C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Sloppyz Single Turbo Nitrous c6 z06
Old 02-28-2019, 10:06 AM
  #101
Shortpersonbk
Shortpersonbk's Avatar
Originally Posted by schpenxel
That isn't true.
Using virtual VE you can go as high as you want.
Never looked into this. Everything I was reading just said that our ECU was maxed at 2.5 bar. The guy who tunes my cars is really busy and has alot better things to do then respond to my texts about things like this so i keep it to a minimum.
Originally Posted by g23crawler
Does this exclude ls3 cars? I didn't know there was an issue with running a different map sensor. Mine is a gm performance 3 bar and was like $37 from summit.
Weird. When I was doing all my googling pretty much the only options were to open up the hole in your manifold and make a ls9 one work, or go to the DPE or DSX tuning custom made ones. I emailed DSX at the end of January they responded saying to go to DPE because they discontinued making the pnp map sensors.
I know there are two different electrical connectors I cant remember which group is which i think its ls2/7 share a plug and ls3/9 have another.
Old 02-28-2019, 10:10 AM
  #102
g23crawler
g23crawler's Avatar
This is what I have, works great on my speed density tune. If I remember correctly ls3 are easier because the manifold is already set up for this style of sensor?
https://www.summitracing.com/parts/nal-12592525
Old 02-28-2019, 12:13 PM
  #103
Shortpersonbk
Yeah that is a different style for sure although maybe it still clips in? That really looks like the LS9 one the stub that goes into the manifold should have been around 50 thou larger then OEM was it a really tight fit or require some modification?
Old 02-28-2019, 12:58 PM
  #104
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Saw this posted in a different thread. No need for a downpipe when you just 90 it straight up...
Old 02-28-2019, 03:03 PM
  #105
Shortpersonbk
lol thats exactly what we are doing. We did the samething back when we built my single turbo 2JZ GTE miata. Eventually ill probably change it up to out the fender or something. If somehow the car runs well and I like it we will probably cut the stock hood like that and then lay fiber glass to do a little turbo bump so just the inlet is sticking out. Similar to what that one F1X 6 speed record holder corvette did.
Old 02-28-2019, 03:18 PM
  #106
Innovate
Innovate's Avatar
That is Cody's car I see on IG, that is the plan for mine if I go twins. Stick them out of the hood beside the Hi-Ram. I would hide the single and do fender exit.
Old 03-01-2019, 03:18 PM
  #107
_Wayne_
_Wayne_'s Avatar
I bought Cody's old manifolds for my car. Cool guy, says he regrets going out the hood everytime it rains lol
Old 03-01-2019, 03:23 PM
  #108
Innovate
Innovate's Avatar
Haha, that is why I probably will tuck a single in the compartment and have only my Hi-Ram sticking out. I would slap a normal filter on the turbo if he got caught in the rain. A buddy here in SC has a turbo sticking out like that and just runs a turbo guard.
Old 03-01-2019, 03:27 PM
  #109
_Wayne_
_Wayne_'s Avatar
Yeah, I like that mine will be under the hood and a 5" exhaust out of the bumper just less to worry about. I'm debating on the high ram out the hood too, have to have something to draw attention lol
Old 03-01-2019, 04:35 PM
  #110
Innovate
Innovate's Avatar
It will draw attention, that is for sure!
Old 03-11-2019, 09:03 PM
  #111
Shortpersonbk
Well we got a little farther. More to come throughout the week most likely.
Old 03-12-2019, 01:57 PM
  #112
MTBSully
MTBSully's Avatar
Sick. Log manifold from scratch. Stock hood should fit with a K-member spacer or two.
Old 03-12-2019, 03:04 PM
  #113
Shortpersonbk
Yeah only would need a good foot or so spacer lol.....saw will win this one.
Old 03-12-2019, 05:38 PM
  #114
Pb82 Ronin
Pb82 Ronin's Avatar
I must admit...the go-pro sitting on the roof is an awesome touch considering that car wont be racing for quite a while...
(Unless it's there to film an epic time lapse install video, in which case, well played sir)
Old 03-12-2019, 09:17 PM
  #115
Shortpersonbk
Not my gopro it is my buddy who is doing all the fabricating. I think originally he was going to time lapse everything with it but ended up using my phone tri pod. Not sure exactly what if anything he recorded.
Old 03-15-2019, 12:13 PM
  #116
Shortpersonbk
More more charge piping is done 100%.
List of things to finish
Radiator bracket welding after the pieces I designed come back from waterjet.
One more piece of the crossover
Final weld on the manifold
Oil drain
Oil Feed
Catch can
Starter wires
Clean up harness that is laying in weird spots in some places.
Start car pray it runs.
schpenxel (03-15-2019)
Old 03-15-2019, 01:43 PM
  #117
MTPZ06
MTPZ06's Avatar
Looks awesome. Confident that the charge pipe will clear the hood closer to the front bumper?
To Sloppyz Single Turbo Nitrous c6 z06
Old 03-15-2019, 03:15 PM
  #118
Shortpersonbk
We will find out. Worst to worst we will oval it or adjust the height of the intercooler which is not very much work just requires a different spacer setup from ace hardware which is only a couple bucks.
Old 03-17-2019, 09:47 AM
  #119
jayyyw
jayyyw's Avatar
You're much closer than I am, now. Lol
Old 03-17-2019, 09:40 PM
  #120
Shortpersonbk
Gonna be a slow week and going out of town this weekend to pick up a corvette for my dad so your have plenty of time to catch back up haha.
Quick Reply: Sloppyz Single Turbo Nitrous c6 z06
