Quick Jacks - make things easy!
Old Feb 10, 2022 | 01:29 PM
dkpnkc's Avatar
dkpnkc
So you guys don't use stands after raising the car & working under? That trusting? Just curious - I would love a pair myself.
Old Feb 10, 2022 | 02:01 PM
CycleReport-Nate's Avatar
CycleReport-Nate
8th Gear
Absolutely. They are pretty rock-solid stable when used correctly. They have built-in locking arms that keep them from lowering before you want it to - not just relying on hydraulics to hold the car up...
I've used jack stands for years, and while I mostly trust them, they always feel a TAD sketchy. Not so with the quickjack. I have zero worry being underneath them.
Old Feb 10, 2022 | 02:11 PM
G6612's Avatar
G6612
I had to adjust my exhaust tips while I had the car up in the air and I did not use jack stands as the car was very secure and sturdy. Let's say I was maybe doing the complete exhaust install, I would probably use jack stands for peace of mind but to be honest I do not believe they would be necessary.
Old Feb 10, 2022 | 02:18 PM
rskwannabe's Avatar
rskwannabe
My car is up right now as I was removing my wheels in order to bring to a shop to rebalance. I was hoping to address a slight shake when going about 80 on the highway.
It's a lot easier to pull all four wheels at once. It was then I saw a broken wheel stud. Hmm maybe that was what was causing the slight shake.
Old Feb 10, 2022 | 04:47 PM
Chukman's Avatar
Chukman
To add to the above, each one of the QJ units is pretty heavy. I'd say any part of the QJ lift is beefier than the typical jack stand. Jack stands seem sketchy at their highest level and the QJ is solid at the higher level it provides. As long as the car is lifted up to and resting on one of the two stop levels, I think it's plenty safe alone. On these stops you're not relying on the hydraulics to hold the weight. But it never hurts to add another factor of safety by still using jack stands just in case.
Old Feb 10, 2022 | 06:02 PM
Matt Zed's Avatar
Matt Zed
Hmm maybe I'll do the clutch on my c6z with one of these Quick Jacks, looks like it should give enough room.
Old Feb 10, 2022 | 07:37 PM
mikeCsix's Avatar
mikeCsix
Once you get the car in the air and the stands are locked, you can disconnect the hydraulic hoses so you are not tripping on them.
Old Feb 10, 2022 | 07:49 PM
Sdk8103's Avatar
Sdk8103
Originally Posted by G6612
Also watch Home Depot believe it or not, they were cheaper than Costco.
That's where I got mine.
Old Feb 20, 2022 | 11:44 AM
dkpnkc's Avatar
dkpnkc
FYI - I just saw on quickjack.com they're having a one day sale on 02/22/22 for 22% off. Gives me 2 days to figure out if I can afford it. Very tempting.
https://www.quickjack.com/22offdeal/...SAAEgI-cPD_BwE
Old Feb 20, 2022 | 03:14 PM
She_Thicc's Avatar
She_Thicc
Banned Scam/Spammer
Good find. Does the longer version work on the C6 (5000tlx) or is the regular length recommended (5000tl)?
Old Feb 20, 2022 | 03:21 PM
Chukman's Avatar
Chukman
See my post #14 above. I have the 7000 and it barely works for the C6. So I'd think any of the 5000 models would work. The QJ website shows the spread dimensions min - max. Check the dimension for the 5000 tlx and measure between your jack puck points to confirm it'll work for you.
Old Feb 21, 2022 | 08:14 PM
PAPAYOYO's Avatar
PAPAYOYO
So... I started this GOFUND ME...For a pair of quick jacks🙏🙏🙏
Old Feb 22, 2022 | 09:19 AM
  #33
dkpnkc's Avatar
dkpnkc
Just bumping this up in case anyone wants to take advantage of the sale. I'd love a set but alas it's not in the cards right now.
Old Feb 22, 2022 | 09:34 AM
  #34
Geoff13IOM6GS's Avatar
Geoff13IOM6GS
one day i will have a set!!!
Old Feb 22, 2022 | 01:06 PM
  #35
leadfart's Avatar
leadfart
I just pulled the trigger, been wanting them for a while now. I bought the 5000TL.
Old Feb 22, 2022 | 06:07 PM
  #36
C6HROD64's Avatar
C6HROD64
Received my 5000TL a couple of days ago from Costco and finally set them up. The set up was easy no leaks works great. Great height for alot of different jobs. Glad I bought them.
Old Feb 22, 2022 | 08:16 PM
  #37
jeffs64's Avatar
jeffs64
Had mine for two years now. Also the 5000 work perfect
To Quick Jacks - make things easy!
Old Feb 22, 2022 | 11:49 PM
  #38
russ472's Avatar
russ472
this thread with the sale today made me pull the trigger.
Old Feb 23, 2022 | 08:17 AM
  #39
PAPAYOYO's Avatar
PAPAYOYO
looks good. Did you use the pucks to lift it?
Old Feb 23, 2022 | 10:27 AM
  #40
C6HROD64's Avatar
C6HROD64
No pucks, just the 4" blocks supplied with the Quickjacks.
