Correct you are. Candy paints, IIRC, are a base of gold (sometimes silver) followed by a "candy" color and topped with clear. A three step process, much like some of the extra cost colors offered on Vettes.
Yes, exactly, and it should cost no more than the Crystal Red Metallic paint which is about a $500 option.
Originally Posted by 1rusty1
Ahhh full circle. I am not talking a standard metallic paint job. I am talking candy apple done right and what I was referring to in my original post. See in bold.
I know your not talking about a standard 3 step metallic paint job, but I AM.
You keep referring to very expensive hand rubbed lacquer paint jobs.
It's like I'm talking about bananas, and you want to talk about oranges.
The others get it, but you don't for some reason.
Like I said, it's all good, this really isn't very important anyway.
Originally Posted by Cybernetic Medic
Back in the day the true Candy Apple paint jobs were very difficult to do really well... hence the higher cost. It's true that a modern tint coat paint job is not that big a deal but now it's done by robots that once programed, always get it right. The trick is to lay down that perfectly even tint coat.
that car is bad *** an its exactly the over kill im shooting for. the extra wide rear fenders are needed for the extra wide rear wheels 20x13 I believe . it looks like a vette on steroids an I love it .
Why does everyone keep saying "rear fenders"?
There's no such part on any car. It's the rear quarter panel. http://www.westcoastcorvette.com/p-1...FVCVfgodIakAQg
Come on guys, get with the program, "rear fender" is a bastardized laymen's term.
Gotta call ya on that one...look at maybe a '32 Ford and those things covering the back tires would be...ta da...fenders.
Corvettes...not so much.
: a curved piece of metal that covers a wheel of a motorcycle or bicycle
Dictionary Spelling Help
quarter panels
The word you've entered isn't in the dictionary. Click on a spelling suggestion below or try again using the search bar above.
quarter sessions
quarter note
quarter tone
quarter rest
That's true, but how does that relate to my comment???
I said,...
"It's really just a base coat metallic, then color, and topped with clear.
Yet for some reason, it's always considered an exotic, expensive, color."
What I'm saying is, the Candy Apple Red color is just another color. No different than Crystal Red Metallic, or Night Race Blue, or Blade Silver.
All of those colors, and hundreds of others, look beautiful from the factory.
They are very common, not considered exotic, and do not cost thousands extra to order.
Yet, when it comes to Candy Apple Red, expect to pay a hefty premium as though it was some extra labor intensive process to produce.
If anyone knows why it's so expensive, please tell me, I'd like to learn.
aside from the top coat varying in color depending on what color base or ground coat you use, candy apple paint is a translucent color and changes in darkness by the amount of coats you put on until you reach your desired shade of color, in other words it gets darker and darker the more you put on, with any standard paint you can apply a hundred coats and the color will be the same when your done, the paint itself is also very expensive more than your standard paints, it is more difficult to spray when you spray a standard color you may start at the top of the car, then go to the hood, then the fender , the door, the quarter panel, each coat over lapping at the fender seam and door, quarter panel and door etc, on a candy apple paint job your supposed to go down the entire side of the car not overlapping those areas as you get darker spots in those areas, i painted one candy apple paint job and it takes quite a bit more time to do, but looks beatiful when done right.
