C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Pinging during acceleration
Old Sep 22, 2010 | 10:25 PM
VetteAwe's Avatar
VetteAwe
Default Pinging during acceleration
About a month ago, I noticed some pinging on acceleration. (2007 MN6 with Vortech V-2 Si-trim) Tried both Klotz and adding in 4-5 gallons of Sunoco 100 that did not cure the pinging.
Brought the car to Nick at Newtech who was able to tune to eliminate the pinging. However, to eliminate the pinging, Nick had to basically zero out timing in several areas to stop the pinging. Although no more pinging, below about 2000 rpm, the engine is sluggish in the range where the timing was removed.
I am dropping the car off with Nick on Saturday to try to figure out what is causing the pinging issue, fix and and restore the old tune. I don't want the pinging, but the low rpm sluggishness is getting annoying. One of Nick''s thoughts was possibly oil getting into intake manifold from PCV. Anyone have any thoughts on what might be cause of the pinging?
Old Sep 28, 2010 | 05:00 PM
ShowcaseC6's Avatar
ShowcaseC6
St. Jude Donor '10
I had an odd issue that gave my tuner some headaches. Turns out it was from clogged cat. Somehow my cat's innards had broke apart a small bit that formed itself into the perfect ball-like shape to wedge itself in my exhaust.
I also had some issues with oily-MAF.
Old Sep 28, 2010 | 05:36 PM
VetteAwe's Avatar
VetteAwe
ShowcaseC6,
Thanks for the info. I will pass it along to my tuner who has the car this week to troubleshoot this issue.
Old Sep 28, 2010 | 08:32 PM
Slowhawk's Avatar
0Slowhawk
Former Vendor
Stock cats could do that.Could also be the PE fuelling which the car could not be going into open loop early enough.I ussually tell customers not to load the car at WOT under 2500rpm.
Old Sep 28, 2010 | 10:15 PM
Cyphear's Avatar
Cyphear
Your setup (a vortech) at 2k RPM will only be generating like 2-3psi, right? Assuming that's correct, I couldn't imagine how you'd be getting preignition with 2-3psi + 100 octane... but retarding the timing fixed it. Have you checked your base timing?
I would say unless the tune is way off or something else is causing issues. Good luck! I'm sure it's something simple.
To Pinging during acceleration
