***the new c6 hidden meth kits****
#41
Location: Greater Detroit Metro MI, when I'm not travelling.
No doubt. I took what was existing with my kit and came up with the idea to put it back there when thinking of all possible places. When I asked around no one had ever heard of it before. Guess they didnt know of AIS plans. I definately didnt and couldnt find anything about that on here. But its water under the bridge. They took it to another level and molded a tank to fit precisely. I like the looks alot the only thing I am concerned about just slightly is I used to have a Fuel cell in my other car made out of the same stuff and the top would sink in over years and became very tough to remove the cap. Being that this is so small I doubt they will have the same issue. Do they sell just the tank with a fitting on the bottom so I can use my existing setup?
#48
Meth Kit for C-7 Twin Turbo
Do you have a kit for a C-7 ? I have a LMR twin Turbo, Makes about 836 RWHP @ 12 PSI.
Thats right guys, you asked for it and we delivered! AIS just finished up the mold for the new meth kits that mount in the rear DS cubby hole.
here is the info:
"2005 - 2010 C6 Corvette water methanol injection tank. Designed to fit in the drivers side rear storage compartment. Once installed and with the storage lid closed. Its completely hidden for a factory appearance. Eliminating mounting a tank out in the open or using your factory windshield washer container. Additionally, with its 1.7 gallon capacity over the factory 1 gallon washer fluid tank. Users can go longer in between refills"
" * Custom roto molded tank
* 1.7 Capacity
* Aircraft style fuel cell cap with stainless steel ring and hardware
* One-way flapper vent built into the cap
* Built in sump with dual pick ups
* Billet 3/8 NPT inserts molded into the tank
* Built in low level sensor"
Kits will be available in two weeks, get me a email or a call to get on the list so you can get in on the first batch.
all AIS kits come with a limited lifetime warranty also!
here is the info:
* 1.7 Capacity
#49
