Do a search. Someone posted this. It involves connecting the purple ?foglight wire (at the foglight switch) to the high beam circuit, all done inside the car at the dash.
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
well, it has been for me. I would like to use the fog lamp circuitry for some aux. lighting, however, the fog lamp circuit goes dead when the high beams are activated.
The seach feature blows, do a google search you'll get better results, someone sells a box that does this and it keeps all 6 lights on at the same time. No need to splice wires just clips on to the existing wires and zips ties to the kick panel. Sorry I have no more info, and no time to search for you, good luck.
I came across this thread by accident, but you'll find exactly what you need to know right here
Let me know if you have any questions
: Mark,
Just this morning, I found the wiring diagrams that you sent me regarding both Highs and lowbeams working with the foglights. Was trying to show someone how they work last month and (naturally,) they didn't work. Figured that I needed to troubleshoot it soon but had to find the diagram. Was REALLY cool when they worked though!
