View Poll Results : Axle nut issue, please indicate which group you fall into
Found one/both nuts to be loose
39
31.97%
Found both nuts to be tight
15
12.30%
Have not checked at all
68
55.74%
Axle Nut issue
Jul 14, 2007 | 07:40 PM
Checked mine today. Left side nut could be removed with my fingers. Right side fine.
Jul 14, 2007 | 07:45 PM
Quote:
Originally Posted by
nikic6
That's the opposite of most of us. Left (drivers) was tight and right side was loose.
Save The Wave,
John
Jul 16, 2007 | 09:30 PM
People are always saying I must have a screw loose... But in this case, my results are pretty much typical?
I have 4,000 miles on my '07 Coupe (F55).
Left (driver's) side took very little force to make the torque wrench click.
But the passenger side axle nut took about a quarter of a turn just to snug it up and then the typical amount of force before it "clicked".
Maybe overkill --- but I went ahead and double nutted the suckers. Now I'm concerned that my top-end speed will be adversely affected by all of that additional weight (two nuts) I've added. Time to go on a diet...
Or, perhaps a vasectomy is in order?
Jul 17, 2007 | 12:22 AM
drivers side ok, pass side loose.
Jul 17, 2007 | 12:33 AM
Both of mine were about one rotation loose, but then again I only have 6000+ miles on it.
Jul 23, 2007 | 04:55 PM
Checked my 06 with 4500 mi and both sides were very loose. A 33 MM fit perfect. I advise all to check those spindle nuts.
Jul 23, 2007 | 10:05 PM
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
Good to keep this thread alive, as new members are joining all the time.
Perhaps this should be added to the FAQ sticky under "Known Issues".
Jul 23, 2007 | 10:16 PM
Checked my new '08 today (900 delivery miles this past weekend) Nuts were to spec, but I double nutted it to be sure it stays that way!
