Axle Nut issue
http://www.sjdiscounttools.com/arm22-242.html
http://www.sjdiscounttools.com/sk34242.html
I looked locally - here's what I found:
Northern tool had a 3/4" drive 1 5/16" socket.. It's not quite a deep-well, but it's pretty deep considering it's diameter. It was $9
Autozone had 33 and 34 MM deep well 1/2" drive sockets - About $13 each.
I bought all three and we'll see what fits
Kit arrived within 5 days.
I do not have any affiliation with the above company, just a satisfied customer. There may also be sponsor vendors that sell the same kit.
I measured my axle nuts before ordering and both were more than 33.5mm so the 34mm socket worked fine for me.
Save the wave,
John
Save the wave,
John
I picked up a 33mm socket today at Pep Boys... el-cheapo, made in Taiwan, "Performance Tool" (PT) brand.. part #W80553... 1/2" drive, 6-point, deep, says "fits many GM applications" (for whatever that's worth)... only $12.99... it fit my rear axle nuts just fine, a tad loose if anything. This socket is of decent enough quality for this application.
A 34mm would definitely be way too big, at least on my axle nuts. Maybe different nuts have been used on C6s over time, but this PT 33mm socket is pretty much the perfect tool for the axle nuts on my 2006.
My driver's side nut was fine... was torqued to at least 118 lbs/ft.
My passenger side nut... I found it at LESS than 50 lbs/ft. But it did not require much movement to get it up to 118 lbs/ft.
I was thinking of double-nutting, but I feel that the nut torque may become reduced over time NOT necessarily because the nut loosens on its own, but because of other movement in the joint. Thus, it may be possible that the effective torque on the primary nut will become reduced over time even WITH double-nutting. Just a theory. Double-nutting WILL keep the primary nut from moving and backing off, but it will not ensure precise correct torque on the nut against the hub over time.
With the above in mind, I am thinking that I may NOT double-nut, and just make it a point to check the torque at every oil change or whatever... it's so quick and easy to do, realistically takes like 2 minutes or less and you don't even get dirty. Since I do not drag race, I doubt those nuts will be loosening up any quicker than 6k miles, so a bi-annual torque check should be a safe bet... about the same frequency as my oil changes.
I went to look at the hydraulic floor jacks and noticed they had some automotive tools back there that included several axle nut sockets. These are deep 6-pt 1/2 in drive sockets made out of black steel. They had one in 34 mm for $15 which I bought and it worked great.
It doesn't fit. It's too small.
Has anyone gotten a 1 5/16 inch to fit?
I guess I'm looking for a 33/34mm socket next...
Thanks for the tip
On my 2006 coupe, a 33mm fit great and was even a bit loose.
Some report the 33mm working fine, others report the 34mm working fine.
Seems that GM has been putting two different size nuts on these axles. I can't believe that the "same" nuts would vary in tolerance by almost a millimeter... and/or that common sockets would also vary this much in tolerance. It would be sad if all this is truly due to sloppy tolerances.
For everyone else: when in doubt, just go to your local auto store (Pep Boys, etc), and pick up a 33mm and also a 34mm... they should be about $13 each. Then keep the one that fits best, return the one that doesn't. It'll be one or the other. The "cheap" sockets sold in common auto stores are 6-point and deep (which is what you want)... and 1/2" drive also... so you will not need an adapter.
I lucked out with mine... bought one 33mm 6-point deep 1/2" drive socket, took it home and it fit perfectly. I had my nuts torqued within two minutes.
