Pussy cat problem
Old Jan 14, 2008 | 10:58 AM
Me262's Avatar
Me262
Default ***** cat problem
Since winter has set in, I am finding cats sleeping on my Vert top. I guess it's warm on soft. Obviously it's not good for it. Has anyone had this problem and come up with a solution? I do not want to use a cover because it's a hassle.
Old Jan 14, 2008 | 11:02 AM
70454's Avatar
70454
Cats and Corvette paint do not mix well either.
Old Jan 14, 2008 | 11:08 AM
JJC5's Avatar
JJC5
Nix the cats!!!
Old Jan 14, 2008 | 11:09 AM
Carnac's Avatar
Carnac
Default Had the same problem...
When I had my 90 Vert and parked it in the garage our cat loved sleeping on the black top (white cat of course). We didn't let the cat in the garage often, but every chance he got, there he was.
I used a beach towel on the roof for a while (since it was inside, the wind didn't blow it off). Ended up covering the car most of the time.
Used a lint roller to remove the hair when needed.
Also didn't like the foot prints sliding down the windshield.
Cat is gone and so is the 90 Vert (loved them both).
Good luck - Jim
Old Jan 14, 2008 | 11:12 AM
Captain David's Avatar
Captain David
Here's the Solution
[IMG][/IMG]
Old Jan 14, 2008 | 11:14 AM
Victoryred 08's Avatar
Victoryred 08
St. Jude Donor '08
I see you said cats in the plural(more than one). This is going to be hard to stop. Are they your cats? If not, a cover may be your only choice, but you may in time have a problem with your top sagging from the cats weight. Never heard of a problem like yours. Good luck keeping them off your vert's top.
Old Jan 14, 2008 | 11:19 AM
Me262's Avatar
Me262
Originally Posted by Captain David
Here's the Solution
[IMG][/IMG]
OMG !!! That's a huge freakin dog.
Old Jan 14, 2008 | 11:22 AM
70454's Avatar
70454
I've seen my cat jump on the roof via way of the driver's door window trim. The rear claws don't hook up very well and it does a number on the paint. I've also found exit wounds on my hood from the cat's dismount towards the front of the car. Cat's don't like the unstable, freshly waxed surface. Once they start sliding, they panic.
Old Jan 14, 2008 | 11:28 AM
PAvetter's Avatar
PAvetter
Dogs, Guns, Rat poision, those types of things will all solve your problem.
If those aren't options can u just keep the cats out of the garage? If you get cat whiz on your top good luck getting rid of that smell.
Old Jan 14, 2008 | 11:36 AM
Jim-in-Ga's Avatar
Jim-in-Ga
Right now I have the plastic top on the vet. I have the the hard top wraped in a soft blanket and covered and under the bed. I have a large male cat that thinks this is his new bed. I've used a spray bottle with water, amoung other things, but nothing works.
It must be something in the roof materal that they like. If you find a way to keep them out, let me know.
Jim
2008
USAF Retired
Old Jan 14, 2008 | 11:40 AM
Tyler_Z06's Avatar
Tyler_Z06
They make a sour apple spray to keep cats off of stuff. With our cats we only had to spray it once (our electronics cabinet for our family room) and they stayed away for good.
If I remember correctly it was about $10 here at a small pet store for a good sized bottle. It said it was safe on all surfaces but before I sprayed it on my rack I tested it on the underside
Old Jan 14, 2008 | 11:43 AM
C6NRED's Avatar
C6NRED
There is NO way I'd let a cat sleep on the 'Vette......I know that they make sprays to keep cats off of furniture....most are mildy citrus based, which should not hurt your top....the other option is to cover your car......the weight of the cat on your top is not the worry that their claws on your doors and fenders should be......best of luck!!
Old Jan 14, 2008 | 11:47 AM
joec's Avatar
joec
antifreeze in pan...
Old Jan 14, 2008 | 11:49 AM
User 020720's Avatar
User 020720
Old Jan 14, 2008 | 12:19 PM
MThomas's Avatar
MThomas
I would load the cat up and take it for a long one way drive. No more problems!!!!!
Old Jan 14, 2008 | 12:23 PM
rjr2007's Avatar
rjr2007
Here's the Solution
[IMG][/IMG]
good looking puppy
Old Jan 14, 2008 | 12:29 PM
BrentC5Z's Avatar
BrentC5Z
+2
To Pussy cat problem
Old Jan 14, 2008 | 12:34 PM
vetdude's Avatar
vetdude
Just get a cover - not that much hassle.
PS: If someone intentionally killed my pet with antifreeze as suggested above, I'd be out for revenge.
Old Jan 14, 2008 | 12:38 PM
brianz's Avatar
brianz
Beach towel over the top.
Ya might want to also cover the hood and the trunk while
the training is taking place. The cat is gonna jump some
unknown direction ...
Set 2 mouse traps on the beach towel.
Cover the mouse traps with newspaper.
When the cat jumps on the top and triggers the mouse trap(s)
the snap of the mouse trap under the newspaper is loud and causes the newspaper to jump. Startles the cat and it jumps off.
Repeat are required to train the cat to go somewhere else.
hth
Old Jan 14, 2008 | 12:40 PM
07C6Z51's Avatar
07C6Z51
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Originally Posted by rjr2007
good looking puppy
Damn. he might knock the Vette over, getting to the cat!!!!!!!!!!!!!!!
