Now taking orders for the LS2 Predator programmers!
Old Jan 13, 2006 | 02:18 PM
  #101
aaaaa's Avatar
aaaaa
[QUOTE=Burnt C6]
Originally Posted by tbyrne
We now have 3-4 shipments on the way here now. I expect to see boxes any day now
Tom I have a question.
I had a Hypertec programmer in my 98-F150 The tranny canned it’s self and I had to have it towed to the Dealer. Before I got there they flashed the computer and I lost the program because it had to be down loaded and re uploaded every time I took it in. All I had left was a plastic hand held box that was useless. Is this going to be the case with the Predator?
Same thing happened to me. I had a $400 box that did nothing. I called Hypertech and they said 'Too Bad'. Short sighted on their part I would say. Did they think I would keep that car forever and never need another programmer? Well I've had two vettes since then and You know I'm not buying a hypertech.
BTW that's not a thumb.
Old Jan 14, 2006 | 11:18 AM
  #102
AutoCutter's Avatar
AutoCutter
Here are all of the details for this programmer -
The flash tuner that allows for end user adjustability
The flash tuner which accepts custom tunes directly from DiabloSport or from ChipMaster Revolution dealers that you can install yourself
The flash tuner with built-in advanced diagnostic capability that displays fault codes along with descriptions of the code right on the Predator screen
The flash tuner with data monitoring capability
The flash tuner with a true graphical display that's 300% larger then the competition's puny text only display
The flash tuner running on a custom high performance, multi-threading KROS operating system
mind, POWER!
Performance Tune: Designed to add power and torque using premium fuel.
Factory Tune: Designed for users who wants to adjust parameters using the factory tune.
Average power gains are in 10-20 RWHP range in the cars and 20-30 RWHP in the truck line. The Predators additional power makes itself noticeable immediately with an increase in power that starts in the low RPMs and builds into a frenzy at the high RPMs.
A Predator equipped vehicle will notice significant improvements in drivability. The additional power and improved shift patterns created by the Predator tune will yield quicker acceleration, firmer shifts and better mileage, whether it is in town or out on the highway towing an 8,000 lbs trailer.
The power increase in the lower RPMs will yield a better throttle response. The wider power band that the Predator creates will be particularly noticeable in city driving, where speeds constantly change. The mid-to-upper power increase is extremely useful on the highway when passing slower vehicles and to quickly maneuver out of emergency situations.
The increase in MPG is a byproduct of maximized engine efficiency, the improved timing curve and air/fuel ratio creates a more complete combustion, i.e. the engine extracts more power from each molecule of gasoline.
Predator tunes re-map the:
Fuel Curves
Timing Curves
Torque Management
Extend Rev Limiters
DiabloSport Performance tunes require the use of Super Unleaded / Premium grade fuel only, like carried by Amoco/BP, Sunoco or Mobil.
2) Predator Applications
The Predator 2005 GM 6.0L LS2 (part no. U7191) is applicable for the following vehicles:
2005 Chevrolet Corvette
2005 Chevrolet SSR
2005 Pontiac GTO
3) What is the GM Predator?
The Predator for 2005 GM 6.0L LS2 (part no. U7191) is a state-of-the art high performance tuning flash programmer, which advances the timing and optimizes the air/fuel ratio . Unlike other 'tuners', DiabloSport’s programming is performed in very small increments throughout the entire RPM range, for a smoother, wider and a more predictable power delivery.
4) Why to get DiabloSport Predator?
In house engineering and manufacturing is the only way to assure quality in every component. DiabloSport does it all, from molding the plastic to automated assembly of each product. Check out our virtual factory tour.
5) Dyno Tested Performance Tunes
The Predator was created with one thing in mind, POWER!
Fuel Curves
Timing Curves
Torque Management
Extend Rev Limiters
6) Adjustable Parameters
The Predator features end user adjustable parameters so the end user can customize his/her tune depending on other modifications done to the vehicle. Because we allow for timing and fuel adjustments the end user can optimize the tune for his/hers specific vehicle utilizing a dyno with proper air fuel monitoring and utilizing the Predator's live data feature to monitor timing and other vital parameters.
The Predator allows the end user to adjust the following parameters:
Timing Table 1000-1800rpm (+15/- 40%)
Timing Table 2000-3800rpm (+15/- 40%)
Timing Table 4000-7000rpm (+15/- 40%)
Fuel Table 2000-3800rpm (+/- 20%)
Fuel Table 4000-7000rpm (+/- 20%)
Idle (+ 400rpm / -400rpm)
Rev Limiters
CAGS ON/OFF (skip shift)
COT ON/OFF (catalytic converter overtemp protection)
COT enable time
Fan Calibration
Injector Adjustment
Adjust for different injector size
Adjust for long term fuel trims
The Predators diagnostic features allows end user scan and erase fault codes as well as monitor and log live data while driving. Predator can read and erase fault codes, and contains all the manufacturer specific P codes.
You get all of this for $399.99 and we include free overnight shipping to you!
Tom
This is going to be one useful tool! I can't wait until it is in my hands!
Old Jan 15, 2006 | 01:35 AM
  #103
SpinMonster's Avatar
SpinMonster
I had a similar experience with a predator but the vendor replaced the unit for me so just because one company gave you the shaft doesn't mean they all perform that way. All that says to me is you bought the wrong programmer from the wrong vendor.
I bought mine from a forum vendor that simply listened to the story and since it was feasible they replaced it.
Old Jan 16, 2006 | 06:05 PM
  #104
tbyrne's Avatar
tbyrne
From: Westport, MA. www.tbyrnemotorsports.com - 1-877-4-TBYRNE
St. Jude Donor '06-'07
Tracking info is being sent as orders go out.
Enjoy!
Old Jan 16, 2006 | 06:17 PM
  #105
aaaaa's Avatar
aaaaa
I thought that's what I said. I bought a programmer from HYPERTECH.
