2006 automatic/ performance axle
Old Aug 6, 2005 | 08:22 AM
Need 4 Speed's Avatar
Need 4 Speed
The A6 should get better gas mileage and you won't notice any change in speed unless on the clock.
Old Aug 6, 2005 | 08:55 AM
ProfMoriarty's Avatar
ProfMoriarty
I saw the GM graph that showed 2% slower 0-60 times for the A6 v. the A5/3.15 but it's not borne out by the math.
I wonder how they derived the graph?
2.56x6L80E = 10.31, 6.05, 3.92, 2.95, 2.18, 1.71
3.15 x4L65E = 9.64, 5.13, 3.15, 2.21
Old Aug 6, 2005 | 09:14 AM
Curtis A. Franz's Avatar
Curtis A. Franz
Originally Posted by ProfMoriarty
I saw the GM graph that showed 2% slower 0-60 times for the A6 v. the A4/3.15 but it's not borne out by the math.
I too wonder where that came from. My guess would be that the A6 requires one more shift in the 0-60 dash. What do you think about that, Sir Doyle's evil one?
Old Aug 6, 2005 | 09:17 AM
ProfMoriarty
Got me.
I'm still pissed off about Reichenbach Falls!
Old Aug 6, 2005 | 11:25 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Prof-
I started a thread "New A6 Speeds in Gears", please take a look and post your opinions.
Hopefully, my disappointment will be incorrect.
Old Aug 7, 2005 | 01:43 PM
TRJ's Avatar
TRJ
Originally Posted by LS WON
I'm glad I got an 05 C-6 with 4 spd. auto which is a heavier duty version 4L65LEof a tried and true transmission with 3.15 gears.
LS WON, In an earlier post by someone, they read an excerpt from an article in the Corvette Quarterly "Special Edition" on the "05 C6 Auto." What was said was that the '05 A4 Auto. Trans. in this heavier duty version, was capable of handling up to 620 lbs. ft. of torque. I personally have not read the article, but would like to. Would anyone be able to scan & post the article, or even type out the exact wording from the article?? I think that they said it was on page 120 of the "Special Edition" of the magazine. Thanks much...
Old Aug 7, 2005 | 01:49 PM
2000 green hornet's Avatar
2000 green hornet
Default Goofy Graph
I wondered too. This A6 may fly with the best if it is designed and programmed right .
Standard transmissions will become ever rarer in the future. Many young people can't even drive them anymore .
Even trucks have mostly automatics now .
Old Aug 7, 2005 | 02:14 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
more parts,more weight,like a heavier flywheel, in the trans means more rotational mass which equals slower accelertion. that is why a THM 350 is quicker then a THM 400 at the drags. this is the reason that GM did not use a dual mass flywheel in the C-6s to quiet down the "gear rattle" problem found in the C-5 because it would cost .2 in the 0-60 times because of the extra weight
Old Aug 7, 2005 | 03:13 PM
StrayDog's Avatar
StrayDog
Veteran: Marine Corps
with big Jim the 6 speed tranny is /will be an improvement over the A4,lower ratios out of the hole>>> you guys probably complained when the power glide was done away with in 67/68 for the 3 speed auto>>>..wait a minute you were on big wheels at the time, a 6 speed auto is in my future & if i need a 4 speed to prove im a man i will take my 66 B/B out for a spin my legs are tired but not my thumbs paddle shifters here I come Yahoooo & Woof 2 cents from the old dog>>>> QUOTE=Big Jimm]I think the new tranny is ABSOLUTELY EXCELLENT!!
I like the new low - and high - ratios and think the paddle shift is just right! Having driven MANY stick shifts in the past, I'll bet that, with the operation of this new tranny, stick shift buyers in the future will dwindle fast.
And, that there will be a lot of 05 stick AND auto trade-ins to get the new A6.
Also - 1250 is a VERY fair price! (Unlike the chrome wheels @1995.)
Big Jimm
So. Fla.[/QUOTE]
Old Aug 7, 2005 | 03:47 PM
2000 green hornet
Default Neat Presentation
Big Jimm
So. Fla.
[/QUOTE]
I love the presentation. Neato eye candy . But I too wonder why somebody would want less gears in an automatic. Fluid clutch and dynaflow way back when only had 1 gear , and they were terribly slow off the line . 2 speed Powerglide might be great for the dragstrip where the power is awsome, but it was mighty feeble driving down Muholland Road .
