Ok, I'm starting to notice that my stock car battery is starting to loose some strength. What car batteries do you all recommended? Thank you in advance.
I've learned the hard way there are two ways to look at this.
1) You can buy the best of the best battery and pay twice as much as the average battery and maybe get an extra 6 months to a year of life out of it
or
2) By a comparable average battery (AC Delco, Exide, etc.), spend right around $100 (less if you watch for sales) knowing every 3-4 years you'll be replacing batteries
Moral of the story is our vettes chew up batteries. I don't drive mine a lot and when my first battery went out I thought I'll fix this and spent close to $200 on a premium interstate battery toted to be among the best in the industry. Even with the car being plugged into a battery tender when not in use I got just under 3.5 years on that $200 battery.
Then I figured why spend that much on another battery when it's just going to die anyways in a few years so I bought an el-chepo AC Delco battery ($92) matching the cars specs and put that in and with the same process in mind (battery tender attached while not in use) I got another 3.5 years out of it.
I just bought the same AC Delco again in October this year figuring in 3.5 - 4 years I'll have to replace it again.
A better battery won't cure the electronic drain these cars have. In my opinion / experience it makes no sense forking out the extra cash.
The other two threads on the first page on the same subject will provide you with all the info you need to be even more thoroughly confused.
Optima has worked well for me in the past.
I like the idea of it being sealed, no leakage.
Had a Yellow Top in the 4Runner that lasted 11 years in a daily driver. Changed it out heading into a Winter just because I figured I got my money's worth and didn't want any surprises. Oh and I ran an 60 amp draw RF amp too with it.
I've had an Optima yellow top in my 2007 for about 5.5 years now, and I have not had any issues with it. Very pleased with it. Yes they are more expensive, but I live in a climate where I can't drive my car year round, so it's sits on a CTEK battery charger for the winter months. I would recommend it.
There are many quality batteries out there to choose from. A well maintained battery is critical to longer battery life. I keep a battery tender on mine if the car isn't going to be driven for several days. While in winter storage, which can be about 4 months where I live, the tender is on it the entire time.
or
AC Delco has lasted me 4-5 years, on a tender of course. I found the same thing with my Harley's, went cheaper and replace them every year or two or go with the Harley (not sure who makes it for them) and they last at least 3 years. I'm sure you are aware a tender is the key for our cars...
I do the same as this,bought a new Delco Battery for my 09 in Sept,16
It isn't so much the battery as it is the battery tender. I would go with the AC Delco, guaranteed to fit and reasonable cost. I would then look for a battery tender that has a float voltage of about 13.2 volts, or as close as you can get. Big hint, check Deltan and compare with the others you find in the marketplace.
Original lasted six years, died in my garage. Put another AC Delco in and used it for five years. Changed it out just for peace of mind, it was working fine. On my third now. No reason to change. Never used a tender either. Also, my dealership was at or close to the best price so no reason to change.
seems like AC Delco is the way to go. Where did you all get it at the dealership or auto parts stores?
