Compressor Map Q
Turbonetics T04E 57 Trim Compressor Map:
Turbonetics HP 76 Compressor Map:
Actually their T66 seems to fit the bill well also. Two of those have a nice sweet spot from ~800-1200 HP!
A friend pointed out that real world results often differ from "on paper". Example: My old Novi 1500 is only rated to 825 HP max. Mark (winters97gt) is making 825 RWHP from it on his 402 which is ~950 crank. From the looks of it I'm way off the map efficiency-wise but they'll still be good for low to mid 800's RW and possibly more if I swap out the exhaust housings (.62 to .82 AR).
93 octane with dual nozle straight meth.
A friend pointed out that real world results often differ from "on paper". Example: My old Novi 1500 is only rated to 825 HP max. Mark (winters97gt) is making 825 RWHP from it on his 402 which is ~950 crank. From the looks of it I'm way off the map efficiency-wise but they'll still be good for low to mid 800's RW and possibly more if I swap out the exhaust housings (.62 to .82 AR).[/QUOT
Bill without a doubt start off .82 AR. Don't use bother with .62
Correct on the 76's...well partially. I have not doubt that they've been used with great results, AND if you map out the compressor map at 15psi and redline, that will put you smack dab in the peak of the efficiency, beautiful! However, I'm going to assume that your car doesn't have a variable geometry transmission, and isn't going to spend it's life at redline. I run a single T76 on my 3000GT pushing 800whp. I'm going to have to say for what you're looking for the twin 76's are just a bit too big.
Here's what you want to look for when mapping the compressor. First, what's the power you want to make, and aprox (based off others) what is the required boost to achieve that. Obviously fuel, compression, cam, etc all play a vital roll, but just to narrow it down. The 57 trim you posted I would call a 425hp max from each turbo, so 850 total. Now where do you assume that you'll be spooled by? Generally fully spooled by ~4K isn't alot to ask for, so we'll assume that. Now plot your lb/min requirements at 14psi @4K and then at 14psi @ redline (or what ever boost you choose). Draw a line. Try to get the majority of that entire line as efficient as possible when comparing turbos, and cap it on the right side of the map, because it's pretty good assurance that the turbo isn't going to support much past what's drawn on the map.
Looking at the 57 trim map posted, I would say that's a really efficient setup for 600-700hp on our cars, and maxed out by 850. Comparing that to a SH-trim (58mm)
57 Trim- Inducer 56mm Exducer 74mm
58mm - Inducer 58mm Exducer 76mm
And those 2mm on each are good for anther 75hp each.
Oh, and one last thing, if for whatever reason you find any point of your plot off the left side of the map (surge limit), that's very bad too. That's where the turbo is too big and trying to flow too much air for what little shaft speed it has and isn't able to maintain pressure. It causes back flow, which can damage the shaft/bearings.
Hope this helps.
CK
Sorry I haven't been able to reply yet to this thread. I went back through some of my notes from when I started my build. I ran across an email where TTi stated that the turbo had an SH wheel which stands for Super H. If you download the compressor map from turbonetics, it looks like this:
Knowing what I know about the kind of power that people have made with the 57mm turbos, this is a better fit. I know early on there were even a few guys that used these "standard small turbos" on 402's and 427's and they weren't disappointed. Did they make 1000 rwhp, no, but they did eclipse 900 rwhp.
And I've personally pulled 550whp out of a single one by itself.
