Solution to my Parking Problem
Old Nov 3, 2008 | 08:55 PM
Django's Avatar
Django
Default Solution to my Parking Problem
Now they all fit in the garage!
Old Nov 3, 2008 | 09:00 PM
dpigguy's Avatar
dpigguy
pretty wild however, the stang should be on top since you drive it the least (or at least should do so)
Old Nov 3, 2008 | 09:01 PM
happydealer's Avatar
happydealer
2nd Gear
Too funny. The Mustang should have gotten the upper bunk.
Old Nov 3, 2008 | 09:03 PM
JohnRR's Avatar
JohnRR
Very nice. You're thinking outside the box!
Old Nov 3, 2008 | 09:05 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
I like what you have done and it is a radical design and how tall is the orginal ceiling
Old Nov 3, 2008 | 09:07 PM
VettedCandidate's Avatar
VettedCandidate
wow, pretty cool...
Old Nov 3, 2008 | 09:12 PM
HANNY's Avatar
HANNY
awesome!! can we get some specs? Ceiling height, height of mustang width and height of lift. thxs paul
Old Nov 3, 2008 | 09:15 PM
Donkey's Avatar
Donkey
Perfect...now you can finally crush that Mustang!
Old Nov 3, 2008 | 09:18 PM
Django's Avatar
Django
The stang would be my son's ride. I would be afraid to stick the vette under a oil leaking Ford
The ceiling in the garage is 9'. The cut out is 6' x7' 24" depth.
The lift is a Pro Park 8s The roof clearance on the stang is 55.1"
There is a good 8 to 12"" clearance with the vette raised to the max.
Old Nov 3, 2008 | 09:26 PM
RocketV's Avatar
RocketV
Nice clean job.
Old Nov 3, 2008 | 09:31 PM
philip_g's Avatar
philip_g
can you cut a truss like that and not have the roof fall in?
Old Nov 3, 2008 | 09:32 PM
VET4LES's Avatar
VET4LES
Great job.
Old Nov 3, 2008 | 09:39 PM
dwiemers's Avatar
dwiemers
I'm impressed....I'd be scared as hell to do that to my own house....does that mess up anything with AC electric bills or whatever?
Old Nov 3, 2008 | 09:40 PM
Django's Avatar
Django
It is not advisable to cut the bottom cord of a truss roof as I have done here with out consulting a qualified contractor.
For even this short span there are two suspended beams and considerable bracing involved.
Old Nov 3, 2008 | 09:46 PM
BlueC6's Avatar
BlueC6
Default Engineer Advice
As a structural engineer (aviation), cutting that truss gives me goose bumps. But, houses don't fly, so it is probably cool. Nice Vette! I have an '07 LMB coupe. My garage is barely too short to fit both my Vette and the wife's Accord in tandem. Maybe I should consider stacking.
Old Nov 3, 2008 | 09:53 PM
HANNY's Avatar
HANNY
last question, is the lift electric? and how long if you wanna drive the vette to get it down (alright 2 questions)
Old Nov 3, 2008 | 09:55 PM
Django's Avatar
Django
Thanks!
I have a sawzall I can loan you if you want to expand up
To Solution to my Parking Problem
Old Nov 3, 2008 | 10:00 PM
xlr8rvette's Avatar
xlr8rvette
From: Fayetteville Arkansas recently moved from Oakland Ca
St. Jude Donor '06
[QUOTE=JohnRR;1567717667]Very nice. You're thinking outside the box!
....thinking outside the garage !!
Old Nov 3, 2008 | 10:01 PM
BlueC6's Avatar
BlueC6
Is there anything a sawzall can't do? I always wanted a convertible...hmmm
Django's Avatar
Django
Yes it is electric/hydraulic.
The lift has only been setup for a few hours.
It seems to go up in about 40 or so seconds and down a little quicker.
I still need to tweek the position of the lift a bit more before I bolt it to the floor.
