"block it"
Old Jun 7, 2013 | 01:43 AM
  #61
3 Z06ZR1's Avatar
3 Z06ZR1
Originally Posted by LS WON
I disagree! Good way to cut some noise and removes in less than a minute!
Like I said put one in the back and the two behind the seat pieces.
Drive daily then remove them after a week.
Plain to see they work as advertised! Make the radio better and cuts tire noise!
Old Jun 7, 2013 | 06:26 AM
  #62
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Ok folks.....just like everything else not everything works for everybody....if you have a stock car this product probably works better than if you have a heavily modified car. I think if you buy this product and expect your car to suddenly be whisper quiet like some hybrid you won't be happy. It is not the be all end all for a nosie problem you probably created by modifying your car. My 99 was just fine until I decided it needed headers and a Borla exhaust...guess what....its not quiet inside anymore and in fact it can be damn annoying....I'm sure that if I added this product it would help but not totally cure the issue I created. You need to be realistic.
OP I wish you luck in your decision but I am closing this thread as it has turned into a running debate which even includes some vendor bashing and this isn't the place for it.
a simple search will turn up a lot of threads reviewing this product...many people like it.....many people like clear bras and I think they look like crap point is everyone has an opinion on what is good and what isn't.
