C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
View Poll Results: Have you had a SC engine failure?
Turbo failure
0
0%
Turbo no problems
9
9.38%
Centri failure
6
6.25%
Centri no problems
62
64.58%
PD failure
2
2.08%
PD no problems
22
22.92%
Multiple Choice Poll. Voters: 96. You may not vote on this poll
Supercharged engine failure Poll
Old Jan 5, 2011 | 06:33 AM
lsbrodsky's Avatar
lsbrodsky
Default Done
Looks like we are done. About 8% of voters reported failures. Conclude what you want, thanks.
Larry
Old Jan 5, 2011 | 06:34 PM
trickability's Avatar
trickability
Larry
Well I would like to see how many NA modded cars are on here and out of 90 how many have failed. You in ?
Old Jan 5, 2011 | 06:42 PM
BADZ's Avatar
BADZ
I can't say enough about the centri SC...
I love mine!!!!
Old Jan 5, 2011 | 09:00 PM
trickability
I love mine!!!!
Me too 680 rwhp feels just nice under my foot weeeeee.:
Old Jan 5, 2011 | 09:35 PM
Slvr08Z51's Avatar
Slvr08Z51
I love mine!!!!
Best performing vehicle/$ in the entire car universe..
Old Jan 5, 2011 | 10:28 PM
TrenAman's Avatar
TrenAman
if I had to do it all over, it would be a LSX454-R with a tvs2300 from the get go.. maybe this will be my next years setup.. Talk about insane torque!
Old Jan 6, 2011 | 06:46 AM
lsbrodsky's Avatar
lsbrodsky
Trickability,
How would you ask the poll question?
Larry
Old Jan 6, 2011 | 10:16 AM
trickability
Trickability,
Larry
Maybe we could post in the zo6 section, and just say how many NA modded cars have had failure. It would be interesting because I think we get a bad rap on our SC cars because a lot of people probably run them pretty hard. ?????
Old Jan 6, 2011 | 12:26 PM
lsbrodsky's Avatar
lsbrodsky
How about the C6 General? I , for one, never look at the Z06 forum.
Larry
Old Jan 6, 2011 | 12:46 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
Larry
I conclude by your all-inclusive and extremely thorough poll then that turbocharged Corvettes are one hundred percent reliable... Who knew!
Old Jan 6, 2011 | 01:04 PM
trickability
Larry
better yet, sounds good
Old Jan 6, 2011 | 04:40 PM
ArmySpeedFreek's Avatar
ArmySpeedFreek
I need to get mitch (super speed) in on this his ptk kit killed his 427 C5R fully forged with billet crank and rods lol
Old Jan 9, 2011 | 01:15 PM
  #33
3 Z06ZR1's Avatar
3 Z06ZR1
I love mine!!!!
Me too! The Centri on the 427 is a bad azz package. The 427 loves the boost.Then you have a lightweight frame. Rolling through the gears is no effort triple digits in seconds. Stock ZR1? Your smoked!
Power to weight says it all!
Old Jan 9, 2011 | 01:18 PM
  #34
JSB LS3's Avatar
JSB LS3
Originally Posted by ArmySpeedFreek
then you need to get R888s GODS OWN TIRES :P I cut a 1.71 60' with a full boltons car on them this last summer and they hold in the corners better then any other "streatable" tire Ive ever been on. i stratable because they are infact 100 tw road racing tires :P if you want to try b4 you buy I would be more then happy to let you take aride with me some time I'm in CT now
Sounds good.
Old Jan 9, 2011 | 02:18 PM
  #35
Mr.Big's Avatar
Mr.Big
I can't use my little 370c.i. 9.25:1 torque with sh*tty heads without TC/BC... I believe this would be a huge mistake without Traction Control/Boost Control which isn't cheap with a PD setup, and then add heat soak to boot... Wait until you go F1 and set it up for your driving style, you will NEVER consider a less efficient PD setup again. Now if you were just doing a stock engine and only wanted 550ish rw, and could care less about heat soak, then a PD is the ticket. Short of that they are just not a smart choice given the superior aspects of the Centrifugal systems. Centri's win period, now Centri vs. TT, the TT's win if availability (none offered in 2005 when I started my C6 venture) and cost are no issue...
Old Jan 9, 2011 | 06:58 PM
  #36
PowerLabs's Avatar
PowerLabs
Knows what he's taking about.
Old Jan 9, 2011 | 07:52 PM
  #37
TrenAman's Avatar
TrenAman
I know several tvs2300 owners, they all say that this heat soak claim is a just a bunch of crap in real world driving. Can it happen, yes, but you have to try pretty hard to get it.. Only people without PD blowers make this claim.. Even most members here with tvs2300's say the samething my buds say.. I just get sick of everyone saying that crap with no real world experience to abck it up..
I do not see what this poll is trying to show.. 90% of FI applications are centri vs PD. even fewer are TT. Also, you do not know if the failures can from some guy putting 10lbs on a stock LS7 or 18lbs on a stock ls3..
Off my soap box..
To Supercharged engine failure Poll
Old Jan 10, 2011 | 04:24 AM
  #38
Mr.Big's Avatar
Mr.Big
TA have you seen the data logs in Texas after back to back road/track pulls of these setups? Either your friends are not logging their IAT's after the compression or they aren't at all... I have seen them, and even with larger and larger heat exchangers they have issues, period... a guy we know at the mile with an all out build had some crazy logs to share right after it blew to pieces... now run methanol, that they claim you shouldn't, and that's a different story, but those that have claim to have rotor finish issues... however believe the hype if you will...
Old Jan 12, 2011 | 03:39 PM
  #39
dreyfus's Avatar
dreyfus
2.5 years and 7k miles with a Vortech and no problems so far. I've hit rev limiter briefly several times, and even ran it lean due to low fuel pressure. This was a result of a poor ground connection on the BAP. If i were to blow the engine at this point, I wouldnt fault the blower, plus im running a 3.6" pulley and pushing the limit on a motor with pretty high compression (ls2). Would do it again in a heartbeat.
Old Jan 12, 2011 | 04:30 PM
  #40
aTX427's Avatar
aTX427
St. Jude Donor '09-'10
You would need two tvs2300's to support an efficient 454ci Lsx engine. They are fine for a 6L or 6.2L, but don't have the output to support 400+ cubes.
If you are looking for a flatter torque curve, TT's are the way to go, but most will concur that you can't put that kind of power to the ground down low on the street and go with boost by gear, which defeats the purpose of having monster low end torque to begin with.
I still think people are best served with a high boost centri on stock cubes unless they are making gobbs of power like RC or AtomicFusion, but to each their own.
