Which Gas
Old Feb 11, 2012 | 08:00 PM
rakuhn's Avatar
rakuhn
Check out the Top Tier Gas site. I had my Cadillac towed in and the dealership gave me a copy of their GM Advisory that they recommended Top Tier. I have not had a problem since in any of my GM products.
Your buck, spend it as you see fit---you too Glenn.
Old Feb 11, 2012 | 08:03 PM
VET4LES's Avatar
VET4LES
Wow, has this subject been beat to death?
Old Feb 11, 2012 | 08:04 PM
rakuhn's Avatar
rakuhn
Sorry Glenn, meant the comment for c3-po.
Old Feb 11, 2012 | 08:16 PM
HighPro's Avatar
HighPro
My Z06 has an 18 gallon tank. If it is completely empty, the difference between 87 and 93 octane is $3.60. I spend the extra $3.60 on my 50k auto. Think about it.
Old Feb 11, 2012 | 08:44 PM
JoesC5's Avatar
JoesC5
Originally Posted by Mad*Max
I now exclusively use Shell V Power which here is 91 Octane sans ethanol. I swear that I get better mileage than the ethanol mixed gas.
You will, as 100% gasoline has greater BTU then gasoline diluted with ethanol. And if the ethanol in the gasoline has absorbed any water(very likely) then it will have even less BTU. On the highway, I see about 1.5 MPG better gas mileage when I run 100% gasoline vs E10.
Old Feb 11, 2012 | 08:55 PM
Jimmy W1's Avatar
Jimmy W1
Shell V-Power here. It's everywhere you go. I've never heard of Hess gasoline in 50 years of driving.
Old Feb 11, 2012 | 09:26 PM
GlennsVette's Avatar
GlennsVette
So Shell doesn't have ethanol?
My Dad calls me Mad Max but I look nothing like you!
Old Feb 11, 2012 | 09:28 PM
GlennsVette
My thought exactly I'll be heading to Shell tomorrow!
Thanks all!!!
Old Feb 11, 2012 | 09:47 PM
MKenM's Avatar
MKenM
St. Jude Donor '12-'13-'14-'15-'16-'17-'18,'21
Well I guess that you have never been to the Northeast. Leon Hess founded the company back in the 30's. At one point Hess owned the NY Jets football team. They are not a small company by any stretch.
http://www.hess.com/default.aspx
Enough about history. I use Hess premium in my Mercedes with no problems but I only use Shell premium in my vette.
Old Feb 11, 2012 | 10:33 PM
GlennsVette
I also only used hess in my SLK350, but I think I'll use shell in my vette also!
go jets, maybe next year!
Old Feb 11, 2012 | 11:25 PM
fnsblum's Avatar
fnsblum
The Shell station gas in my little part of the world has ethanol. That sucks! Later! Frank
Old Feb 12, 2012 | 12:53 AM
Vette5.5's Avatar
Vette5.5
Truth is, most gas is tranfered on the same pipeline to the region, but name brands put in their own additive packages, before delivery to the pumps. Name brands usually have better quality control and inspections for moisture content. If the owners manual says 91 or better octane, what you're wanting. While getting off topic, my sister was buying gas at the corner coffee stop, and not running good in the winter. Told her water, and buy gas elsewhere. She did, and all's well now.
Old Feb 12, 2012 | 02:42 AM
  #33
LS9Drew's Avatar
LS9Drew
I will only run Chevron 91 (CA has nothing higher) in my Z06 unless I can't find one then I'll use the 76 Gas Station. From my understanding the difference in gas is the additives of course, how "fresh" it is, and condition of the storage containers. I also won't use a pump that is all 3 grades in one, has to have a separate pump for each grade dont want ANY 87 getting in my car
Old Feb 12, 2012 | 04:14 AM
  #34
LS WON's Avatar
LS WON
Arco 91 octane
Old Feb 12, 2012 | 05:46 AM
  #35
RicemanZ06's Avatar
RicemanZ06
Chevron premium with techron to my Z.
Old Feb 12, 2012 | 06:22 AM
  #36
Don-Vette's Avatar
Don-Vette
Mobil 93 here,only because Shell V power is not around here.I use only Top Tier gas.
Old Feb 12, 2012 | 07:31 AM
  #37
joejoe440's Avatar
joejoe440
[QUOTE=GlennsVette;1579988503]
shell 93
To Which Gas
Old Feb 12, 2012 | 08:49 AM
  #38
gsflyer2011's Avatar
gsflyer2011
Originally Posted by Joe C5
I only run top tier gasoline as GM recommends. The different oil companies use different additives, some being better then others, but all must meet the minimum Government standards. Top Tier additives is a cut above the minimum required. GM used to recommend not using any gas additives, just to use a top tier gas, but they have now changed that. Chevron Techron is recommended(repackaged under the GM label) since all the gas tank sensor problems they had with the C5's. Those of us with that had C5's know that using Techron worked.
In addition to running nothing but top tier gas in my Z06, I also run a 20oz bottle of Techron through the tank once a year(and also my supercharged Mercedes).
Gas is gas other than for additives and chevron uses Techron in theirs. For that reason I have been using Chevron on all my cars for the last 25 years, never had a fuel related problem in any of them. The valves and the valve guides on my 140K mile Volvo look like brand new, no deposits whatsoever. Chevron is also on the GM's top tier list.
Old Feb 12, 2012 | 08:52 AM
  #39
C7Joy's Avatar
C7Joy
91+, I don't worry about brand and suspect that many come from the same place anyway....
Old Feb 12, 2012 | 09:50 AM
  #40
RobLo's Avatar
RobLo
Originally Posted by goatts
http://www.toptiergas.com/
I think you're safe with this.
Interesting, no Sunoco or BP (the 2 closest to me) on the list.....I use Sunoco because the company "supposedly" doesn't import from the Middle East. Didn't know about the Top Tier thing, I might have to rethink where I get my gas, also didn't know Shell V doesn't have Ethanol in it, great info on this forum!
