upgrading interior speakers
Plain and simple: replacing 10 inch woofers with 6 inch "higher quality" is counterproductive due to the higher sensitivity of larger drivers and their ability to produce equivalent output and play lower with less power (until you reach their linear excursion limits). If you have not enough output, you can easily increase it by employing eithe first or second order high pass filters you can build yourself with great ease and for a few dollars using parts from digikey or even radio shack.
Considering the positioning of the midrange/high frequency drivers and their aiming, a premature rolloff at the upper end is actually a good thing, makes for more pleasant listening experience since even small dedicated tweeters would be rolling off quickly due to severe off axis and low positioning and the results would be worse than those paper cone drivers deliver.
If you need to gain better end extension, you could again build some first or second order hi pass filters, tap into the current speakers and perhaps try to mount some tiny supertweets in the side vents, all you would need would be about 12k up freqs playing to extend the upper end.
The center channel is actually very useful when stock speaker locations are used, it helps to make the stage more symmetrical with the listener by by making the stage narrower and thus reducing the offset with the opposite side. The center channel also helps to create illusion of music playing out higher up and to a degree, improve stage centering and imaging detail.
There is no stereo effect to speak of in any car unless it has a center seating position. When drivers are pointed at each other, you end up with a textbook definition of hard panned mono that is centered in the middle of the car and at the height well below your ears, with completely no acoustic crosstalk, this is why you hear sounds well located at the passenger side door while sitting in the driver seat and then you hear them right next to you on your side. Center channel helps to reduce this difference, you lose width but you gain more symmetry.
There is considerably more to this but I do not feel like writing a book. This information is readily available and easy to verify through practical experiments, including using earphones and simulated car listening environment setting. Alternatively, you can hide your head in the sand and follow the rest of the sheep.
Now, based on this post, I actually have a legitimate sound stage question for you. You already know a fair bit about my install, let's not get into how much you disagree with what I've done thus far. It is what it is, and I'm very happy with the result with one caveat: I'd like to move the sound stage up a bit without TOO MUCH effort. Above, you suggest supertweets in the vents. Can you elaborate? Mount position, angle? I was leaning towards a pair of supertweets as well, or just to add a center speaker. Keep in mind that I never had a center speaker, it's not like I removed it. I haven't taken the grill of to find out what the deal is, whether the speaker was removed, blown, etc. If I end up going with a pair of supertweets, I had initially thought of mounting them in the top corners of the windshield pointing towards the windshield itself, ala CDT upstage style. I know there are many people that have utilized this design, and it has its own benefits and drawbacks. I'm just not sure if I would want the headache of trying to equalize the windshield reflections, etc. However, I see other potential problems by mounting them in the vents, depending on what you had in mind with the install.
I know the easiest answer would be to just buy the supertweets and experiment with placement, which is what I'll probably do, but I wanted your take on it.
Olive branch.
I think I am gonna hit some sanding blocks before rain comes
Your happy with the factory crap in your car, that's fine. Everyone who has changed it I'm sure is happy with the results and think it's money well spent, including myself. You can't sit there and try to tell everyone they aren't happy with the sound because it's staged wrong. Who cares.
You and anyone else who thinks there is something outstanding about their effort should have no issues... Now, I really need to do some sanding. In real life, I spend very little time behind computer or laptop.
Now, back on(sorta) topic. Does it make a pretty good difference to unhook the center speak in the dash? I hear it does. Any thoughts on that?
1.) I have two systems.
2.) Something in the second system is different than in the first.
3.) The two systems are exactly the same.
This is why you guys need to stop arguing with him.
Olive branch.
You are all witnesses, I really, really tried with this guy. I actually had a legitimate sound stage question, and he could provide no response except the one above. So much for his "knowledge"... What an a$$bag. He just keeps preaching his theoretical bs without providing any actual rebuttal to a single counterpoint anyone has made, muchless when I ask him a question in his supposed area of expertise... Of course, I'm sure he'll bounce back and say "none of the counterpoints provided are worth addressing" or some similar lame *** excuse to hide behind in order to avoid providing any ACTUAL knowledge on the subject. He's already done it countless times and I don't see this changing.
It has been fun keeping this thread going long enough to discredit "odd Peter" beyond a shadow of a doubt. Actually, "long enough to let him discredit himself" would be more accurate. Of course this thread is just another to add to the list.
If you initially intended to answer my question, why did you jump into the forum, throw a jab, then jump back out?semi-objective opinion, SUPER BASHING, semi-objective opinion, SUPER BASHING... you're as bi-polar as anyone.
I'll legitimately thank you for your response, though you honestly didn't actually answer most of my question which was asking about your supertweeter idea, and your thoughts on other potential mounting locations vs using a center speaker.
I'm finally done with this one, have fun everyone.
