Which Gas
Bill
Bill
http://www.toptiergas.com/retailers.html
Bill
And if your definition of 100% synthetic oil is from 1970, it is probably out of date. At that time, 100% synthetic meant group 4 oil. A lawsuit between Mobil and Castrol which Mobil lost, has allowed the definition of 100% synthetic to be expanded to include group 3, which most experts agree is slightly lower quality. As a result of that, you can be virtually certain that if your “100% synthetic” oil does not specifically say group 4 on the can, it does not meet your definition of 100% synthetic from 1970 (or from 1990 either for that matter). This topic is discussed in more detail in a lengthy post of mine in the current thread called “Mobil 1 all marketing hype!”, so I will not repeat it here.
Excellent, thank you for posting, your article is a great read.
3 weeks ago I had to put an off-brand gas in an emergency, pumped 93 but within 5 minutes of getting back on the highway it was pinging under load (this was my 05') - added Techron and some Bel Mix-i-go when I got home, problem solved.
First thing I did when I bought the GS last week was add Techron to the 3/4 of a tank.
Toptier is primarily a detergent standard - but I did notice Costco is now advertising 5 times the required levels in their new clean fuel so I might give it a try.
I run either Shell or Chevron. Same for my wifes VW CC and Audi A6 before that.
If you drive 10,000 miles per year at 20 mpg, you burn 500 gals per year. If Premium costs 30 cents/gal more than regular, the Premium will cost you about $150/year. Doesn't seem worth the risk and reduced power, to me.
Fuel
Use of the recommended fuel is
an important part of the proper
maintenance of this vehicle. To help
keep the engine clean and maintain
optimum vehicle performance, we
recommend the use of gasoline
advertised as TOP TIER Detergent
Gasoline.
Look for the TOP TIER label on the
fuel pump to ensure gasoline meets
enhanced detergency standards
developed by auto companies. A list
of marketers providing TOP TIER
Detergent Gasoline can be found at
www.toptiergas.com.
The eighth digit of the Vehicle
Identification Number (VIN) shows
the code letter or number that
identifies the vehicle's engine.
The VIN is at the top left of the
instrument panel. See Vehicle
Identification Number (VIN) on
page 12‑1.
Recommended Fuel
If the vehicle has the 6.2L V8 engine
(VIN Code W), use premium
unleaded gasoline with a posted
octane rating of 91 or higher.
You can also use regular unleaded
gasoline rated at 87 octane or
higher, but the vehicle's acceleration
could be slightly reduced, and a
slight audible knocking noise,
commonly referred to as spark
knock, might be heard. If the octane
is less than 87, a heavy knocking
noise might be heard when driving.
If this occurs, use a gasoline rated
at 87 octane or higher as soon as
possible. Otherwise, you could
damage the engine. If heavy
knocking is heard when using
higher, the engine needs service.
(VIN Code T) or the 7.0L V8 engine
(VIN Code E), use premium
Why is so hard to read the manual? I read it before I bought the car, there are on line versions in case you are allergic to paper
Now the additives. They are added to the truck that delivers to the station. So even if you are in option #2 from above, if your station is advertising Chevron with Techron, or nitrogen enriched Shell, or some such thing, you can be 100% sure you are getting that company’s additives. Legal risk to the company would be too great for that not to be true. There are only two possible variations that I know of on that story. One is that sometimes, in remote areas or areas with only a few of that company’s stations, you might come across a Chevron station that just says Chevron, or Shell that just says Shell, with no posting anywhere in the station that says Techron or nitrogen enriched. In those few and unusual cases, you probably are getting gas from option #2, with just the standard EPA additive package. The other is that sometimes, you can get more than you pay for (but never less). That is happening if you see a delivery truck leave, for example, a Chevron station and then pull into a Wal Mart. In such a case, the Wal Mart store is getting the Chevron/Techron additives, not the standard EPA additives. But you have no way of knowing whether that is a contracted, routine procedure, or an occasional happening. You can be sure the Chevron station will always have Techron, but next delivery to the Wal Mart might be standard EPA additives. You would never see (unless you were witnessing an illegality) a truck leave a Chevron advertising Techron and then go to a Shell advertising nitrogen enriched.
Locally, we have a large storage terminal in Brookline, MO, that supplies not only Springfield, but a huge portion of southwest Missouri, and parts of Arkansas. Unless a station has a special gas (like the two Phillips stations that have ethanol free 94 octane premium) I doubt if the remaining stations are trucking in gas from Bartlesville, OK or Ponca City, OK or Derby, KS, when they can truck it from a storage terminal on the outskirts of Springfield that is supplied by a pipeline.
