View Poll Results: Axle nut issue, please indicate which group you fall into
Found one/both nuts to be loose
39
31.97%
Found both nuts to be tight
15
12.30%
Have not checked at all
68
55.74%
Voters: 122. You may not vote on this poll
Axle Nut issue
Old Jun 8, 2007 | 09:19 AM
Bone Daddy's Avatar
Bone Daddy
Member: Jr Geezer's Club
This may have been brought up before....... but I'd be interested in knowing the correlation of how this is panning-out on Autos vs Manuals.
I am checking mine this w/e. If they are lose I will first try red (high-strength) loctite and mark with a Sharpie. If that doesn't work then I'll double nut. If that doesn't work I'll fire-up the Lincoln and weld the ****.
Old Jun 8, 2007 | 11:36 AM
Mr Valet's Avatar
Mr Valet
loose
Old Jun 8, 2007 | 11:41 AM
MNVette's Avatar
MNVette
I checked mine a couple of nights ago - both were loose (mine is a 2006 A6). Driver's side was about 1/4-1/2 turn loose, passenger was about 1/2-3/4 loose. I left the car on the ground and torqued each to 118 lbs with a 33 mm deep 1/2" socket & wrench from the folks at AutoZone.
From the amount of rust on the bolts and the shiny silver I uncovered when tightening, it would appear that the bolts have been loose for some time. They were probably that way from the factory, although I have no way of knowing.
Old Jun 8, 2007 | 03:36 PM
Don Baldwin's Avatar
Don Baldwin
Both sides less than 50 lbs/ft. Torqued to 118 lbs/ft and added a paint mark so as to be able to check without torque wrench.
Old Jun 8, 2007 | 04:05 PM
Busa196's Avatar
Busa196
Both of mine less than 50ft lbs as well - 05, A4.
Old Jun 8, 2007 | 04:48 PM
sea-six's Avatar
sea-six
Default axle nut
Right side finger tight/ Left side snug.. A06 coupe 4600 miles.Retightened 118Ft lbs.... done
Old Jun 8, 2007 | 04:58 PM
WHT's Avatar
WHT
I would expect the passenger side to be the biggest problem due to the right hand threads and direction of wheel rotation.
Old Jun 8, 2007 | 05:17 PM
NEV3R L8's Avatar
NEV3R L8
I understand the cause, but what could be the effect? I ask because my friends WS6 just went into the shop for a ticking sound coming from the right/rear area and it turns out the axle was bad. Just wondering if this could cause this or what could happen from a loose nut.
Old Jun 8, 2007 | 06:50 PM
webdzynes's Avatar
webdzynes
Originally Posted by LouieM
The axle nuts on my 07 are at leat finger tight. I'll have to go out and buy a 1-5/16 deep socket to really check this out.
Good luck finding one! Sears, Pep Boys, Autozone, Advanced Auto - ZIP!
Old Jun 8, 2007 | 08:10 PM
jbeidl's Avatar
jbeidl
NCM Life Member
Checked mine today. 2007 Z51 Coupe with 2424 miles. Left did not move at 118 ft.lbs. Right was between 30-50 ft.lbs. Tightened right to 118.
Save the Wave,
John
Old Jun 8, 2007 | 08:23 PM
dwilcox's Avatar
dwilcox
My 01 manual - left tight - right loose. Wifes' 04 auto - both tight. Current 07 Z - both tight - checked twice - once when new and at 6000 miles.
Old Jun 8, 2007 | 08:59 PM
01 Coupe's Avatar
01 Coupe
From: Denton, TX My goal in life is to be as good of a person that my dog already thinks I am.
2005, Z51, MN6, 5,500 miles. Both sides loose, passenger side much more then drivers side. I used a 1 5/16" socket and it fit perfect. I'll be checking these often.
Old Jun 8, 2007 | 09:01 PM
  #33
b4i4getit's Avatar
b4i4getit
There is way too much anxiety being posted about this. The wheel will not fall off. The only nut that needs tightening is the one behind the wheel.
Old Jun 9, 2007 | 08:19 AM
  #34
109710's Avatar
109710
Passenger side was tight...Driver side was loose.40-50ft lbs....Both now on with 'locktight' blue and double nuts......FIXED...34mm socket
Old Jun 9, 2007 | 08:28 AM
  #35
LMB 4 ME's Avatar
LMB 4 ME
From: Boca Raton Inlet, Atlantic Ocean (Floridas east coast)
Thats what happened to me. Had a loud "popping" sound every time I touched the throttle and again when I hit the breaks! Was driving me Took it to the dealer and they fixed it. The service guy said he has seen a few like that. The axle bolts were loose! Problem started around 8K miles on my 06 A6. Its perrrrrrfectly quiet now.
Old Jun 9, 2007 | 08:34 AM
  #36
catsmasher's Avatar
catsmasher
Passenger side too almost 1/3 turn to get it torqued. Drivers side was only a tiny bit loose.
Old Jun 9, 2007 | 03:35 PM
  #37
magredsee6's Avatar
magredsee6
Both sides were loose--probably at about 60-80 ft. lbs.
To Axle Nut issue
Old Jun 9, 2007 | 04:36 PM
  #38
don7790's Avatar
don7790
Mine built on May 1 with just over 1,000 miles on the speedo was about one half turn loose on both sides.
Old Jun 9, 2007 | 11:44 PM
  #39
MWAZ's Avatar
MWAZ
Stopped and bought a Great Neck 33 mm 6-point deep socket today at Autozone (fits perfectly).
Add me to the list; after only 5,000 miles - driver's side ok, passenger side very loose. I added a dab of green (wicking) Loctight but think I will order a couple additional nuts to act as jam-nuts.
Old Jun 10, 2007 | 12:24 AM
  #40
2kvetmy's Avatar
2kvetmy
mn6 11k miles
both sides started turning at 30 lbs torque, moved about 1/2 turn
