Security system, 2005 c6, Help Please..
Old Jan 20, 2017 | 08:26 PM
  #101
Jason W Dreher's Avatar
Jason W Dreher
Unbelievable.. Here at the dealer, ready to drive away and the power seat doesn't work but, when I get out of the car, not sitting in it, the seat works.. Bottom line the seat doesn't work sitting in it and works not sitting in it.. I had to leave it to find out something Monday.. �� Wow...
Old Jan 20, 2017 | 08:30 PM
  #102
bartsky's Avatar
bartsky
Sounds like something is not making contact with your weight on the seat. The module that controls everything is right under your rear when sitting in the seat.
Old Jan 20, 2017 | 08:33 PM
  #103
RICH 28's Avatar
RICH 28
That sucks. Have you ever had problems with the seat before? Probably just a loose plug, I hope.
Old Jan 20, 2017 | 08:39 PM
  #104
Jason W Dreher
Interesting.. I hope it's little.. If they charge me I won't be happy.. It should have been back to normal.. Do you think this has anything to do with the radio replacement?
Old Jan 20, 2017 | 08:44 PM
  #105
bartsky's Avatar
bartsky
It is easy enough to pull seat bottom cushion up to expose the module and all the wiring to see if anything is not making good contact. These cars have soo many different modules. Is your driver seat bottom worn down?
Old Jan 20, 2017 | 08:49 PM
  #106
Jason W Dreher
I don't think it's worn, normal wear if anything.. The car only has 44k on it... I had no clue there was a module under there.. Is it possible that it has any connection to the replacement of the radio?.. Just seems odd this happens right after it gets fixed..
Old Jan 20, 2017 | 08:51 PM
  #107
Jason W Dreher
Never... I hope you're right..
Old Jan 20, 2017 | 08:53 PM
  #108
bartsky's Avatar
bartsky
I don't see how they would be connected, unless tech was heavy guy and caused when he was in driver seat. I have also seen seat wires comes loose when moved back too far.
Old Jan 20, 2017 | 09:32 PM
  #109
Jason W Dreher
Good deal. Thanks for the info.... I'm just frustrated because I excpected to have the car back now it's sitting in the shop again..
Old Jan 20, 2017 | 10:07 PM
  #110
joec's Avatar
joec
there's a connector under the seat that can cause problems like this... Hopefully it just needs to be snapped back together and tie wrapped..
Old Jan 21, 2017 | 08:47 AM
  #111
Jason W Dreher
Thanks.. Hopefully that is just it since it still works when not sitting on it.. I actually forgot to mention to the dealer that I noticed the steering wheel doesn't work as well. I tried to adjust it right before leaving as well and it was dead.. Do you think there is any connection there?.. I'm calling them in about 15 mins. When they open.
Old Jan 21, 2017 | 09:13 AM
  #112
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
Yes, there is. It usually is the wiring connection under the seat and can come loose when the seat is moved. The dealer needs to check the connection and "lock" it with plastic zip ties.
Old Jan 21, 2017 | 09:26 AM
  #113
bartsky's Avatar
bartsky
Yes the telescoping is controlled by the seat module as well.
Old Jan 21, 2017 | 09:29 AM
  #114
Jason W Dreher
Thanks ruxvette and bartsky. :-)
Old Jan 23, 2017 | 09:00 AM
  #115
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Interesting. It is the BCM computer that tells the radio to turn on or off by instructions through the digital network but it is the computer in the radio that actually turns the power on and off to the other units. It is surprising that the radio would still work if that computer was not functioning correctly. It decides when to power the aux amp and the antennas. But if it were letting all the other units run then I guess it is possible. How this fixes the issue.
Old Jan 23, 2017 | 11:32 AM
  #116
lovinmyls1's Avatar
lovinmyls1
With all that the original radio does, its amazing that any aftermarket radio will work in these cars.
Old Jan 23, 2017 | 09:59 PM
  #117
Jason W Dreher
Yeah, he said there was a short in the radio that made it continuously run. You could totally hear it when the cr shut off. It sounds like the cd player was ejecting the cd continuously. Honestly, it was going on for the 2 years and I thought it was normal. Ot would make the sound and sometimes it wouldn't after shutting off the car.. It must have finally burned out the radio.. I did get the car back tonight thank God.. :-)
To Security system, 2005 c6, Help Please..
Old Jan 23, 2017 | 10:00 PM
  #118
Jason W Dreher
I was thinking the same thing.. I searched the heck out of this subject and found nothing which makes me believe this isn't very common..
Old Jan 23, 2017 | 10:36 PM
  #119
C5 Dude's Avatar
C5 Dude
Originally Posted by CorvetteBrent
I have learned a lot by reading this thread/series of posts. I hope the radio replacement will absolutely and permanently solve the problem.
Wow! Same here! I would have never thought a radio would cause this much af an electronic gremlin. My next question would be if you don't mind me asking.... With all the labor and a new radio, what did this set you back?
Old Jan 24, 2017 | 08:18 AM
  #120
FortMorganAl
None work completely to replace a nav unit. To just replace the radio requires jury-rigging and is not a task for the novice.
