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
AMSOIL sells the fuel filter element (among other things). I've changed out mine on my 02 Z06 and it is a piece of cake if you have the fuel line separator tool (which can be bought at any auto parts store for a couple of bucks).
AMSOIL part numbers:
2004 CHEVROLET CORVETTE 5.7L 8-cyl VIN Code G
FILTERS
Oil Filter......SDF32
Oil Vapor Filter......N/R
Air Filter......TS83
Fuel Filter......GF336
Fuel Vapor Filter......N/R
PCV Valve......HV199
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Nov 16, 2004 | 11:45 PM
gmosley's Avatar
gmosley
Default fuel filter
fuel pump is in gas tank
filter should be on the framerail
Old Nov 19, 2004 | 05:12 AM
vettenuts's Avatar
vettenuts
According to a write-up by Hib Halverson, the fuel filter was moved from the frame to the inside of the tank in the mid-2003 production year. It remains there today in the C6.
Old Nov 19, 2004 | 08:31 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
The fuel filter on the new 2003-04 FFS system is an integral part of the left fuel sender and it is not servicable short of replacing the fuel sender,which requires removing the trans and rear differential to remove the fuel tank (unless you know the tricks of course )
Old Nov 19, 2004 | 09:11 PM
Dirty Howie
Well boys one half of you say its on the frame well the other half say its inside the tank and not servicable.
My local dealer says its accessable and has one on hold for me that I am supposed to pick up tomarrow!!!!
Old Nov 20, 2004 | 01:30 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
As per the 2003-04 service manual:
"The fuel filter is contained in the fuel sender assembly inside the left fuel tank. The paper filter element of the fuel filter traps particles in the fuel that may damage the fuel injection system. The fuel filter housing is made to withstand maximum fuel system pressure, exposure to fuel additives, and changes in temperature. There is no service interval for fuel filter replacement."
Good luck
Old Nov 20, 2004 | 01:32 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Old Nov 20, 2004 | 02:29 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
(1) Fuel Fill Hose
(2) Left Fuel Tank Grade Vent Valve
(3) Fuel Feed Pipe to Engine
(4) 5/16 Inch Auxiliary Fuel Feed Pipe
(5) 3/8 Inch Auxiliary Fuel Return Pipe
(6) Right Fuel Tank Grade Vent Valve
(7) Fill Limiter Vent Valve (FLVV)
(8) Secondary Fuel Pressure Regulator
(9) Siphon Jet Pump
(10) Convoluted Crossover Hose
(11) Anti-siphon Hole
(12) Fuel Sender Reservoir
(13) Turbine Fuel Pump
(14) Venturi Pump
(15) Primary Fuel Pressure Regulator
(16) Reverse Flow Check Valve
(17) Fuel Filter
Old Nov 20, 2004 | 06:59 PM
vettenuts's Avatar
vettenuts
Think you better find a new dealer, they should have known about this as there have been many who have complained about it.
Old Nov 21, 2004 | 12:45 AM
Dirty Howie
Originally Posted by C-5 TECH
(1) Fuel Fill Hose
(9) Siphon Jet Pump
(14) Venturi Pump
(17) Fuel Filter
I am no mechanic but it sure looks like the filter is in the tank!!!!!!!!
Thanks for the definative answer.......glad I didn't pay for it
To 04 Feul Filters
