C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Horn Relocation After E-Force Install
Old Feb 17, 2011 | 10:00 PM
  #61
Motorhead-47's Avatar
Motorhead-47
I did a similiar fix to the two installs I've done. I also re-used the stock v-bracket. In my case I drilled the center v-bracket hole larger and mounted it sandwiched between the frame and the radiator cradle using the front cradle bolt. I had to bend the v-bracket slightly upward to make clearance for the rear horn (to clear the brake duct) but it works as Elmer described.
Old Feb 17, 2011 | 10:10 PM
  #62
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Originally Posted by EG@EnglandGreen
Just read you post Elmer. Let us know the gauge and type of material so we can start using that with our Edelbrock installs.
Stephen
It is the stock OEM horn bracket. I just attached the horns to the OEM bracket and then I attached the OEM bracket to the rear hole of the E-Force bracket. In other words, don't attach the horns directly to the E-Force bracket, use the OEM bracket to mount the horns. Look at the picture. It shows the horns attached to the OEM bracket, with the OEM bracket attached to the E-Force bracket.
Elmer
Old Feb 26, 2011 | 09:34 AM
  #63
Motorhead-47
Old Feb 27, 2011 | 10:38 AM
  #64
eboggs_jkvl
Moderator emeritus
Originally Posted by Motorhead-47
Perfect! ...and it don't go "meep-meep" any more, huh?
Elmer
Old Feb 27, 2011 | 10:57 AM
  #65
Motorhead-47
Elmer
Yep....this is someone else's photo though. In the two I've done I sandwiched that bracket higher up using the front radiator cradle bolt. Tucks the horns up completely out of the way.
