C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Will tuning fix it
Old Jul 23, 2013 | 01:18 PM
PGSJOE's Avatar
PGSJOE
Default Will tuning fix it
I am experiencing a surging while driving at low speeds(RPM) so even at 50 mph I can feel a surging sensation. Is this a tuning issue??
A6 12gs A&A 6lb boost. Thanks in advance
oh yes - tuner adjusted some transmission values and some timing he said as we drove, stopped programmed restarted several times. Much better but it remains.
Old Jul 23, 2013 | 01:35 PM
Unreal's Avatar
Unreal
No way to answer that. Could be plugs, vacuum leak, etc. Once all those are ruled out then it could be the tune.
Old Jul 23, 2013 | 01:46 PM
Pekka_Perkeles's Avatar
Pekka_Perkeles
Is this car with just an A&A kit?
Fairly easy - or I guess it depends - is to put the stock injectors and stock tune back and see if it still surging.
A decent tuner would have checked misfires or error codes, so I guess those were not the problem.
Old Jul 23, 2013 | 01:47 PM
PGSJOE's Avatar
PGSJOE
Dont think its vacuum, its steady on gauge. I am on the hp hunt and had my engine built with callies rods and forged pistons, I gues the plugs could have gotten damaged in the process?
Old Jul 23, 2013 | 01:48 PM
PGSJOE's Avatar
PGSJOE
no misfire codes they checked. service ahs is on so its going to dealer tomorrow to calibrate or fix whatever went bad. Checked the vac, and all plug wires are on securely.
Old Jul 23, 2013 | 03:32 PM
Unreal's Avatar
Unreal
Gap correct? Correct plugs? Steady vacuum doesnt mean there is no leak.
Old Jul 23, 2013 | 04:38 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
I wouldn't imagine you rebuilt the engine with all race components and kept the stock camshaft in, did you?
If the engine has an aggressive cam it will never idle like a stock car. Its one of the reasons why they don't come with big cams from the factory...
Old Jul 24, 2013 | 12:55 AM
PGSJOE's Avatar
PGSJOE
powerlabs:
I know this might sound crazy but I did keep stock cam because I wanted to maintain good idle and driveability, not a huge fan of choppy idle.
Unreal:
what is correct gap? and plugs were supplied in my A&A kit, 1000 miles old.
Dont want to pop tranny and axles and all but would eventually like to reach 700+/-. I have heard 600 is kinda the high end on stock internals ... so still being conservative. I built the motor so the most vulnerable part(stock pistons) would not break and cost a fortune, not that the other stuff is cheap. did not want to kill a piston and score the block rendering it junk. do you all know where i can get a vacuum diag. to look for leaks?
thanks!
Old Jul 24, 2013 | 09:32 AM
PowerLabs's Avatar
PowerLabs
powerlabs:
What injectors are you running then? My car idled perfectly with an A&A kit, there is no reason yours shouldn't if you have a stock cam...
Old Jul 24, 2013 | 10:14 AM
Unreal's Avatar
Unreal
All I was saying it there is no way to say "Yes the tune will fix it" without knowing what the problem is. If it is a problem with the tune, then yes. Then again it could be many other things that the tune won't be able to fix.
Old Jul 24, 2013 | 10:35 AM
PGSJOE's Avatar
PGSJOE
using injectors with A&A kit, idles good, surges under light load. I appreciate everyones input
Old Jul 24, 2013 | 11:39 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Go for a ride while watching your MAF HZ, you will see them jumping all over, that is your surge problem.
Old Jul 24, 2013 | 11:52 AM
PGSJOE's Avatar
PGSJOE
So how does one correct this Doug??
Old Jul 24, 2013 | 11:54 AM
Pekka_Perkeles
^^ exactly.
I bet it's also MAF only tune.
You can fix it by going Speed Density, as an example.
Old Jul 24, 2013 | 12:01 PM
Unreal's Avatar
Unreal
Tune or different maf/pipe/etc to reduce reversion at low RPMs.
Old Jul 24, 2013 | 12:10 PM
PGSJOE's Avatar
PGSJOE
I guess I will try another tuner then because I feel this one has no more tricks left. I will mention the speed density approach to him and check his reaction.
what about AHS, the light is on now and had to reschedule for monday at dealer. last week they said communication error but if I turn the wheel all left turn then try to go straight it applies the brakes on the left front then it drives normally. I think installer did a poor job and could hae buggered up something but who knows. Upon reading it seems everything from plug wires to too much salt in your diet sets this thing off kilter
Old Jul 24, 2013 | 12:12 PM
Pekka_Perkeles
This is an example of unstable MAF. Note that MAF and RPM scale is very small (0...10 g/s and 1150...1250 rpms), but it anyway shows effect of unstable MAF at steady state cruising:
To Will tuning fix it
Old Jul 24, 2013 | 12:18 PM
PGSJOE's Avatar
PGSJOE
Thank you all so much for the help, hate to spend $$$$$ and end up with crap. At least now I have a direction to look in
Old Jul 24, 2013 | 03:20 PM
Thomasmoto's Avatar
Thomasmoto
What is your boost/vac gage showing at idle?
Old Jul 24, 2013 | 10:29 PM
Josh@AandASuperchargers's Avatar
Platinum Supporting Vendor
My best guess below:
Surge can be fixed with proper tuning.
TCS issue can probably be fixed in the tune also. It's probably a MAF tune with stock MAP sensor and you need to disable code P0108 to No Error Reported.
