C6 Starting problem - please help!
Old Nov 11, 2011 | 06:06 PM
Richie Fazio's Avatar
Richie Fazio
Default C6 Starting problem - please help!
So I've mentioned this problem before and I still don't know whats going on. I have a 2009 C6 with 4800 miles on it. It's obviously not a daily driver as I've had it since July 2009. Anyways, sometimes I have a problem with my car starting up. For example, today I started it this morning, with no issues. Drove it around to run some errands. Parked it, started it up again, repeated a few times. It was warmed up fully at this time. Once I got home, I parked the car and let it sit for a while - about an hr or so. The next time I started it up, it made a hesitation type of noise (jitter, jittter, jitter) before firing up. The car was only about 20% warm at this time as it had been sitting for a while now. Took it out again for a little and parked it again real quick. Started it up then with no problem or hesistation. Then drove to the gym. Came out of the gym about an hr half later and started it up. This time it hesistated again before firing up - again only about 15-20% warmed up now.
Seems as though the pattern for this problem happens after I have driven it for a while and it sits for about an hr or so, the next time I start it.
This issue has become very frustrating to me. I've taken it to Chevy twice already, but they couldn't get the jitter noise to repeat - so they haven't found any issue. Could the battery be not fully charged from not driving the car enough? I've had my fuel pump replaced last year for the same type of issue, but it was constantly making this hesistation. Could it be another fuel pump issue?
Any advice or suggestions would be greatly appreciated. I'm going nuts with this thing now. Thank you.
Old Nov 11, 2011 | 06:14 PM
VET4LES's Avatar
VET4LES
If it's the original battery I'd replace it. The C6 is very hard on batteries. It sounds like your driving habit is short trips which is hard on any battery. When you replace it, make sure it's at full charge when you install it. New batteries can sit on the shelf for many months.
Old Nov 11, 2011 | 06:19 PM
Richie Fazio
Yes it is the original battery and yes mostly short trips all the time. Back and forth to the gym, quick errands etc. May I ask why short trips cause this?
Old Nov 11, 2011 | 06:20 PM
speedlink's Avatar
speedlink
Fuel pump?
Old Nov 11, 2011 | 06:22 PM
RicK T's Avatar
RicK T
Battery is usually the first suspect with these cars and probably wouldn't hurt to put in a new one. As Les said, sounds like you do many short trips and unless you drive in a lower gear a lot it's possible you really aren't charging the battery enough when you drive.
However, your description does make me think of a fuel delivery issue. Yes, could be the fuel pump again. Is there any way you can arrange to take the car in, warmed up to the level you've described, then stay there for an hour to hour and a half and then show them what happens when you start it under your partly warm scenario? Just thinking out loud. Let us know what happens.
Old Nov 11, 2011 | 06:24 PM
FiberGlassKid's Avatar
FiberGlassKid
Default How's the air filters?
Check the air filters. Does it hesitate when you apply the gas? Mine did, and the air filters were black with soot. I replaced them with K&N.
Old Nov 11, 2011 | 06:28 PM
arcticblast's Avatar
arcticblast
Cruise-In VI Veteran
Cruise-In VII Veteran
Short drives are harder on batteries because the car is not run long enough to keep the battery recharged. It's just a greater amount of drag from starting over and over.
Try to take it on a longer drive. At least 50 miles or so. But sometimes these original batteries do just go out after a couple of years. I like an Optima for replacement.
Old Nov 11, 2011 | 06:33 PM
Gary '09 C6's Avatar
Gary '09 C6
do you use a battery tender ?
you really should, given that you have said you do not drive it often, and then mostly on short trips...
the original battery is now almost 2.5 yrs old, or slightly more...
Old Nov 11, 2011 | 06:37 PM
Richie Fazio
Thanks for the replies. Looks like I didn't wait enough for the car to cool down the last time at Chevy for them to hear it. Sounds like I will have to try to bring it to them warmed, wait an hr and then try to get the noise. Not sure if it hesistates when I apply gas.
As I mentioned I get the hesistation the next time it starts up after sitting a while and its cooling down. If it was a fuel pump problem, wouldn't it happen all the time, like the first time I start it up or no? I don't understand why it happens once it begins to cool down?
Old Nov 12, 2011 | 09:56 AM
Richie Fazio
What's a battery tender?
Old Nov 12, 2011 | 10:19 AM
Jimmy W1's Avatar
Jimmy W1
It sounds to me like you have a bad ground or a wire loose somewhere. But before you start buying anything- take it to the dealer and let them take care of it. It is still under warranty isn't it? And I wouldn't change the battery unless you have it checked out for sure. The car should have a 6 year battery in it and it should still be under warranty too, correct? So, you don't want to start replacing everything and find out you just wasted your money. Let the dealer fix it........
Old Nov 12, 2011 | 10:36 AM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
go down to Auto Zone and have the battery checked step #1
Old Nov 12, 2011 | 10:46 AM
azcanuk's Avatar
azcanuk
Default get a new..
BATTERY.. the short trips you take is not charging it enough and every time you start it up.. you're draining it a little.
Put a new battery in and keep the car on a battery tender... PROBLEM SOLVED..
The clicking you hear is the starter trying to kick the car over.
BATTERY!
Old Nov 12, 2011 | 11:45 AM
mpuzach's Avatar
mpuzach
When you get the "hesitation type of noise (jitter, jittter, jitter) before firing up," is the starter motor turning or do you get these noises before the starter actually begins turning? If the symptoms are happening first, then the starter motor starts turning, I agree that the battery could be the problem; otherwise, it sounds more like a fuel delivery issue (vapor lock, perhaps).
Old Nov 12, 2011 | 11:46 AM
Mad*Max's Avatar
Mad*Max
check the voltage before you start it next time - should be at least 11.8 volts otherwise there is a problem in your battery
Old Nov 12, 2011 | 11:57 AM
4thC4at60's Avatar
4thC4at60
BATTERY!
Old Nov 12, 2011 | 12:56 PM
b4i4getit's Avatar
b4i4getit
Before you take the time and trouble to get a new battery consider getting a new battery tender and see if that makes a difference. I noticed you are in New York State so with the winter approaching you probably will be driving it less anyway. The dealer has documented your problem and you are still under warranty so if it keeps happening bring it to them again.
To C6 Starting problem - please help!
Old Nov 12, 2011 | 04:18 PM
Richie Fazio
Yes I will be driving it even less, if that's possible. I took it to the dealer today to show them the problem and their Corvette mechanic wasn't in, so I couldn't show them. Unreal. It keeps happening when I start it up after it has been cooling down and the car is about 20% still warmed (so it's been sitting for almost 45 min to hr after it has been warmed up and driver). It's just really an odd thing. Yes the warranty isn't up till July 2012. If it was a fuel problem, wouldn't it occur more often?
Old Nov 12, 2011 | 06:03 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Mine goes on a battery tender whenever it's going to sit for more than a couple of days.It's an OEM that's almost six years old and still going strong. These cars wll normally draw current even when parked, and as mentioned, short trips will only compound the problem. Buy yourself a battery tender (they aren't very expensive) and keep your battery fully charged. Once you know your battery is carrying a full charge, if you still have the same problem you will know it's something else.
Old Nov 12, 2011 | 08:24 PM
mpuzach's Avatar
mpuzach
OK, let me try asking again:
