I have a problem
Old Sep 8, 2008 | 09:13 PM
  #61
Hickory Flash's Avatar
Hickory Flash
St. Jude Donor '09
Oh Ya,
BTW, I never could find how to get hold of Talon. It might have helped.
Old Sep 9, 2008 | 07:21 AM
  #62
gota07's Avatar
gota07
Cruise-In VIII Veteran
Originally Posted by Black2009
Oh Ya,
For future reference, go to the members list under the Other menu and search for the username. From there you can send a PM.
Old Sep 9, 2008 | 07:30 AM
  #63
Bulitt's Avatar
Bulitt
I find it hard to believe they only found a broken valve spring. What about the valve? Piston?
Old Sep 9, 2008 | 07:36 AM
  #64
Mad*Max's Avatar
Mad*Max
Glad to hear that you are all fixed up now.
Old Sep 9, 2008 | 07:46 AM
  #65
C6 Doberman's Avatar
C6 Doberman
I was wondering the same thing
Did the valve drop into the cylinder? If so, I would want to see the head pulled off the car!
Old Sep 9, 2008 | 03:29 PM
  #66
Hickory Flash
St. Jude Donor '09
They scoped the cylinder and found no damage. The compression check had all eight cylinders within 5 psi of each other. I still have 99,000 mils of coverage on the engine so I'm happy. It runs great now. They showed me the valve spring and it was broken in two about 1 1/2 turns from the top.
Old Sep 9, 2008 | 03:46 PM
  #67
cclive's Avatar
cclive
I wouldn't expect a broken valve spring to allow the valve to fall into the cylinder, unless it shattered into a million pieces. The spring would just lose its ability to make the valve seal to the seat. This is funny because if you had taken a car into a mechanic in the 1960's, they would have checked the compression much sooner, after they found spark and fuel.
And it may still be that the two events just happened at the same time by coincidence. There wouldn't seem to be any connection between a valve spring and a DIC message like you got. It will be interesting to see if the DIC message comes back after a while without any engine roughness.
Glad your wife decided to ride out the storm and stay with you!
Old Sep 9, 2008 | 05:30 PM
  #68
BetterMostC6's Avatar
BetterMostC6
I feel so lucky, my car has been 99% trouble free so far. I sure hope you enjoy your car as much as I do mine. Glad its fixed.
