T56
Old Apr 7, 2021 | 07:33 PM
joevette perdomo's Avatar
joevette perdomo
Default T56
What trans oil for an 05 stick shift c6, I know dextron vi is specified but has anyone tried royal purple or other after market atf's with better smoother shifts?
Old Apr 7, 2021 | 08:16 PM
VolSince69's Avatar
VolSince69
I’m running Redline D4 ATF. Here’s a couple of threads that may help...
https://www.corvetteforum.com/forums...ndation-2.html
https://www.corvetteforum.com/forums...t56-fluid.html
Old Apr 7, 2021 | 08:46 PM
joevette perdomo
Thanks for replying after reading 10 mins of opinions it looks like Redline or amsoil!
Old Apr 7, 2021 | 09:17 PM
Rocketmanwpb's Avatar
Rocketmanwpb
I use Dextron VI. I tried Royal Purple once but went back to the Dextron. I got better shifts when I changed out the shifter.
Old Apr 8, 2021 | 01:33 AM
Cherokee Nation's Avatar
Cherokee Nation
Waste of money and your time to change to a different oil...Do as said above change the shifter.
Old Apr 8, 2021 | 06:08 AM
VolSince69's Avatar
VolSince69
Agree, shifter is a mod that will make a far more pronounced difference. MGW seems to be preferred by most here. Have one and love it! Tried anti-venom mod too, but went back to not using the copper spacers. Prefer that feel.
Changed fluid a while after shifter install. In my case RL D4 ATF does feel better. It’s subtle, but most noticeable once car is warmed up.
Old Apr 8, 2021 | 06:16 AM
VolSince69's Avatar
VolSince69
Note too, if car is z51 and do change fluid (regardless of choice) be sure to drive it a bit then top off due to trans fluid cooler being filled.
Old Apr 8, 2021 | 11:29 AM
Dutch08's Avatar
Dutch08
2005 Z51 MN6
I am using an MGW shifter, AMSOil, one venom mod ring, oiled and greased packed linkage U joint ( transmission end under the rubber boot as it enters the transmission). Each made an improvement. My shifts are very smooth now.
Old Apr 8, 2021 | 05:34 PM
joevette perdomo
Yea I installed the mgw just recently, but I'm doing a rear main seal and a new mantic 9000 so I want to address all I can while drive train is out. The t56 has always been notchy
Old Apr 8, 2021 | 06:07 PM
Ahrmike's Avatar
Ahrmike
I run redline in all my transmissions. Used to have an S2000 that loved MTL/MT90 mix and the T56/T6060 seems to like D4 ATF.
Old Apr 9, 2021 | 12:22 PM
steig's Avatar
steig
I put AMSOIL in mine
To T56
