C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Pulley Problem
Old Aug 11, 2015 | 05:13 PM
Dealripper's Avatar
Dealripper
Default Pulley Problem
Anyone know the part number for the ac idler bearing on 2008 LS3? I have an 8 rib direct drive setup the bearing went bad and caused my ac belt to shred which caused my power steering and charging system to fail, because it runs another set of pulleys which they operate off of. Any help would be appreciated. The dealer has been no help.
Old Aug 11, 2015 | 05:50 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Earl is that on the AC tensioner or were you upgraded to the C5 bracket that has the second idler?
Old Aug 11, 2015 | 06:14 PM
Dealripper's Avatar
Dealripper
Doug that must be an upgrade because the tensioner is below that. I guess that's why the dealer did not see it in the computer. I need the idler bearing part number if you can help me thanks in advance. Earl
Old Aug 11, 2015 | 06:40 PM
Xtremespeed's Avatar
Xtremespeed
From: The only state to ever kick another country's ass! TEXAS
I believe 38241 is what you are looking for. C5 AC idler pulley. Also 12557334. AC-Delco #15-4669.
That's if you have the c5 ac idler. The LS3 usually does not. Is it in that pic?
Old Aug 11, 2015 | 06:50 PM
Dealripper's Avatar
Dealripper
Thanks for your help. I will try to get the part this week👍
Old Aug 11, 2015 | 07:07 PM
Xtremespeed
Make sure that's what you need. An LS3 wouldn't normally have an ac idler.
Old Aug 11, 2015 | 08:29 PM
Dealripper's Avatar
Dealripper
I have a modified setup by ECS, built engine, supercharged, direct drive etc. Thanks a lot😃
Old Aug 11, 2015 | 08:41 PM
Dealripper's Avatar
Dealripper
Yes I have removed the idler bearing it was shot. The tensioner is directly below. The LS3 does not have this setup. This was an upgrade by ECS. Thanks for your help.
Old Aug 11, 2015 | 08:42 PM
Xtremespeed
No problem. Glad I could help. Just wanted to make sure you had the c5 style ac setup.
Old Aug 11, 2015 | 08:57 PM
Dealripper's Avatar
Dealripper
Thank you🏁
To Pulley Problem
