I have a problem
Old Sep 2, 2008 | 12:31 PM
Hickory Flash's Avatar
Hickory Flash
St. Jude Donor '09
That's where it is and they can't figure it out
Old Sep 2, 2008 | 05:34 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
As mentioned above, there have been problems with the steering wheel position sensor wiring, a connector in the steering column gets pulled slightly loose and weird things happen. There is a bulletin out on this subject, the current fix is a clip that holds the connector together even if the wires pulled a little. Many dealers seem unable to understand the issue and the associated codes.
I'm not at all sure this is your problem, but it's worth checking...
Old Sep 2, 2008 | 05:41 PM
Hickory Flash
St. Jude Donor '09
I just got a call from the dealer. They were on the phone with Tech service and were told to put in a new Mail Computer (DTC I think) It will be in in the morning and I hope that fixes things. If not I will mention your comments.
Thanks for the help
Old Sep 2, 2008 | 05:45 PM
Fuego's Avatar
Fuego
Thanks for the help
What's a Mail Computer? Or DTC?:o
Old Sep 2, 2008 | 05:48 PM
Hickory Flash
St. Jude Donor '09
Ops, Mail computer.
Old Sep 2, 2008 | 05:49 PM
Hickory Flash
St. Jude Donor '09
Main computer
Old Sep 2, 2008 | 05:53 PM
rjwoerheide's Avatar
rjwoerheide
Good luck with everything. I am curious to see what Talon90 has to say.
Old Sep 2, 2008 | 07:52 PM
Mad*Max's Avatar
Mad*Max
Thanks for the help
Good luck, keep us posted.
Old Sep 3, 2008 | 04:04 PM
Hickory Flash
St. Jude Donor '09
Well I just talked to the dealer and they replaced the computer and that didn't fix it. Still has the same problem
Old Sep 3, 2008 | 06:05 PM
Hickory Flash
St. Jude Donor '09
The dealer just called and said it is an engine issue and that is what is making the Service Active Handling come on. They have two guys working on it and can't figure it out.
Old Sep 3, 2008 | 06:43 PM
Pocket Aces's Avatar
Pocket Aces
Well, took it to the dealer this morning at 7:00. They jumped right on it and thought they figured it out. They took a part off a Corvette in the showroom and put the part on mine and tried to reprogram the computer. Well now I'm driving a rental car and they haven't a clue. They are trying to talk to Tech service.
WTH? I know they are trying to service it quickly but I'll be damned if the way to do it is pull parts of a brand new vette and do the trial and error swap. There could be easily something wrong electrically with your vette which could end up frying those new swapped parts.
Are they pulling an engine out of a new vette and trying that too?
Old Sep 3, 2008 | 06:56 PM
Johnny Utah's Avatar
Johnny Utah
From: ,fl.Never, under any circumstances, take a sleeping pill and a laxative on the same night.
same happened to me,it was a steering wheel positioning switch/clip,good luck
Old Sep 4, 2008 | 10:37 AM
  #33
Hickory Flash
St. Jude Donor '09
Boy, these grease monkeys really get pissed when you suggest something. They can't fix it but won't try something different. If It isn't fixed today, I'm going to pick it up and go to a different dealer.
Old Sep 4, 2008 | 01:37 PM
  #34
Hickory Flash
St. Jude Donor '09
Well, the dealer claims the the Steering Wheel swich was not the problem but they still can't fix it. What a bummer. It's too bad my check has already cleared the bank.
Old Sep 4, 2008 | 01:54 PM
  #35
wsharp24's Avatar
wsharp24
I had this actual issue and the dealer fixed it....there was a TSB on it.
Old Sep 4, 2008 | 02:01 PM
  #36
Hickory Flash
St. Jude Donor '09
I told them there was a TSB but don't know if they followed up or not. Wish I could get a copy of it.
Old Sep 4, 2008 | 03:55 PM
  #37
Hickory Flash
St. Jude Donor '09
Well the dealership called and said they found the problem. There was a hole in one of the lines that has something to do with the fuel injectors. The sales guy that called me didn't know exactly what but said they would have the new part tomorrow and would show me the old part when I pick it up. Hope it fixes it. It has already spent one third of its life at the shop.
To I have a problem
Old Sep 4, 2008 | 04:19 PM
  #38
rakuhn's Avatar
rakuhn
I guess part of the information is a definition of "got on it just a little bit".
You have received valid advice. Remember as well, that is the reason you have a warranty.
Good luck
Old Sep 4, 2008 | 04:33 PM
  #39
Hickory Flash
St. Jude Donor '09
I shifted about 3500 RPMs, That's where the NPP's bark at ya. The service Mgr. said it was a small crack that looked like it was over tightened at the factory. Just my luck.
Old Sep 4, 2008 | 04:48 PM
  #40
REVHIGH's Avatar
REVHIGH
Is this fixed? Curious
By Michael S. Palmer | 2026-06-03 11:00:24
