C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
2018 Build
Old Apr 5, 2018 | 10:44 PM
  #121
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Reusing block?
I’m in AZ, first time here. 2 hour layover
Old Apr 6, 2018 | 01:00 AM
  #122
Unreal's Avatar
Unreal
No. Lsr block
In San Diego now. Beat you there
Old Apr 6, 2018 | 07:31 AM
  #123
Mordeth's Avatar
Mordeth
2018 C6 of Year Finalist
St. Jude Donor '10, '17
All great choices. Glad things are progressing Nick.
I went with the 2126 lifters due to the axle oiling feature. Both are great lifters, but I wanted the axle oiling. I have the Katech red oil pump though as I know I was going to lose some oil pressure with these lifters. Works great now, perfect oil pressure.
What oil pump will you install? If you are staying with the OEM pump I would go 2116. If not, then 2126. In any event, I would avoid the short travel version. Pain in the *** to set pre-load. Stick with the .093" plunger travel.
Old Apr 6, 2018 | 01:00 PM
  #124
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Originally Posted by Unreal
No. Lsr block
Nice, should be awesome setup
I don’t even know when I got here I was so tired last night
Old Apr 22, 2018 | 01:44 PM
  #125
Unreal's Avatar
Unreal
Trying to catchup after a week in Costa Rica.
Will be doing a big update on here soon. Race Engine Shop is doing the motor. Lots of cool trick stuff. Michael has been a pleasure so far to work with.
Heads are on the way
Mast 285
Victory DLC coated TI intake valves
Inconel Exhaust valves
Pac Springs, etc etc
Crower Steel Shaft Rockers
Other than that basics are
LSR block
4.125x4"
Callies Dragon Slayer (reused for current motor)
Callies Ultra Billet I Beams
Custom Crazy pistons, RES spec ~10:1 compression
Etc etc etc
Old Apr 23, 2018 | 11:51 AM
  #126
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Should be nice, I think we're all looking forward to a bunch of pics
Old Apr 23, 2018 | 12:16 PM
  #127
Unreal's Avatar
Unreal
Yah for sure. On the way to Wyoming right now. Trying to get caught up.
Trying to plan all the little stuff, like doing a improved racing crank scraper, etc.
Old Apr 23, 2018 | 12:28 PM
  #128
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Sounds good. Going to have to go to a bigger blower next
Old Apr 26, 2018 | 12:16 AM
  #129
LemansbluebyU's Avatar
LemansbluebyU
St. Jude Donor '12, '15
[QUOTE=Unreal;1597050875]Trying to catchup after a week in Costa Rica.
Mast 285
LSR block
4.125x4"
Etc etc etc[/QUOTE
So far that motor sounds just like mine
Old May 10, 2018 | 07:39 AM
  #130
Unreal's Avatar
Unreal
Most stuff on order.
Upgraded to CA625 head studs. Was a nice inbetween 1/2" studs and normal ARP 2000.
Looking at improved racing crank scraper. Need to figure out if that works with the block/dragon slayer.
Old May 10, 2018 | 07:43 AM
  #131
EnginerdVT's Avatar
EnginerdVT
So the CA625 head studs aren't 1/2" but you still get better clamping force? Sounds like a good option instead of the machining cost for the 1/2" studs and more expensive 1/2" head stud kit if so.
Old May 10, 2018 | 07:54 AM
  #132
Unreal's Avatar
Unreal
Not clamping force, as they are still stock size studs, but they are a stronger material less likely to stretch/deform. Now they may be torqued higher, not sure. Would have to ask engine guy, but the benefit is the strong stud, not increased clamping force.
Was a ~$400 upgrade compared to $860 upgrade. $1000 head studs vs $1460 for 1/2"
Old May 10, 2018 | 08:02 AM
  #133
EnginerdVT's Avatar
EnginerdVT
Great to know. I was told to go for the 1/2" over 1000 whp but the stronger material seems to be the right decision if I'm flirting with that line.
Old May 10, 2018 | 08:38 AM
  #134
Unreal's Avatar
Unreal
4 bolt stock style gm heads are holding 1200rwhp just fine so saying 1000 needs 1/2" seems like a stretch.
Old May 10, 2018 | 08:55 AM
  #135
gameover4's Avatar
gameover4
agreed it be wise to step up to 6 bolt over 1k and maybe 1/2s if over 1500
Old May 10, 2018 | 08:56 AM
  #136
gameover4's Avatar
gameover4
nick do you have a power goal in mind yet? seem to be building it for than your ysi
Old May 10, 2018 | 10:50 AM
  #137
CI GS's Avatar
CI GS
I’m betting there’s a F-1A-94 in his future....
To 2018 Build
Old May 10, 2018 | 11:46 AM
  #138
algZO6's Avatar
algZO6
doubt it, that would be pretty much a lateral move. he's going X
Old May 10, 2018 | 05:25 PM
  #139
Unreal's Avatar
Unreal
I would 100% bet not. If anything, a F1X, or a V15. That being said, goal is just fun reliable, and actually same power as before. It was already a handful, it doesn't need more power.
Old May 10, 2018 | 05:43 PM
  #140
CI GS's Avatar
CI GS
An F1X would make for a monster. I only said that because I seem to recall that you said a while back that if you had to do it over you wouldve gone with the F-1A-94...? Or maybe it was something or someone else? I dunno. I can’t even even keep up with which blower is what these days...
I can only imagine that it was a handful already...
