C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
TTIX, Forged 408 Build
Old 01-17-2012, 12:55 AM
  #41
BLOWNBLUEZ06
BLOWNBLUEZ06's Avatar
Just in case you're interested, I heard ARP is coming out with studs stronger than the L19's yet don't have the hydrogen embrittlement issues. They're made from "Custom Age 625"
The last studs you'll ever need.
If you're not going crazy, the 234-4319's will do fine though.
Old 01-17-2012, 09:52 AM
  #42
5 Liter Eater
5 Liter Eater's Avatar
St. Jude Donor '11
Thanks Bret. I'm excited too. Not interested in exotic head studs right now. I had a hard time opening the wallet for the 8740 ARP head studs. Not willing to pay what I'm sure is double that for "aged" studs.
I don't plan on exceeding 2.5 bar, actually don't want to go into the 20# range. My OS is limited to 2.5 bar anyhow. I've been toying with scaling a 3 bar MAP to fit into 2.5 bar worth of range. But again, not going to get that crazy with it yet.
Old 01-17-2012, 02:20 PM
  #43
MIGHTYM0USE
MIGHTYM0USE's Avatar
its not the bolts anyways its the head that moves between the bolts
Old 01-17-2012, 02:55 PM
  #44
user_name
user_name's Avatar
Those heads will stay down 99% of the time. 100% if you never race me. Just like last time.
Old 01-17-2012, 03:03 PM
  #45
Vince99FRC
Vince99FRC's Avatar
Has anyone lifted AFR225's with L19's?
Old 01-17-2012, 03:14 PM
  #46
Ls240sx
Ls240sx's Avatar
I ran over 30lbs on my 42r with L19s in my mr2 back in the day and those were like half the size of the corvette headbolts. no problems. you could prolly bend the head in half with the L19 studs.
Old 01-17-2012, 04:44 PM
  #47
MIGHTYM0USE
will rip the aluminum threads out of the block before anything happens to the bolt
i dunno about afr but my 4 bolt all pro's would consistently give at about 1000hp with 5 layer mls. i doubt the alloy is different.
Old 01-17-2012, 05:00 PM
  #48
TWINZO6
TWINZO6's Avatar
Why didnt you just upgrade the head unit to a YSI or bigger??
Old 01-17-2012, 05:15 PM
  #49
5 Liter Eater
St. Jude Donor '11
Because that would be boring.
Plus turbos are a gentleman's power adder.
Old 01-19-2012, 11:47 AM
  #50
0Jeff @ TPE
Former Vendor
Jeff @ TPE's Avatar
St. Jude Donor '06 & '12
I just had my block drilled out, and installed ARP 2000 1/2" studs. Man was I terrified torqueing those things to 140lbs. I actually did it once, then took it back apart to make sure I didnt crack anything.
Old 01-19-2012, 12:35 PM
  #51
MIGHTYM0USE
that seems a bit excessive! i've never even heard of anyone going over 110
bigger bolts with more surface area of threads should hold more torque so you had that going for you.
doing something fancy like a o ring stack on 4 bolts?
Old 01-19-2012, 04:22 PM
  #52
5 Liter Eater
St. Jude Donor '11
Originally Posted by 5 Liter Eater
The part is an even bill on gmparthouse. I'll use my interwebz sleuthing skills to see if I can find it cheaper.
Amazon FTW! $68 w/ free shipping.
Old 01-19-2012, 05:14 PM
  #53
BLOWNBLUEZ06
Way to go! Race gas money!
Old 01-19-2012, 05:33 PM
  #54
BLOWNALKY01
BLOWNALKY01's Avatar
Old 01-21-2012, 12:03 PM
  #55
SouthTexasBully
SouthTexasBully's Avatar
Bill,
winters97 is gonna drag u
Old 01-21-2012, 02:36 PM
  #56
0Jeff @ TPE
Former Vendor
Jeff @ TPE's Avatar
I got the shaft!!!
I couldnt find it on Amazon, so I had to pay 104 bucks at my dealer.
Old 01-21-2012, 08:12 PM
  #57
5 Liter Eater
St. Jude Donor '11
Originally Posted by SouthTexasBully
Bill,
Maybe from a dig. We'll see how it goes in MX.
To TTIX, Forged 408 Build
Old 01-21-2012, 09:10 PM
  #58
cencalc6
cencalc6's Avatar
Congrats on the new TT Setup.... should be lots of fun when your done with it
Old 01-21-2012, 09:34 PM
  #59
5 Liter Eater
St. Jude Donor '11
Thanks! I'm pretty stoked. Waiting for parts is hard...
Old 01-22-2012, 12:56 AM
  #60
winters97gt
winters97gt's Avatar
I can't wait to see this sucker be finished. I can't even imagine tackling something like this in such a short time frame. What will speed up the process is a Katy Perry CD on repeat.
Quick Reply: TTIX, Forged 408 Build
