Jacking point
Old Feb 3, 2018 | 11:39 AM
madsonp's Avatar
madsonp
Originally Posted by Corvette_Ed
They didn't have the frame rails like modern ones do, no, and had a lot of flex to the body. Iirc, the C4 was the first generation with full frame rails.
Weren't some of them unibody's ?
Old Feb 3, 2018 | 11:47 AM
fake's Avatar
fake
Real corvettes have full frames C1,C3, C2, From C4 on Uni Body A Pie Plate on Wheels!
Old Feb 3, 2018 | 11:48 AM
mikeCsix's Avatar
mikeCsix
One word of advice, supporting the car front and rear on the suspension cradle alone is not a good idea because the support base is too narrow. It is better to support the car at the shipping lock locations, either both front and rear or front or rear.
I made my own cross beams for my Costco jack using 2x4 steel tubing, then would use jack stands under the tubing. Doing this front and rear doesn't give a wide enough base for support.
Old Feb 3, 2018 | 11:53 AM
madsonp's Avatar
madsonp
I got one of these. https://www.harborfreight.com/steel-...eam-60762.html
Old Feb 3, 2018 | 12:32 PM
mikeCsix's Avatar
mikeCsix
Originally Posted by madsonp
I think I'm going to go the QuickJack route. Just the labor savings of doing my own header install will help pay for much of it not to mention the brake work I do.
Old Feb 3, 2018 | 12:52 PM
Corvette_Ed's Avatar
Corvette_Ed
Old Feb 3, 2018 | 01:23 PM
Mad*Max's Avatar
Mad*Max
Originally Posted by EVRose
You can put a jack under one of them and lift that whole side of the car.
Old Feb 3, 2018 | 11:41 PM
buckmeister2's Avatar
buckmeister2
I wonder if he'd be interested in selling his headers
I have a feeling he is not interested in anything anymore. I wonder if the right front tire caused the accident, or was destroyed in the accident...
Old Feb 4, 2018 | 12:45 AM
CaPilotMark's Avatar
CaPilotMark
Dude, that's just brutal...
Old Feb 8, 2018 | 02:35 PM
custompainter99's Avatar
custompainter99
Do you need a puck to jack it up on the side?
Old Feb 8, 2018 | 02:50 PM
madsonp's Avatar
madsonp
You should have something there so you don't damage the rocker panel, you could just make your own by using a 2x4 block of wood.
Old Feb 8, 2018 | 09:32 PM
mikeCsix's Avatar
mikeCsix
Yep, some use hockey pucks, others use professionally manufactured ones, mine are aluminum and mounted in the shipping locks so I won't have to make sure the dealer or whomever doesn't screw up and break my rocker panels.
Old Feb 8, 2018 | 10:06 PM
  #33
LowRyter's Avatar
LowRyter
The tire store opened the doors and opened the hatch when they jacked it up..
Old Feb 8, 2018 | 10:19 PM
  #34
EVRose's Avatar
EVRose
Not necessary.
Old Feb 9, 2018 | 01:09 AM
  #35
LowRyter's Avatar
LowRyter
good to know
Old Feb 9, 2018 | 05:48 AM
  #36
69 L46 4 Speed's Avatar
69 L46 4 Speed
I had the body off of my 69 and it has a full length boxed frame. All Corvettes have a full frame. The difference is the manufacturing process that allows the newer frames to be stiffer than previous generations.
Old Feb 9, 2018 | 10:38 AM
  #37
windyC6's Avatar
windyC6
Great point !!! I've always done the math when it comes to getting a new tool to do the labor myself compared to having it done. Now if i could just get the wife to understand the reasoning !!!!.....
To Jacking point
Old Feb 9, 2018 | 11:02 AM
  #38
flyeri's Avatar
flyeri
Exactly.
Old Feb 9, 2018 | 11:39 AM
  #39
itomh's Avatar
itomh
I love this forum, members are willing to go out of there way to assist others at their own expense!
Old Feb 9, 2018 | 02:55 PM
  #40
LowRyter's Avatar
LowRyter
That should buff out.
