SuperVettes rear diffuser problem
Old Mar 27, 2017 | 10:33 PM
  #41
vetten76's Avatar
vetten76
Originally Posted by poughkeepsie
now that is a beautiful car
The tires say Corvette? Really cool car....
Old Mar 27, 2017 | 10:49 PM
  #42
vetten76's Avatar
vetten76
Old Mar 28, 2017 | 07:40 AM
  #43
tri08sbc's Avatar
tri08sbc
This may sound dumb, sorry, but can you turn the bolts around ?
Old Mar 28, 2017 | 08:09 AM
  #44
mcandrew67's Avatar
mcandrew67
2016 Corvette of Year
2015 C6 of Year Finalist
Originally Posted by c6z51man
I cut about 3inches off, I had no choice it was hitting the sway bar bolt and still is a tight fit, idk what going on with this diffuser maybe just a bad one who knows. Idk how I'm going to mount it gonna have to be some custom thing. Can you guys with this diffuser take a pic of how close it comes to sway bar bolts to maybe see what's going on with mine... thanks
you can't just put shorter bolts in, they stick out so far?
Old Mar 28, 2017 | 08:21 AM
  #45
c6z51man's Avatar
c6z51man
Worth a shot, thanks!
Old Mar 28, 2017 | 01:07 PM
  #46
p2toy's Avatar
p2toy
Originally Posted by COMMANDER2OOO
Here is mine, I had to trim nothing.
Definitely beautiful!!!
Old Mar 28, 2017 | 07:18 PM
  #47
pokerpro's Avatar
pokerpro
2021 C6 of the Year Finalist - Modified
2020 C6 of the Year Finalist - Modified
Here's a few pics of the bottom of mine. Sorry but the car was on the ground so they are no perfect. Hope this helps.
Old Mar 28, 2017 | 09:38 PM
  #48
COMMANDER2OOO's Avatar
COMMANDER2OOO
2017 Corvette of Year Finalist
2016 C5 of Year Finalist
OK put a mirror under the car so you can see how it bolts up, and reverse lights.
Old Mar 28, 2017 | 10:43 PM
  #49
tri08sbc's Avatar
tri08sbc
Keep us posted.
Old Mar 29, 2017 | 10:05 PM
  #50
c6z51man's Avatar
c6z51man
Originally Posted by Supervettes LLC
it looks like you're trying to pull the bottom of the diffuser up too far. The flat bottom (side sections) should be parallel to the floor, looks like they will slant upward if you are attempting to pull it up too high? The bottom of the diffuser should have touched the bottom of the sway bar as it was shipped. As mentioned earlier, you can tie it to the sway bar, with industrial strength ties to avoid flapping from the air flow, or trim tat section out, but I wouldn't recommend trimming as much as you did. From this point, I would make some L-brackets out of steel strip (you can pick some up at Home Depot), and bolt the long end to the diffuser, and the shorter side of the "L" to the cross member.
I understand what your saying but basically when the diffuser clipped in from the front and screwed in from the sides that's where it was left to hang. If I placed the diffuser from bottom away from sway bar bolts it would not connect from front or sides.... idk would you be willing to ship another one. Don't know what else that can be done? Obviously it fits or doesn't. Base,z06 and zr1 doesn't matter right? I do have the base z51...
Old Apr 1, 2017 | 07:27 PM
  #51
c6z51man's Avatar
c6z51man
Little update went to install my johnny o'connell rear sway bar and this did not help my situation with this diffuser. Now since it's thicker the diffuser is hitting the sway bar so now I would have to trim more for it to fit. What a headache this is turning out to be. Is this diffuser not supposed to fit with aftermarket sway bars???
Old Apr 1, 2017 | 07:54 PM
  #52
COMMANDER2OOO
Man I'm sorry to hear your having such a hard time with this, I have the Hotchkis sway bars and they are also thicker than stock, but no problems with diffuser installation.
I really hope you get this sorted out because that is a great looking diffuser. I even like yours better then my own lol.
Old Apr 2, 2017 | 11:19 PM
  #53
c6z51man's Avatar
c6z51man
I need pic with guys with the 2 tip. 4 tip is obviously shaped differently around sway bar area compared to 2 tip. Will be calling SV tomorrow. Getting tired of this ��
Old Apr 3, 2017 | 11:27 AM
  #54
tri08sbc's Avatar
tri08sbc
I guess the bolt reversal didn't work ?
Old Apr 3, 2017 | 03:22 PM
  #55
c6z51man's Avatar
c6z51man
That's probably going to work I trimmed enough for that to fit but now it's hitting the actual sway bar cause it's bigger then stock
Old May 7, 2017 | 06:34 PM
  #56
c6z51man's Avatar
c6z51man
More trimming then I wanted to, but very happy the way it looks!
Old May 7, 2017 | 07:33 PM
  #57
tri08sbc's Avatar
tri08sbc
Looks pretty damn good if I do say so.
To SuperVettes rear diffuser problem
Old May 14, 2017 | 02:04 PM
  #58
Tarheels1's Avatar
Tarheels1
Ditto!
Old May 14, 2017 | 09:59 PM
  #59
vetten76's Avatar
vetten76
Originally Posted by Tarheels1
Ditto!
Ditto. Ditto! It looks really good.
Old May 15, 2017 | 09:55 AM
  #60
choppychop's Avatar
choppychop
Wow, that was worth the trouble...
Looks very good!
