Anyone done FI on a built 427?
Peter
That Engine will not work well with FI as the compression is pretty high, MTI likey to put compression in the piston's so getting bigger 71cc heads may not buy you much as far as lowering your compression but its worth looking into.
Good luck on your next mod.
HP Turbo System?
Blocktrdr and Devil Ray,
Here is an HP turbo system. I like it personally better due to the fact there is room enough to "switch out" different sized turbos in your vehicle applications with the kit(s).
Small Turbo: Spool Fast and fall on your face.
Big Turbo: Laggy, But BOOYAH when it hits!!!
The right size turbo for your CID: Less lagg, more consistent and continuous power.
Ability to change turbo sizes is the best "bang" for the buck!
Check these out:
http://www.hpturbos.com/c56turbosystems.htm
Check these out:
Maggie coming out with a 144CI kit in the spring. Rumor from my source there puts it at very low IAT's (in the 105 range) at full boost.
Planning on building a forged short block for mine, may just make it a 403 and slam the 144 on.
Rick
Rick
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Rick
The way you are headed, you will need to move to Cape Canaveral so you can launch at the Kennedy Space Center The need for speed continues
Jeff
Its in the works lpe 427 with my m122 with higher comp than my 403 hope to have #,s late jan
St. Jude Donor '07-'08-'09
Former Vendor
#33
i like your style....beating chevy to the punch i want to kick some ss but myself....the longer they push it back the more chance i have of getting the lsx block in aluminum!!!
