Jacking Points
Old Feb 22, 2012 | 02:38 PM
  #41
Shifter6's Avatar
Shifter6
Originally Posted by pahlbfishn
Has anyone ever seen or heard of a vette folding in half when they use Bugman's jacking points? I have used them many times when I use one jack and have NEVER folded my car in half, broken a cross member or any other damage.
For people that track these cars (C5/C6) regularly and jack them up regularly, they know the Bugman jacking points work fine. Make sure the width of the crosmember is covered by the jack as Bill suggested.
If you have pratical experience working on cars, you know why it works with no issues.
If you are a "stick to the manual" kind of guy, or just to scared to make any decisions on your own without consulting a GM engineer, stick to the EXACT procedure as described in the manual.
I will call you when I fold my car in half and tell you how right you were!
Old Feb 22, 2012 | 02:46 PM
  #42
TJay74's Avatar
TJay74
I guess I dotn see the issue. To jack the front of my car up I go to the spot right under the drivers side door on the frame rail and lift the car up, then place a stand under the engine cradle.
then I put the jack under the engine cradle and lift the whole front end up and put the other jack stand under the passenger side of the car and lift it up.
has worked perfectly fine eac time I have done it. To lift the rear I go right in the middle of the exhuast and lift from the rear cradle and lift the entire rear end, then support with stands.
I have not seen one issue so far with these methods.
Old Feb 24, 2012 | 10:03 AM
  #43
vray's Avatar
vray
Originally Posted by Racer
Old Feb 24, 2012 | 10:31 AM
  #44
Jimmy W1's Avatar
Jimmy W1
When changing oil, does anyone just use the one jacking puck under the driver's door, jack the car up in that one spot and put a jackstand near the jack and do all of the oil changing work just by using that one jacking puck spot? Or should you jack both sides up using the jacking puck areas and put two jacks under the front of the car? I've never changed oil doing all of that before on my other cars. I always just used one jackstand on the side after I got the car high enough to crawl under. It seems like an awful lot of work to jack both sides up and lower them twice and use two jack stands while changing oil. Is this really necessary?
Old Feb 24, 2012 | 10:39 AM
  #45
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Originally Posted by JoesC5
This is not a GM engineering drawing, not is it approved by GM. Some guy on the Internet just did some southern engineering at Bubba's Bait and Chassis Engineeing Shop.
Actually, this drawing is taken directly from the Corvette service manual. The only thing that has been modified is that the colors were added in place of the various cross hatches in the oriignal drawing to aide in clarity because they are difficult to discern when posted. It also makes allowances for jacks as well as lifts at the primary and secondary locations.
Notice
When you are jacking or lifting a vehicle at the frame side rails or other prescribed lift points, be certain that the lift pads do not contact the catalytic converter, the brake pipes or the fuel lines. If such contact occurs, vehicle damage or unsatisfactory vehicle performance may result.
Before you begin any lifting procedure, be sure the vehicle is on a clean, hard, level surface. Be sure all the lifting equipment meets weight standards and is in good working order. Be sure all the vehicle loads are equally distributed and secure. If you are only supporting the vehicle at the frame side rails, make sure the lifting equipment does not put too much stress on or weaken the frame side rails.
If you use any other lifting methods than those called out, take special care not to damage the fuel tanks, the exhaust system or the underbody.
Notice
When you are jacking the vehicle at the front locations, be certain that the jack or the jack lift pad does not contact the front fascia, front fascia air dam, or the front fenders. If such contact occurs, vehicle damage may result. When jacking at selected front locations additional clearance may be required for the jacking points.
Regarding the owners manual. What it says is as follows:
"If you ever use a jack to lift your vehicle, follow the
instructions that came with the jack, and be sure to
use the correct lifting points to avoid damaging
your vehicle.
Notice: Lifting your vehicle improperly can damage
your vehicle and result in costly repairs not covered
by your warranty. To lift your vehicle properly, follow
the advice in this part.
To help prevent vehicle damage:
• Be sure to place a block or pad between the
jack and the vehicle.
• Make sure the jack you’re using spans at least
two crossmember ribs.
• Lift only in the areas shown in the following
pictures.
For additional information, see your dealer and the
Chevrolet Corvette service manual.
5-77"
Old Feb 24, 2012 | 10:49 AM
  #46
ufso's Avatar
ufso
I've been doing that exact thing since 2005 and have not had any problems, except using the jack stand point as shown by Bugman.
Old Feb 24, 2012 | 10:50 AM
  #47
Jimmy W1's Avatar
Jimmy W1
But my question is: Can't you change oil and only use the one jacking spot under the driver's door ( with the jacking puck) to lift the car up and down? Or do you have to lift the entire front of the car up and support it with TWO jack stands under the front end.
Old Feb 24, 2012 | 10:54 AM
  #48
talon90's Avatar
talon90
NCM Ambassador
You can safely lift the C6 for an oil change by jacking at the jacking point behind the front wheel. It is always a good idea to use a jack stand for safety when working with a hydrauic jack.
