Rear end ratios-Comments please
Old Jan 17, 2005 | 08:58 PM
claysmoker's Avatar
claysmoker
St. Jude Donor '09-'11-'12-'13-'14
Default Rear end ratios-Comments please
The kid is thinking about a lower rear end ratio for his 6 speed '01. Anyone had any experience with 4.10, 4.56, and 4.88 ratios or something close? He wants an off the line rocket with reasonable rpm in top gear. He's done the calc's and even the 88's don't look too bad.
Any comments welcome...Dad.
Old Jan 17, 2005 | 09:10 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Tell Jr. that he only has two choices..
3.90's (what I went with) and 4.10's
Nothing lower available.
Many folks have been happy with either choice.. Good luck.
Old Jan 17, 2005 | 09:39 PM
DragMan's Avatar
DragMan
Cruise-In VII Veteran
I have A4 and put in 3.73 & wished I had went with 4.10s.
Old Jan 17, 2005 | 09:42 PM
claysmoker's Avatar
claysmoker
Thanks for the info. The 56's and 88's go back to my 55 Chevy in 1966,(oh, how I wish I still had that car).
Old Jan 17, 2005 | 10:24 PM
Cap'n Pete's Avatar
Cap'n Pete
I put 4.10's into my LS1 Z28 with an A4, so I'm sure they would be the right gear to use with a 6-speed, considering 6th gear is like "double over-drive".
I know that lower ratios (at least to 4.56) are available for standard GM 10-bolt and 12-bolt rear ends, but I never knew that 4.10 was the lowest for a C5?? ...guess ya learn something new everyday?
Old Jan 18, 2005 | 04:14 AM
fdxpilot's Avatar
fdxpilot
Yeah, it's a totally different rear end (Gertrag), so the gears are unique. I have heard that DTE is working on some higher ratios (like 4.33)
Old Jan 18, 2005 | 04:39 AM
2002Z06Yellow's Avatar
2002Z06Yellow
4.10s already put a lot of stress on the car. anything lower and the car will face reliability issues IMO
Old Jan 18, 2005 | 11:02 AM
Tree's Avatar
Tree
Could you elaborate? Besides increasing the engine speed for a given MPH, what other stresses should I be considering?
Old Jan 18, 2005 | 11:25 AM
ThissenW's Avatar
ThissenW
I have 4.10s in my 6-spd Vert. They make a major difference in the car's acceleration and handling. My Vert is lightly-modified (340 rear-wheel HP), and I can break the stock tires loose by mashing the gas on a roll in 1st. I think if I were doing it again, I'd go with the 3.90s.
Alll in all, a worthwhile mod.
Old Jan 18, 2005 | 03:12 PM
2002Z06Yellow
I dont pretend to be an expert so someone might help me out here. But i think there are less teeth on this gear. thus the pressure will be divided will be higher on each one.
Old Jan 18, 2005 | 03:36 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
It's not so much the 4:10's as what you'd do after you had the 4:10's.
Obviously, with that sort of a gear, you'd go racing where you'd quiickly find out that you didn't have any traction, so you'd put slicks or drag radial on the car to get the traction back, right?
So what you'd do is effectively increase the amount of torque going to the rear wheels during your start. That increase in torque wouldn't be able to relieve the stress by spinning the tires, so the stress would go to the next weakest part of your drivetrain, my guess would be the universal joints, but that's just a guess.
There's always going to be some part that's the weakest link and whenever you increase the stress, that's where it's going to go. Generally it's the tires but if you do something to increase traction, it's going to be something else. That's why race cars use things like driveshaft safety loops, transmission scatter shields and such. Somethings gotta give!
Old Jan 19, 2005 | 12:04 AM
Dan_the_C5_Man
Just look through all the posts where the damn diff separated from the back of the transmission!
Those lower ratios reduce the diff assembly's torque-handling capabilities.
Frankly, I'd be surprised that DTE would peruse even lower ratios, given the failures they've already seen.. Maybe they are "playing the odds".
3.90's are more than enough for me.
Old Jan 19, 2005 | 12:40 AM
7.0sc SuperVette's Avatar
7.0sc SuperVette
From: Sunny Earthquake Country, USA On the Left Coast (which is becoming more Right!)
Default I'm a product of the '50's...
In 1962, I had a 1956 Austin Healy with a '62 fuely short block, boggin' quads and I spliced in a Chev 4.56 punkin into the full floating Healy axle and somehow that seemed appropriate at the time!
Now I couldn't imagine a 4.56/4.88 in my C5. I have a big engine and my 3.90 seems just perfect!
Roy
Old Jan 19, 2005 | 01:02 AM
Speedway's Avatar
Speedway
Junior chiming in....
Finding a qualified mechanic to do the swap could be tough.....anyone know of a reputable shop in the greater Reno, Nevada area?
Thanks in advance.
Old Jan 19, 2005 | 02:11 AM
Tsab's Avatar
Tsab
If you are going to "track" the car then go with 4:10's. If not then 3:90's will be fine. Just remember to follow the proper break in proceedures for the gears.
Old Jan 19, 2005 | 04:28 AM
7.0sc SuperVette
Default Pressure on teeth...
With fewer teeth, the contact area (transmitting the torque) will be snaller, i.e. the equivalent of say 1 3/4 teeth in contact instead of say 2 1/4 teeth in contact to transmit the load and in a given housing size the pinion will have a smaller pitch dia. resulting in higher stress on the tooth in bending and contact stress. So you are correct!
Roy
Old Jan 19, 2005 | 02:24 PM
Antivenom 447's Avatar
Antivenom 447
I was told the same thing more or less. The ring is the same size but the pinion shaft has less teeth changing the ratio and of course taking more stress on a smaller shaft. I was told the reliability was markedly decreased with high HP/TQ cars and of course if you have good traction. I wanted to go with a different ratio and was talked out of it right away. Hope this helps......
To Rear end ratios-Comments please
Old Jan 19, 2005 | 08:44 PM
vettemaster1's Avatar
vettemaster1
4.10 w/ a4 here...about 375 rwhp.....they ROCK!!!!....you can break anything if you try....the 4.10 are VERY reliable....the gears are not breaking..the output shafts are...[ trans and diff]....
Old Jan 20, 2005 | 12:37 PM
2KREDVert's Avatar
2KREDVert
Did you do a High Stall Converter too?
Old Jan 20, 2005 | 12:59 PM
vettemaster1
my 4.10 a4 is a daily driver that i autocross twice a month....i kept the stock converter to keep the driveabilty as close to stock as possible...it works great!...normal in town driving is sweet as can be, raving on it is way FUN!!!!!!!!
