C6 Skip Shift Eliminator
Old Aug 4, 2008 | 05:48 PM
  #161
KBoltz's Avatar
KBoltz
Mine's installed and I love it. My light has not come on at all - even though I shifted from 1st to second at 5mph - no complaints.
Damn thing drove me nuts.
Old Aug 5, 2008 | 08:11 AM
  #162
southerncarparts's Avatar
southerncarparts
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
Originally Posted by rjwoerheide
It isn't about "knowing how to drive a manual properly," or about "driving it like it's a vette." The CAGS thing is annoying because it prevents you from shifting how YOU want. Which is exactly the point of a manual transmission. I don't want to be forced to lug my engine along in fourth gear at 15 miles an hour, or accelerate past the threshold to coax the computer into letting me shift to second.
This is an essential mod in my book. I find CAGS to be distracting and even dangerous.
100% agree with you!!!
Thanks,
Jim
Old Aug 29, 2008 | 07:36 PM
  #163
NTMD8R's Avatar
NTMD8R
Default Won't Fit
Well, I tried to install mine (from SouthernCarParts)....
But.. the "plug" end (which dummies into the transmission receptor)
will NOT fit.
Looking at the harness end which I disconnected,
(first.. it is purple and not white as the instructions read)...
it is quite a bit smaller than the white "dummy" connector provided.
And it has 3 holes in it... whereas the "dummy" connector only has 2 holes.
Clearly this will NOT fit into the transmission receptor.
Are there different models of this "Skip Shift Eliminator" ?
Update: DUH !!!!!!!
Put it in the Upper connector... not the Lower one..... (Dumb me).
It fits just fine.
Old Aug 29, 2008 | 08:10 PM
  #164
Mark Ducati's Avatar
Mark Ducati
1) Do you need to get under the car at all or is this a no brainer?
You dont need "Jacks" per se... do what I'm going to do, I'm using my son's local DayCare (or any other office building) with a handicap access sidewalk off their driveway. Back the car's back left wheel up over the driveway onto the natural handicap ramp until its up another 4-6"... install, then drive back forward when done.
Easy! I did my C5 that way.
Old Aug 29, 2008 | 10:38 PM
  #165
NTMD8R's Avatar
NTMD8R
Updated... my Stupid.
It goes in the Upper connection; not the Lower one.
Duh !!!!
Old Oct 29, 2008 | 10:30 PM
  #166
onehdeagle's Avatar
onehdeagle
Originally Posted by starbelly
Guess I just drive too fast... light never comes on for me... but then again I drive like I stole the thing!
Same here, never saw the light, nor had a problem shifting.
Do people actually buy a high performance sports car,to shift it at a 1000 or less RPM, or whatever it takes to turn on the light, and make you skip shift?
Old Nov 6, 2008 | 06:22 PM
  #167
tomZ51's Avatar
tomZ51
just ordered mine, looking forward to installing it!
Old Nov 18, 2008 | 01:46 PM
  #168
mittens's Avatar
mittens
I am still trying to get an answer about this.
I have one from my 2000 trans am, will it work on a c6? do they have the same plugs? part number?
Old Nov 19, 2008 | 02:27 PM
  #169
southerncarparts
Supporting Vendor
I tend to think not but I can't say from first-hand experience.
Thanks,
Dave
Old Nov 24, 2008 | 01:03 PM
  #170
mittens's Avatar
mittens
so my car shows the 1-4 light sometiems but GAGS is not kicking in, makes me think someone allready did this mod. Looked int he fuse box under the hood for a LED fuse but did not see one.
Old Nov 24, 2008 | 03:22 PM
  #171
Larry/car's Avatar
Larry/car
If the shift light comes on, you can always shift into third. It doesn't block any other gear except second. Most of the time I'm shifting into third anyway at low throttle. I was going to go the eliminator route but decided to try the factory system. After over 4,000 miles I have come to terms with shift light and I have decided not to modify the system. It actually saves gas and doesn't hurt performance.
Old Nov 25, 2008 | 03:03 PM
  #172
rjward's Avatar
rjward
Just took my fuse out yesterday and soldered on the old 2.2k resistor myself. Works like a charm.
Old Nov 25, 2008 | 07:29 PM
  #173
99-LS1-SS's Avatar
99-LS1-SS
7th Gear
I don't own a Corvette but I'm getting the Pontiac GXP with the manual transmission (T6060). I ordered the ship shift eliminator. I can't think of any reason why it shouldn't work with the GXP. Anyone more knowledgeable than me know of any potential issues?
Thanks.
Old Nov 26, 2008 | 08:13 AM
  #174
99-LS1-SS's Avatar
99-LS1-SS
7th Gear
Well, I've already purchased it so I guess you can tell me the $2 version.
Old Dec 4, 2008 | 01:46 PM
  #175
rjwoerheide's Avatar
rjwoerheide
Necessary mod. The skip-shift is annoying.
Old Dec 15, 2008 | 05:57 PM
  #176
vettephyxer's Avatar
vettephyxer
Default just a quick question.
I installed a CAGS eliminator that i ordered from Corvette Mods into the #10 fuse holder under the hood. This thing just replaces the fuse and does let you shift from 1st to 2nd even though the light comes on. is there something wrong I should know about this thing? Noone seems to even bring this option up.
Old Dec 21, 2008 | 09:31 AM
  #177
Fastcar's Avatar
Fastcar
It goes into the #10 fuse holder? What is it a LED fuse that is blown?
To C6 Skip Shift Eliminator
Old Dec 21, 2008 | 04:06 PM
  #178
southerncarparts
Supporting Vendor
We have those also.....No real advantages or disadvantages to either style other than they type that plugs into the tranny can be used on both the C5 and C6 while the fuse style can only be used on the C6..
We have both available...
Cags Defeat (Fuse Style)
CAGS Defeat (plugs into tranny)
Ours is a bit cheaper than what you paid, but not by much.
See ya,
Jim
Old Jan 8, 2009 | 06:12 PM
  #179
xcutter's Avatar
xcutter
CF Senior Member
Originally Posted by southerncarparts
here you go...
1. Disconnect your Corvette's negative battery cable from the battery. The stock cable color is black, but you should check the markings on the battery to be certain.
2. To gain access to the CAGS solenoid, raise your Corvette as directed by the GM Shop/Owners Manual. Be sure to follow all safety precautions and use jack stands to support the vehicle.
3. The CAGS solenoid is located on the drivers' side of the transmission towards the top and rear of the transmission. The wiring harness connector is white and blue in color.
4. Gently lift the locking clip and unplug the connector from the solenoid. Make sure the connector and solenoid are clean. Plug the black end of the CAGS Eliminator into the wiring harness. You should hear a snap/click sound when the wiring harness is completely seated. Plug the white end of the CAGS Eliminator into the CAGS solenoid. You should hear a snap/click sound when the connector is completely seated.
5. Lower Corvette according to GM Shop Manual procedures.
6. Re-connect negative battery cable and test-drive car.
I have them in stock and ready to ship if you want one.
Jim
All that in 5 minutes? You are a better man than me
Old Jan 8, 2009 | 06:22 PM
  #180
xcutter's Avatar
xcutter
CF Senior Member
Originally Posted by mannyac5
Can't you disable the 1-4 skip shift feature by Removin the #10 fuse which
is the fuse that powers the solenoid for the skip shift feature? ... I haven't tried it, but it just seems logical...
Peace!
Yes and no. but you need to look at this post. This is another alternative which I chose to use. It involves the #10 fuse. It works great. The 1>4 light will still come on, but it will shift into second and not throw any codes.
CAGS LED FUSE Link
