C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Heartbeat, Being Ordered
Old Mar 11, 2016 | 05:44 PM
  #181
Woodstoc's Avatar
Woodstoc
Originally Posted by CI GS
I'm not at liberty to say, but I got the old girl up to 122 a little while ago before having to get out if it. We've built a few new roads lately and one developer is even in the process of building what I think is the worlds first tunnel built from the ground up.
No kidding, if you were here more than 5 years ago, you might be shocked at what you would see now.
BTW: The TCM tune mods makes this thing shift as fast, if not faster, than a 911's PDK, and it pulls like like a freight train once the converter locks up at about 75mph in 3rd, which feels like a gear change in and of itself.
I don't blame you, I saw police everywhere I went. I was a law abiding citizen in my econobox, with the steering wheel on the wrong side.... It's been a bit more than 5 years, I think it was around 8 now. The daughter married into a family that has a condo there.
So what TCM tune mods?
Old Mar 11, 2016 | 08:25 PM
  #182
CI GS's Avatar
CI GS
Cool. It really does annoy me that we have to drive on the friggin left here too, as if we were in the jolly UK, even though 95% of our cars are left hand drive cars from the US!
On the TCM tune: I had this issue for months with my car hitting the limiter before it would shift on the 2-3 and 3-4 shifts, and I had to keep moving the shift speeds downwards to get it to initiate the shift early enough to avoid that. Even with the shift times shortened and with no TM, it needed significantly lower shift speeds to shift without hitting the limiter. Then I bought myself the Tuning School 6L80 manual and went over the whole process, following their recommended tweaks, which seemed to work well, but it still needed the low mph settings in the shift speed tables.
Then I saw these vids on HPT forum of a couple of Holdens in Australia, and one that was running 10.0s and was shifting like a sequential box. The guy who posted them was recommending that the 6L80 needed the oncoming adapt pressures significantly elevated to shift properly, so I tried what he recommended, and after that the transmission shifted so instantaneously at WOT that I had to put the shift speeds back up to where they were before, because it was shifting too early. It's unbelievable the difference it made. No flare, no lag - it just shifts like it should and at just about the mph that I have in the shift speed tables. I also have the converter locking at 75mph in 3rd and the car pulls like a beast up top now.
Old Mar 11, 2016 | 08:35 PM
  #183
Woodstoc's Avatar
Woodstoc
Hmm, now that it's finally stopped raining, I might get a chance to really test mine out and see if I have any shift point issues. Hadn't thought of that. I tried once and spent a great deal of effort trying to get the car back under control. It looks like it's going to dry up this weekend...
Old Mar 11, 2016 | 08:41 PM
  #184
CI GS's Avatar
CI GS
Be careful dude! We don't want you to crash your Corvette, especially since you apparently drive it naked!
You should be okay, but even if you don't have a problem shifting, I would try to data log it at some point and see exactly what RPM you're shifting at. Mine shifts at ~6400 on the 2-3 shift and 6300ish on the 3-4 shift - for now.
Old Mar 11, 2016 | 09:52 PM
  #185
schpenxel's Avatar
schpenxel
St. Jude Donor '15
How high did you go with the oncoming adapt pressures? I am trying to learn more about A6's and haven't messed with that portion yet
Old Mar 12, 2016 | 08:42 AM
  #186
CI GS's Avatar
CI GS
Here's a link to the thread:
http://www.hptuners.com/forum/showth...lling-me/page2
I used the numbers Tre-Cool posted in post #38: 557, 1153 and 1750 kpa.
Tuning the A6 is like black magic. From what I've seen and experienced, only a handful of folks know exactly how this trans, and most of them aren't sharing.
BTW: Apologies to the OP for the thread hijack!
Old Mar 12, 2016 | 01:01 PM
  #187
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Thanks, I'll take a look through it. Is it bad I didn't realize there was a GM transmission tuning section on HPT's forum?
