2008 corvette windows not working
Old Apr 26, 2017 | 01:31 PM
JCola's Avatar
JCola
4th Gear
Default 2008 corvette windows not working
So I have a 2008 Corvette convertible, in storage all winter. Went to take it out last week, battery was dead (obviously). I boosted it and ran the car but both windows wont work at all. They are both stuck slightly down (when I opened the doors). Both window buttons on the driver door panel, and the one on the passenger panel do nothing. The windows don't move at all. Suggestions?
Old Apr 26, 2017 | 01:33 PM
Corvette_Ed's Avatar
Corvette_Ed
You need to index the windows. The procedure is in the owner's manual. This has to be done any time the car loses battery power.
Old Apr 26, 2017 | 01:34 PM
Homer3D's Avatar
Homer3D
You need to re-index your windows.
https://www.corvetteforum.com/forums...-indexing.html
Old Apr 26, 2017 | 02:00 PM
JCola's Avatar
JCola
4th Gear
I understand how to index the windows.. problem is, the windows won't move at all, up or down. I've also tried to just hold the window switch in the up position like it says, but I get nada.
Old Apr 26, 2017 | 02:27 PM
65GGvert's Avatar
65GGvert
Follow the procedure anyway. Hold, release, then hold. Up and down. Whether they move or not, follow the instructions.
Old Apr 26, 2017 | 02:35 PM
JCola's Avatar
JCola
4th Gear
Ok. Will try.
Old Apr 26, 2017 | 02:37 PM
65GGvert's Avatar
65GGvert
Ok. Will try.
If they still don't move, I'd disconnect the battery again for a few minutes, then reconnect and try the procedure again. After that, you're probably into electrical troubleshooting (relay, etc)
Old Apr 26, 2017 | 02:44 PM
JCola's Avatar
JCola
4th Gear
Thanks. I tried but I think the driver's side window switch is actually not working.. I'll have to do some troubleshooting. I did notice that my anti-theft light (car with the lock through it) is on and stays on. The car starts and runs so I'm not sure what's going on with that now.
Old Apr 26, 2017 | 02:46 PM
windyC6's Avatar
windyC6
Boy.....I sympathize with ya on some of these post. I don't know why anyone would suggest to index your windows when that involves moving them up and down and you said they won't move up and down. Kinda like trying to call the phone company to tell them your phone ain't working......good luck, and keep us posted on the fix.
Old Apr 26, 2017 | 03:04 PM
65GGvert's Avatar
65GGvert
Because after a battery disconnect the windows must be reinitialized (that makes the indexing work properly) If the window doesn't know which is up and down, if you sit in the car with the door closed and in acc or on mode hold the switch both up and down, the window will start to move and reach the stop. Holding the button an additional 3 seconds confirms the stop, then do the other direction.
If the door isn't closed, the window may not move because it has lost position information.
It's free to try and sometimes works. How do YOU let the phone company know your phone isn't working? Write a letter?
Old Apr 27, 2017 | 09:32 PM
pind's Avatar
pind
Did you find a fix? My car is doing the same thing. Anti-theft light and no response from the driver door panel. My passenger window works but nothing from my driver door controls. door open button is the only things that seams to be working.
Old Apr 28, 2017 | 10:35 AM
windyC6's Avatar
windyC6
Oh heck no. I won't write a letter, i'll just hold the phone up to one ear and the the other back and forth and then it should start working sooner or later.......Help us Mr. wizard !!!!......
Old Apr 28, 2017 | 12:09 PM
65GGvert's Avatar
65GGvert
Where are your suggestions? Or do you just troll around to criticize? I wouldn't have offered if it hadn't worked before.
Old May 10, 2017 | 12:20 PM
pind's Avatar
pind
sooooo nothing in my driver door would work except the button to open. I also had a security light on. The fix i found was a broken red with white stripe wire between the door and the body. I pulled off the door panel and removed the door speaker. I also removed the seal trim and a cover just above the hood release. There are two connections there that can be undone and allows you to pull the wires back into the door. I then undid the loom and found the wire. Hope this is helpful to someone, took me forever to find lol
To 2008 corvette windows not working