Old Feb 24, 2012 | 11:00 AM
  #49
Jimmy W1's Avatar
Jimmy W1
According to my book Bugman has the jacks wrong. He only has the jack under one rib. Look at picture #3 above. He has the weight of the car resting on the jack on only one rib. It says to have the jack under at least TWO ribs. All I have ever done when jacking any of my cars when I change oil is to jack it up by the side rail on only ONE side of the car, slide a jack under it for safety- usually under the frame somewhere, and jack it up and down using only one side of the car. So, jacking it up and down on both side rails with jacking pucks and putting TWO jacks under the front end and doing all of this twice in the process of changing oil- is that really necessary?
Old Feb 24, 2012 | 11:01 AM
  #50
Jimmy W1's Avatar
Jimmy W1
That is what I do on my other cars. But I was wondering how to do it with my 05 Corvette.
Old Feb 24, 2012 | 11:08 AM
  #51
talon90's Avatar
talon90
NCM Ambassador
To make my life easier, I drive up on ramps, then jack from the drivers side and support with jack stands so I can move the jack out of the way. It doesn't take me very long.
The exact procedure I use for changing my oil is listed on my website in a PDF here:
http://www.theredlion.us/C6%20Changi...ette%20Oil.pdf
I only do this because it's the way I do it. The frame jack point is fine and there are plenty who use nothing but the jacking point. As I said, I don't recommend getting under a car with only a hydraulic jack supporting it but if it holds the car is fine. There are still three tires under the car supporting the majority of the weight. You do not need to lift the entire front of the vehicle if you don't want to.
By the way. The owners manual photos and information I posted above is from my 2005 owners manual. Have a look in your manual at pages 5-71, 5-72 and 5-73 for the pictures (including the reference of lifting behind the front tire and the notes stating to use a pad or a block between the jack and the vehicle.
Old Feb 24, 2012 | 11:58 AM
  #52
Jimmy W1's Avatar
Jimmy W1
If you drive up on ramps, does all of the oil drain out of your oil pan with only the front end in the air? Once I get the drain plug out of the pan, I always lower the car back down level and let the oil drain out. Then when the pan is empty, I jack it back up to put the filter on and replace the plug. Is the plug on the C6 situated to let all of the oil out of the pan with both sides of the front end elevated?
Old Feb 24, 2012 | 12:07 PM
  #53
talon90's Avatar
talon90
NCM Ambassador
The drain plug is lower and rear on the oil pan. I've never had an issue with a quantity of oil unaccounted for. If you want to make sure (the C5 oil change procedure recommended the car be basically flat). To accomplish this, you can jack up the rear of the car during the draining process. Easy for me as I have a second low profile jack.
Old Feb 24, 2012 | 12:16 PM
  #54
Jimmy W1's Avatar
Jimmy W1
OK. Thanks. I appreciate it.
Old Feb 24, 2012 | 12:22 PM
  #55
Don-Vette's Avatar
Don-Vette
Oh I didn't know I needed a GM engineering drawing to jack up my car. LMFAO!!!!!
Old Feb 24, 2012 | 01:25 PM
  #56
JoesC5's Avatar
JoesC5
You are the reason GM has to include a drawing and instructions in the owners manual.
Old Feb 24, 2012 | 01:33 PM
  #57
JoesC5's Avatar
JoesC5
Notice
Notice
your vehicle.
pictures.
5-77"
I will repeat it again for those that do not understand. The drawing that Bugman shows is NOT a GM drawing not approved by GM. The Drawing is a MODIFIED drawing that GM originally drew and approved. ANY drawings and instructions that have been modified by someone other the GM are no longer GM approved drawings.
I could take a GM drawing and modify it to show a 4 X 4 placed across the car under the roof panel and then say the jacking points are at the ends of the 4 X 4. Just because I started out with a approved GM drawing, does not make my modified drawing an approved GM drawing and anyone who follows that drawing and it's instructions are stupid if they beleive they are following a GM approved drawing.
To Jacking Points
Old Feb 24, 2012 | 01:36 PM
  #58
talon90's Avatar
talon90
NCM Ambassador
I will repeat it again for those that do not understand. The drawing that Bugman shows is NOT a GM drawing not approved by GM. The Drawing is a MODIFIED drawing that GM originally drew and approved. ANY drawings and instructions that are been modified by someone other the GM are no longer GM approved drawings.
Understood. My drawing is an approved GM drawing and it's the one I use. What anyone else cares to use or do...Meh.
Old Feb 24, 2012 | 01:53 PM
  #59
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Old Feb 24, 2012 | 02:07 PM
  #60
Bill Dearborn's Avatar
Bill Dearborn
I would add to that a second jackstand on the other side of the cradle. I do what you are doing if I want to change a brake rotor or brake pads but if I am going to crawl under the car I want at least two jackstands holding both sides of the car. It isn't a matter of what the manual says it is a matter of "**** Happens". When I had a massive oil leak at the track and needed to get under the car to check things out I used two jackstands even though it made it more difficult to crawl in and inspect things. I don't want to be the newspaper headline guy who got crushed by his car.
Bill
