Dash Reflection Problem
Old Dec 14, 2006 | 05:44 PM
2ndCRISISVETTE's Avatar
2ndCRISISVETTE
2nd Gear
Default Dash Reflection Problem
Does anyone have a solution for the problem of dash reflection onto the windshield? When the sun comes back out here in Seattle (next summer), I would like to find a way to avoid this very irritating problem.
Old Dec 14, 2006 | 06:09 PM
jdurhan's Avatar
jdurhan
I find as long as you dont use armorall or anything like that it's not to bad. I only use saddle soap on mine, leaves a clean non-glossy look.
Old Dec 14, 2006 | 06:10 PM
Mel 2001's Avatar
Mel 2001
Wear polarized sun glasses.
Old Dec 14, 2006 | 06:20 PM
06C6Z's Avatar
06C6Z
Old Dec 14, 2006 | 07:43 PM
Wayne O's Avatar
Wayne O
CF Senior Member
I agree...don't get too high of a shine on your dash, wear sunglasses and I wouldn't think there would be a problem. I live in Tucson and we have lots of extremely bright sunshine...over 300 days a year. The only reflection 'problem' I ever had was caused by the HUD built-into the dash and that was minor and didn't last long.
I guess you could always find some sort of a dash carpet to absorb sunlight. I wouldn't suggest doing it but it's possible.
Old Dec 14, 2006 | 08:21 PM
nowheelie's Avatar
nowheelie
I tried unsuccessfully internet searching for something that would help augment a matte finish (without eating the plastic).
Old Dec 14, 2006 | 08:23 PM
dandlb's Avatar
dandlb
Maui Jims
Old Dec 14, 2006 | 08:28 PM
catsmasher's Avatar
catsmasher
I agree with the polarized lenses and less shiny dash trim dressing. I like Meguiar's interior foam dressing.
There are also carpet mats that are intended as UV protection which would block glare as well. But, you'll still have glare from the HUD. I would choose option 1 or 2. Carpet belongs on the FLOOR.
Old Dec 15, 2006 | 03:42 AM
C7 BOB's Avatar
C7 BOB
Armor All makes a low shine version.
http://www.armorall.com/prod_lowshine.html
Old Dec 15, 2006 | 06:50 AM
Deftly's Avatar
Deftly
Is the nav screen polarized? If so, if the screen and sunglasses are in conflict the nav screen will be black. Anyone know?
Old Dec 15, 2006 | 07:35 AM
NightFlight's Avatar
NightFlight
I ordered a dash mat to protect the dash and prevent the glare ... living in the desert, I've seen what the sun can do to a dash
Old Dec 15, 2006 | 07:47 AM
AU N EGL's Avatar
AU N EGL
I agree. I use Windex to clean the dust and dirt off the dash Leaves it nice and clean.
Many ppl freek out about windex, but it does a great job.
GLossy dash boards are from things that probably should not be used.
I also use windex inside and out side of the windows. Works great and fast, no streeks with clean cloth or paper towel. Was not too found of Stoners, found it took too much work and had too many streeks.
dont use rain-x it streeks too much and you need alchol and lots of elbow grease to remove the rain -x
Old Dec 15, 2006 | 09:26 AM
05LeMansBlueMetallic's Avatar
Hi,
My first post to the forum and I hope I can answer your question. I've worn Corning polarized sunglasses for over 10 years and the Nav screen and HUD are both unaffected by wearing polarized lenses.
regards, Sarah
Old Dec 15, 2006 | 10:00 AM
FAA-ATC's Avatar
FAA-ATC
Default Polarized sunglasses...
really help, not only in seeing fewer/less severe reflections from the dash, but the frame around the HUD seems to disappear when I wear mine. Without the polarized sunglasses I see the HUD frame and it distracts from the view of the HUD. The lenses do cut down on the brightness/intensity a little, but not enough to bother me.
Old Dec 15, 2006 | 10:33 AM
LS WON's Avatar
LS WON
If they make those dash protectors you can use that. That solved a reflection problem I had on another car.
Old Dec 15, 2006 | 10:38 AM
LS WON's Avatar
LS WON
This product was recommended to me to clean the C-6 dashboard, and door panels because thus far I have used Klasse, 303 and they leave behind residue marks. There is no way that these parts can shine like on most cars. The interior material or vinyl is skin like a membrane so it doesn't reflect but leaves white marks behind.
Old Dec 15, 2006 | 11:38 AM
Fred C. Dobbs's Avatar
Fred C. Dobbs
I use a 50/50 mix of Murphy's Oil Soap and water. No gloss. It's good on leather too. I may even use it instead of toothpaste.
To Dash Reflection Problem
Old Dec 15, 2006 | 12:26 PM
PappyTinker's Avatar
PappyTinker
From: Life ain't no dress rehearsal, are you gonna wait to get your toys til AFTER you have a heart attack?
I know you don't want the regular Armor All or the Ultrashine Armor All but have you tried;
Old Dec 15, 2006 | 12:34 PM
quickride's Avatar
quickride
Aside from not putting anything on the dash to make it shine, wearing polarized sun glasses in the ONLY way to go. They really knock the glare out. Make sure they are Polarized glasses as they seem to be harder to find these days. Every thing is marked UV protection etc. but they are not the same as Polarized. If all else fails, look for these sunglasses online or anywhere they sell fishing gear. Most fishermen rely on Polarized glasses to take the glare off the water.
Old Dec 17, 2006 | 07:27 PM
2ndCRISISVETTE
2nd Gear
Default thanks for all the good advice
I'm a new member to the forum and the dashboard reflection problem question is my first posting. I'm impressed with the thoughtful responses. Think I'll go with the polarized sunglass solution. Thanks everyone.