Agreed though.. I don't think hardly anyone truly knows how these things work... I'm going to mess around with the settings on the one in my truck
I increased the line pressures a little, decreased shift time a little, increased shift points and turned off tip in/out torque management and it feels like a different truck already
Old Mar 12, 2016 | 04:18 PM
  #188
CI GS's Avatar
CI GS
LOL!! There's only so much one can do, I guess. No one is omnipotent. I've been scouring the HPT forums in search of knowledge for the past several weeks, but haven't really learned much, to be honest.
Most of the guys on there "talk code" it seems. You're one of the few that I see explaining stuff in a way that I can understand (somewhat).
I'd be happy to send you the tunes for my truck and car and you can have a look at what I've done on the TCM tune. That way I might get some free advice too!
Old Mar 24, 2016 | 03:29 PM
  #189
VetteArts's Avatar
VetteArts
Got the 81mm intalled, boost of 11psi. Probably more than what my stock engine can handle . I am considering 87mm now for expected boost. .. ~9psi.
Old Mar 24, 2016 | 03:36 PM
  #190
schpenxel's Avatar
schpenxel
St. Jude Donor '15
nah it's good for at least 20psi
Old Mar 24, 2016 | 03:42 PM
  #191
old motorhead's Avatar
old motorhead
Enjoy it. It's not the amount of boost that kills engines. It's the amount of cylinder pressure/power they make that does. As long as you have plenty of fuel and a good tune, you should be fine
Old Mar 24, 2016 | 03:43 PM
  #192
VetteArts's Avatar
VetteArts
A friend of mine blew up his ls3 camaro engine at 11psi. My tuner is concerned about this as well
Old Mar 24, 2016 | 04:01 PM
  #193
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I can blow one up at 5psi if you want..
I wouldn't run 11psi without meth though.
Old Jan 1, 2017 | 12:15 PM
  #194
VetteArts's Avatar
VetteArts
After long time, installing now Alky meth kit.
Where should the nozzle be fitted?
At the intake between the sensor & throttle
Or
Between the throttle and blower body.
Old Jan 1, 2017 | 07:50 PM
  #195
schpenxel's Avatar
schpenxel
St. Jude Donor '15
If you're using the MAF for airflow measurements then it has to be after the MAF
If you're running in SD only then I put the nozzles closer to the intercooler on centri setups
Old Jan 1, 2017 | 07:52 PM
  #196
VetteArts's Avatar
VetteArts
It's a MAF. I am going option 1. Thanks.
Old Jan 2, 2017 | 11:50 AM
  #197
CI GS's Avatar
CI GS
Or
Good stuff. Are you triggering it by MAP or MAF?
I have a full Alky Control kit as well, but I don't think I'll be installing it.
I'm currently running the car with a 5 gallon can of VP 109 mixed with 93 pump and my car loves that, with no KR at 16.5 *.
Since I don't drive my car often (enough), I don't mind splurging every couple of months on a can of race gas.
I was thinking of doing one of the new NX multiport meth/water kits with the nozzles in the lid, behind the CACs and downstream from the rotors, so that the motor sees the full cooling effect. But then again, my car doesn't seem to need the extra octane, and it seems that I can't get it to make more than the 11.75-12 psi it's making now, so I may just do a multiport nitrous system instead and get the best of both worlds...?
Happy New Year to you all, BTW.
To Heartbeat, Being Ordered
Old Jan 2, 2017 | 11:57 AM
  #198
CI GS's Avatar
CI GS
Hey Carson. Happy New Year!
Is there a benefit from moving the meth injection point further upstream, closer to the intercooler? Do you see a better cooling effect from the meth that way on centri setups?
As per my post above, I was thinking the the closest that you can get the meth to the intake port the better, but from your comment, I'm wondering if it works better if the meth has more chance to cool the A/F mixture down before it gets to the intake port?
Old Jan 2, 2017 | 11:59 AM
  #199
Unreal's Avatar
Unreal
The more time meth has to vaporize the better.
Old Jan 2, 2017 | 12:16 PM
  #200
CI GS's Avatar
CI GS
Makes sense. I can imagine at high engine speeds the air is flowing so fast that there needs to be a good distance between the nozzle(s) and the combustion chamber for the meth to cool the A/F ratio significantly. Makes me wonder just how well those multi port systems work?
