Jacking Pucks?
Old Mar 7, 2008 | 09:27 AM
bullrunvette's Avatar
bullrunvette
Default Jacking Pucks?
I guess I had better get a set of jacking pucks to keep in one of the rear storage compartments. Is there a particular kind to get or not get?
Any particular vendor to get them from?
Old Mar 7, 2008 | 09:30 AM
1bdasvt's Avatar
1bdasvt
St. Jude Donor '06-'09
I got Mine from Katech!!
Old Mar 7, 2008 | 09:33 AM
VETTAMOUS's Avatar
VETTAMOUS
St. Jude Donor '11-'12, '14
can you get them at a auto store?
Old Mar 7, 2008 | 09:35 AM
jimmie jam's Avatar
jimmie jam
i have BMW plastic pucks. installed on the car at 1 mile where they remain. hope they never have to be used. they are about 3/8 lower than the frame. you don't see them at all. $30+- for all 4.
Old Mar 7, 2008 | 09:45 AM
Bandit1's Avatar
Bandit1
Try these. I have a set in the rear compartment. Come in handy at the dealership and tire/wheel shops.
http://www.eliteengineeringusa.com/C6Products.html
STEVE MC's Avatar
STEVE MC
I got mine from Ecklers, they were a bit pricey.
I keep them in the rear comparment.
Old Mar 7, 2008 | 09:55 AM
j_digi454's Avatar
j_digi454
Originally Posted by FAÇADE-C6
BMW Round Pads:
Order here . . .
http://www.bavauto.com/fland.asp?par...1+71+1+960+752
Part # 51 71 1 960 752
(For a 2004 325Ci)
BMW Rectangular Pads:
Order here . . .
http://www.bavauto.com/fland.asp?par...1+71+8+268+885
Part # 51 71 8 268 885
(For a 2004 325Ci)
I have the round ones, installed them and left them on the car. They are not visible at all.
I believe the rectangular ones are a little thicker and am not sure how well they fit into the opening where the puck "screws" in.
Old Mar 7, 2008 | 10:10 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Do a search on ebay for "CORVETTE C5 C6 JACK JACKING LIFT PADS PUCKS". About $20 delivered. Includes a nice bag that seems designed to fit so it takes minimal space.
I prefer the rubber to metal. There have been comments that the metal can scratch or bend the lifting points. Also the metal is slicker so the jack will slip easier.
And, in answer to a comment in another thread, I doubt that a piece of rubber in compression will ever "bust".
Old Mar 7, 2008 | 10:16 AM
dvilin's Avatar
dvilin
Just curious as this is new to me also but is there a reason for keeping them in the rear compartment versus installing them, thanks.
Old Mar 7, 2008 | 10:19 AM
jimchris76's Avatar
jimchris76
I went to this web site and didn't see any for a C6, is the BMW the same as a C6 when it comes to jacking?
FloydSummerOf68's Avatar
FloydSummerOf68
What are the purpose of these? (serious)
What do these do that is beneficial...why would I get these instead of just jacking the car up like I always do?
Old Mar 7, 2008 | 10:20 AM
BearCreekC6's Avatar
BearCreekC6
I got mine from the local ice skating rink. Total cost was $1.39 each....
Old Mar 7, 2008 | 10:27 AM
obxchartercaptain's Avatar
obxchartercaptain
FL Events Coordinator
Now there's a Hockey Puck for ya
Old Mar 7, 2008 | 10:33 AM
FortMorganAl
Helps prevent this - http://forums.corvetteforum.com/show....php?t=1553583
The rocker panels stick down below the frame and without a puck you have to be very careful with the jack and, depending on how large the head of the jack is, it may be impossible to lift the frame without damaging the rocker.
Old Mar 7, 2008 | 10:37 AM
j_digi454's Avatar
j_digi454
Yes, the BMW has the same reqirement for jacking under the rocker panels.
I just tried the link offered with pictures above for Bavarian Autosport and it takes you right to the puck ordering info.
Old Mar 7, 2008 | 10:41 AM
RED2008Z06's Avatar
RED2008Z06
I did the same, Dick's sporting goods(pucks) Home Depot(eye bolts) good luck..
Old Mar 7, 2008 | 10:43 AM
Hogvette's Avatar
Hogvette
Ditto what he said!
To Jacking Pucks?
Old Mar 7, 2008 | 10:44 AM
Wayne O's Avatar
Wayne O
CF Senior Member
I also prefer the rectangular, BMW pucks but I would never leave them installed 24/7. If my car ever breaks down I will need to remove the jacking pucks in order for the tow truck to utilize the oval frame slots (to winch the car onto the flatbed). If my car breaks down I'm already PO'd...I don't want to be lying in the rain and mud; alongside a busy, dangerous freeway; in the dark; trying to remove my jacking pucks before the tow truck arrives. I install my jacking pucks as needed and remove them immediately afterwards. I've also heard of someone damaging their car when the jacking pucks scraped-on and got hung-up a speed bump. IMO put them on when you need to and take them off when you're done.
Old Mar 7, 2008 | 10:50 AM
Painrace's Avatar
Painrace
If you want the best, get them from Katech. Quality still matters to Katech!
Old Mar 7, 2008 | 11:22 AM
RadarP3C's Avatar
RadarP3C
I like the Eckler's because they are thicker to give more clearance and are made of a urathane material which should prevent slipage and is more of a cushion than the other metal pucks.
