View Poll Results: Axle nut issue, please indicate which group you fall into
Found one/both nuts to be loose
39
31.97%
Found both nuts to be tight
15
12.30%
Have not checked at all
68
55.74%
Voters: 122. You may not vote on this poll
Axle Nut issue
Old Jun 4, 2007 | 12:08 PM
Road Rage's Avatar
Road Rage
Default Axle Nut issue
Since my neighbor, Chevy salesman, witnessed this condition on my '07 Z51 he and I would like to get an idea of just how widespread it is.
Old Jun 4, 2007 | 12:51 PM
Road Rage's Avatar
Road Rage
Any way I can get the Z06 folks to see this poll as well?
Old Jun 4, 2007 | 12:56 PM
MNVette's Avatar
MNVette
This is the first time I've heard of this issue - exactly what is the problem you are looking into here?
Old Jun 4, 2007 | 01:24 PM
Road Rage's Avatar
Road Rage
http://forums.corvetteforum.com/show....php?t=1712159
Old Jun 4, 2007 | 01:30 PM
C6FirstVette's Avatar
C6FirstVette
One issue here is your use of the terms 'loose' and 'tight'... to wit... loose can be 'finger loose' as some have found (and represents a significant issue) or could be not to spec (118 flbs) say 110 or 100 or even 90 flbs which is far from 'finger loose' and far from as significant. I found both axel nuts on my MY 05 to be on spec. Not discounting your poll just pointing out there is quite a bit of variance on this issue.
Michael
Old Jun 4, 2007 | 03:42 PM
Buffy's Avatar
Buffy
Michael
I see your point, but usually if a nut is pretty close to spec - say within about 20% - it won't move perceptibly when you re-torque it, especially if its been sitting there for a while. And I think that 20% is significant here - it appears that having this loose can lead to failure of the axle shaft, due to poorly-distributed stress.
Old Jun 4, 2007 | 03:49 PM
johnodrake's Avatar
johnodrake
Moderator
I haven't checked yet. Waiting for the socket.
Old Jun 4, 2007 | 04:59 PM
Radical05's Avatar
Radical05
Yep and double nutted now so no more
Old Jun 4, 2007 | 05:05 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
magic time... hold my beer..
Old Jun 4, 2007 | 05:16 PM
DEagle's Avatar
DEagle
I haven't checked mine, but I've got a question (pardon me if it's been asked before):
I know on other cars (the Ford GT, for example) the axle nut is not a reusable part. Once it is removed (or even loosened) it must be replaced. Has anyone checked a service manual to see if the axle nut on the C6 is reusable? In order to effectively check the torque on the nut, it should be loosened and then re-tightened. I just want to make sure this doesn't invite a new set of problems...
Old Jun 4, 2007 | 05:25 PM
AFVETTE's Avatar
AFVETTE
I'm guessing is this is a major safety issue GM will issue a RECALL or at least a TSB. Have either been published??
Tom
Old Jun 4, 2007 | 05:33 PM
Road Rage's Avatar
Road Rage
According to TSB 05-04-95-001 which is the Axle nut torquing procedure it makes no mention of having to use a new nut.
Old Jun 4, 2007 | 05:56 PM
Vet's Avatar
Vet
Can someone describe....
What EXACTLY would happen if the nut became loose and theoretically fell off?
Something else I had read on the forum implied that if the nut became very loose things would still stay together. It's not like the wheel or axle will drop off. Is this correct? (Have not had a chance to open my service manual yet).
How bad or dangerous is it for the nut to become very loose and/or come off if you are just using the car in a normal legal manner on the street (meaning no super hard launches)?
I plan to check / re-torque mine regardless, but just wondering how serious this issue really is. Not sure if I will double-nut or just douse the single nut with thread locker.
Wonder if these nuts loosened up over time after being torqued by the factory, or if they were just never torqued correctly to begin with.
Perhaps they WERE torqued properly, and then the fit loosened up a bit over time / use, causing the effective torque on the nut to become reduced...? If by chance this is the case, then it would be best to check the torque periodically, especially if racing.
Old Jun 4, 2007 | 06:17 PM
DEagle's Avatar
DEagle
Thanks! I'll do a search for the TSB...
Old Jun 4, 2007 | 06:23 PM
LouieM's Avatar
LouieM
The axle nuts on my 07 are at leat finger tight. I'll have to go out and buy a 1-5/16 deep socket to really check this out.
Old Jun 4, 2007 | 06:27 PM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Service Manual say nothing about needing a new nut.
Old Jun 4, 2007 | 06:33 PM
Daniel Redfoot's Avatar
Daniel Redfoot
I have been wondering the same thing. Any thoughts from those who may have taken the rear end apart before?
Or has anyone heard of a wheel actually coming off??
To Axle Nut issue
Old Jun 4, 2007 | 08:03 PM
PaBlueCoupe's Avatar
PaBlueCoupe
St. Jude Donor '06-'07-'09
Old Jun 7, 2007 | 06:34 PM
FortMorganAl
Bump
Old Jun 7, 2007 | 06:44 PM
retrorod's Avatar
retrorod
The nut retains the drive axle end into the hub center, it has nothing to do with holding the hub to the carrier or wheel or any part of the suspension. Theorectically you could remove the nut and drive around the block......not an advisable practice but the wheel would stay on the car.
