Oh Help Help Help
Old Sep 21, 2019 | 10:23 PM
Got Juice?'s Avatar
Got Juice?
Default Oh Help Help Help
I have a 2006 Covette LS2 Love the car. Impressed with the reliability, handling, power and Fuel economy.
Currently I have some 100,000 miles on it And I am perfectly happy to keep her and put on another 100,000.
BUT
Just came across a 2012 ZR1 in the ugly blue color (not blue devil blue) it has 20,000 miles on it. Looks in primo shape. Dealer wants it gone at 64K .
If you could... would you?
To ZR1 Owners, do you miss the fuel economy of the base car? Any regrets?
I need to be either talked into it or out of it.
Old Sep 21, 2019 | 10:36 PM
jimijam's Avatar
jimijam
guess posting this in the ZR1 forum isn't an option.
oh yeah, some love that blue. i think its called fuel economy blue.
so you may spend 44K more than your car is worth, but you have to be talked into it?
Old Sep 21, 2019 | 10:37 PM
Got Juice?'s Avatar
Got Juice?
I am out of my depth to be honest... so I seek the wisdom of others
Old Sep 21, 2019 | 10:42 PM
TBIRD57's Avatar
TBIRD57
64k??????????????????????????? imo that would be better served toward a C8 in the not too distant future!
Old Sep 21, 2019 | 10:55 PM
jimijam's Avatar
jimijam
^ great point.
Old Sep 21, 2019 | 11:00 PM
Bruze's Avatar
Bruze
Hmm, $64k for a mildly-optioned new C8, any color -- or $64k for a clean C6 ZR1 with any color except the one above.
That would be a tough call.
But being old and not caring about max performance anymore, and having liked the looks of European MEs long before the C8 came out, I would probably go for the C8. But I don't think it will fit in my barn, heh.
Old Sep 21, 2019 | 11:05 PM
Got Juice?'s Avatar
Got Juice?
Not that it matters much, but that 64K is in Canadian dollars. So when compared to a C8 that will be 80k here in our money........ there is the temptation.
Oh and it has 3 pedals
Old Sep 21, 2019 | 11:59 PM
TorchRedFred's Avatar
TorchRedFred
That's about $48k in US dollars. That's a pretty good deal for a ZR1. I actually like the color. Now I want it. Someone talk me out of it please.
Old Sep 22, 2019 | 12:03 AM
jackjohnson_218's Avatar
jackjohnson_218
I've seen that car posted on kijiji. $65k is asking and it's been posted for a couple months at least now. Given the time of the year, season is pretty much done for us in Edmonton, so you should have some good bargaining power. Best of luck in whatever you decide.
Old Sep 22, 2019 | 12:05 AM
Got Juice?'s Avatar
Got Juice?
HAHAHAHAHA... enabler you are.
I am thinking of heading up on Monday or Tuesday to take a look. And I do plan to bring the checkbook just in case.
Old Sep 22, 2019 | 12:08 AM
Bruze's Avatar
Bruze
RED FRED, GO TO BED!
Old Sep 22, 2019 | 12:09 AM
Chris J's Avatar
Chris J
I would go with the ZR1, don't see how you can go wrong on that one!
Old Sep 22, 2019 | 12:11 AM
Dano523's Avatar
Dano523
I really like the ZR1's, but not if I am having to pay the maintenance bill to run it.
Hence just price the cost of the rotor, which have to be replaced when they go bad, since they can not be turned to clean them up.
Next is that the car has a F55 system in it, and when a shock goes bad, you really want to replace it with another MRC shock since the F55 system is that good on that that car.
As for road coarse work, the LS9 has way more torque that the car suspension can handle, so even in a experts hands, you still run the car with ptm at 4/still burn the hell out of the tires on hard drives out of the corner. Hence at 2K, the motor is dam near at 600lb of torque of linear power and just want to roast the tires every chance it gets (even with PTM cracked down) So trust me, when you are smoking super cups are close to 2K a set on the quick side, even replacement tires gets speedy real quick.
As for ZR1 or Z07, Z07 every day of the week the way I use a Vet for road course work.
You can still get over 600hp out of a LS7, but the motor's torque curve is a lot more usable that the LS9's.
Old Sep 22, 2019 | 12:14 AM
TorchRedFred
Bruze, what are you doing here? I thought you would be out drinking a Guinness with some of those barmaids you are always talking about. It is Saturday night.
Old Sep 22, 2019 | 12:17 AM
Got Juice?'s Avatar
Got Juice?
My 06 is plain jane standard suspension It handles it's power reasonably well. I commute a lot, and DD in the summer months. That being said, I am never shy when passing on 2 lane roads and exploring the upper reaches of my tuned LS2. Currently it sits at 390RWHP with just bolt ons and some EFI Live tuning.
How often do the Carbon rotors and pads need changing?
Old Sep 22, 2019 | 12:37 AM
Dano523's Avatar
Dano523
All depends on how you drive the car, but if the car is just for street use, pull the CCM rotors (to put back on when you go to sell the car) and replace them with steel rotors instead. Hence you can get a full set of rotors for the cost of just one carbon fiber rotor. Same with the pads, since the OEM's are going to be over kill for the street as well.
As for tires, still going to need tires that will stick with the amount of torque that the LS9 makes off the bottom, so no getting around that one with a cheap set.
And one last thing, guys tend to be hard on the LS9 clutches on used cars. On the LS9 clutch, you can tell how much wear the clutch has, but the amount of force it takes to use it. Hence the more the clutch is worn, the harder the pedal gets using it.
And no, no extended warranty covers the clutch, nor brakes and rotors, not tire wear.
So if you are thinking this to try to save you, think again since none of these parts are covered under any warranty.
Bottom line, the selling point on the C6 corvettes, is the lower mantinace cost verses the imports; Barring the Zr1 model that has a much higher maintenance cost instead. Its not as bad as say an Austin Martin or Ferrari, but is much more than the standard C6's instead.
Old Sep 22, 2019 | 01:09 AM
hawkgfr's Avatar
hawkgfr
me 2 lol
To Oh Help Help Help
Old Sep 22, 2019 | 01:38 AM
Got Juice?'s Avatar
Got Juice?
Originally Posted by hawkgfr
me 2 lol
do I get a finder's fee? LOL I can even drive it down to ya.
Old Sep 22, 2019 | 07:10 AM
BadAV's Avatar
BadAV
Save your money and buy a C8. The in-your-words ugly blue is the reason it is still for sale. Now you have what my choice would be; it's a no-brainer.
Old Sep 22, 2019 | 07:51 AM
03BlkZ's Avatar
03BlkZ
In my opinion if you have to ask people here for essentially the blessing to buy a car then it is not the one. Save your money u till you find so.ething that is right for you.