Old Aug 7, 2005 | 04:47 PM
1966 327's Avatar
1966 327
I' m sure I'm alone but I'm sure glad I bought a Mag Red, A4 2005
Old Aug 7, 2005 | 05:22 PM
Deep Silver C6 Z51's Avatar
Deep Silver C6 Z51
I'm with you.
I'm sure the A6 will be great but I am really happy with the performance of the A4 Z51 that I already own.
Old Aug 7, 2005 | 05:32 PM
  #33
Curtis A. Franz
here is the original GM Powertrain announcement of building a 6 speed automatic. It is the reference that made me wait for the actual tranny to be made rather than buying a 2005. The Caddy announcement said that all the shifts above the 1-2 shift were clutch to clutch. I am going to have to research that some more. I added the italics to emphasize the claimed advantages.
Hydra-Matic 6-Speed Automatic TransmissionsDelivering performance and fuel economy benefits
Overview:
Several 6-speed variants will be featured in GM vehicles worldwide.
The first 6-speed will debut in 2005 (applications to be announced at a later date)
New Technologies:
Clutch-to-clutch
Controls characterization
TEHCM – Transmission Electro/Hydraulic Controls Module
Shift-by-wire (ETRS)
Features:
Neutral idle
Automatic grade braking
Driver Shift Control (DSC)
Enhanced Performance Algorithm Shifting (PAS II)
Next-generation tow/haul mode
Benefits:
Fuel economy
Performance
Premium shift quality and driveability
Old Aug 7, 2005 | 05:42 PM
  #34
Curtis A. Franz
Default clutch to clutch shifting
Here is a 2004 GM description of this "advance" to be used in the 6 speed transmission:
CLUTCH-TO-CLUTCH SHIFT CONTROL SYSTEM
This innovation consists of groundbreaking control logic and the hydraulic hardware necessary to control clutch-to-clutch transmissions with world-class shift quality. These methods enable five- and six-speed transmissions to be integrated with various engines and platform combinations with significantly reduced calibration effort. Included is FAST Learn, an algorithm that compensates for initial build variation, allowing the control logic to deliver excellent shift quality right out of the vehicle assembly plant and over the life of the transmission through adaptive learning. The control logic with reduced calibration effort minimizes development cost, time, and improves overall quality.
It makes it sound like the advantages are for manufacturing variations and a way to make the shifts consistent. Does that relate to better performance? Boy I don't know. Performance of course means "faster" to us Y body people.
Old Aug 7, 2005 | 05:45 PM
  #35
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
Same here but mine is LMB
Old Aug 7, 2005 | 05:53 PM
  #36
Curtis A. Franz
Default More Clutch-to clutch info
this review of the dual input shaft and clutch-to clutch makes is sound like there are performance gains with a clutch-to-clutch transmissions.
Dual Input Clutch, Layshaft Automatic Transmission (DCT)
The DCT is basically two transmissions in one case, one with gears 1, 3, and 5 and one with gears 2, 4, and 6. Clutch-to-clutch shifting enables the transmission to shift under power, eliminating the torque interruption that is characteristic of many automated manual transmission systems. Like an automated manual system, the DCT uses engine control to optimize feel and has both automatic and manual (shifting) operation modes that can be selected at any time.
Benefits of this system include fuel economy as good as or better than a manual, maintaining the feel and function of an automatic, a layshaft configuration that permits flexibility in designing gear ratios for optimum fuel economy and performance of different vehicles, being well-suited to high power engine applications, and being well-suited for integration of electric motors for hybrid applications.
Old Aug 7, 2005 | 08:54 PM
  #37
tbob's Avatar
tbob
The new A6 tranny sounds alot like the auto in the Audi TT released last year, same clutch to clutch tech. Read the review from Car and Driver:
http://www.caranddriver.com/article....&page_number=1
To 2006 automatic/ performance axle
Old Aug 8, 2005 | 12:56 AM
  #38
LS WON's Avatar
LS WON
Default Please bear with me as I'm having computer problems I will look into this.
This special issue of Corvette Quarterly does it come in the mail to the regular subscribers like myself or do you have to purchase frrom a newsstand. In any event do you know what is on the cover of this special edition magazine so that I can identifiy it easier and faster.
Old Aug 8, 2005 | 12:58 AM
  #39
LS WON's Avatar
LS WON
Default ok howabout this? Which ever transmission will give me better acceleration 0-60 time
with less problems and perhaps better gas mileage if that is possible is the winner.
Old Aug 8, 2005 | 01:17 AM
  #40
shopdog's Avatar
shopdog
Except that the GM A6 still has a torque converter.
